Hey,
i would like to realize a project to take pictures every hour or so with a cam from a ESP32-Cam-Module. The pictures should be stored on a SD-Card, which is connected at a Mega 2560. Now I would like to access the pictures from anywhere in the world. For that I need to make the Arduino a server with a GSM-module.
The questions that i struggle me most right now are those:
is it possible to get access on the Arduino via IP-Address, when it is connected with the GSM-Module? Sometimes i read, that you cannot enter those IPs from outise (blocked by the provider of the SIM-card)
do you know any tutorials, how this would work. I can only find some, where small text messages are sent to control smart home etc.
is it possible to send data from the ESP32-CAM- module directly to the Mega2560, where I would like to store the picture-data on an SD-card?
It would be great if anyone could share some experience or links to good tutorials with me.
Hey,
the cam shall be positioned under water. So there is no wifi network nearby and i need to send the data to the surface first and then use the gsm module with a data plan Sim card to send the data to a server. Also I want to use several cams later. So I thought about triggering the shots from a central mega, which has a SD module to save all pictures as a backup and a connection to the gsm module. Normally the pictures should be sent to a server, so that you can see the pictures taken with the cam.
What sort of wired connection are you planning to have between the ESP32 and the Mega? I suspect sending images will be very slow. Also the Mega does not have the memory or the performance for that sort of project. Consider using a Raspberry PI.
Robin2:
I wonder if the ESP32-cam can do wired ethernet?
Possibly, but it can be a struggle.
Whilst the ESP32CAM appears to have spare pins, these spare pins are actually shared with the SD card, normally used as MMC.
I have mananged to get an SPI based LoRa device running on the ESP32CAM but you have to use the devices; camera, SD, LoRa in a specific order and restart (put into deep sleep) the ESP32 between uses.
