Hi I try to use AJAX to create a website. This website contain a rectangle change there filling color as variable temperature increase. For example if temperature 0-10 there will no filling color. If it is 90 -100 the rectangle is fully fill. The variable temperature will be receive value from esp32 through HTTP. However, when I create a callback to access the value is not working. Could you guy give me some advice?
Code snapshot where I have problem :
setInterval( repeatThis, 3000 );
function repeatThis() {
sendGetRequest ('/percentage',function(response) {
drawFunction(response);
} // end function
function drawFunction(xml) {
alert(xml); // make sure you are able to capture this xml response here
var temperature = parseFloat(xml.responseText);
var canvas = document.getElementById("DemoCanvas");
if (canvas.getContext)
var ctx = canvas.getContext('2d');
ctx.lineWidth = "3";
ctx.strokeStyle = "green";
ctx.strokeRect(5, 50, 350, 200);
ctx.lineJoin = "round";
ctx.strokeRect(355, 140, 40, 30);
if (temperature === 0 ){
ctx.fillStyle = 'rgb(102, 204, 0)';
ctx.fillRect(9, 55, 50, 190);
ctx.font = "100px Comic Sans MS";
ctx.fillStyle = "red";
ctx.fillText(temperature , 500 , 180 );
ctx.fillText("%" , 690 , 180 );
else if (temperature <= 30 && temperature >= 20){
ctx.fillRect(8, 55, 150, 190);
else if (temperature <= 40 && temperature >= 31 ){
ctx.fillRect(8, 55, 155 , 190);
else if (temperature <= 50 && temperature >= 41 ){
ctx.fillRect(8, 55, 180 , 190);
else if (temperature <= 60 && temperature >= 51 ){
ctx.fillRect(8, 55, 190 , 190);
else if (temperature <= 70 && temperature >= 61 ){
ctx.fillRect(8, 55, 220 , 190);
else if (temperature <= 80 && temperature >= 71 ){
ctx.fillRect(8, 55, 250 , 190);
else if (temperature <= 90 && temperature >= 81 ){
ctx.fillRect(8, 55, 300 , 190);
else {
ctx.fillRect(8, 55, 340 , 190);
} // end function
function sendGetRequest ( url, gotResponse ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
gotResponse( this.responseText );
xhttp.open('GET', url , true);
xhttp.send();
} // end function
ESP32 code:
#include <string.h>
#include <Arduino.h>
#include "temperature.h"
#include "charge.h"
#include "current.h"
#include <Wire.h>
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <AsyncTCP.h>
#include "SPIFFS.h"
// Replace with your network credentials
const char* ssid = "JKL";
const char* password = "privacy";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String temperature_text = "25" ;
String percentage_text = "50" ;
temperature bms;
charge battery ;
current battery_2;
Serial.println("Hello, ESP32!");
// Initialize SPIFFS
if(!SPIFFS.begin()){
Serial.println("An Error has occurred while mounting SPIFFS");
return;
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Print ESP32 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.html");
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperature_text.c_str());
server.on("/percentage", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", percentage_text.c_str() );
server.begin();
battery.begin();
bms.begin();
battery_2.begin();
bms.calculate_temperature();
battery.pin_multiplexer();
battery.check_voltage();
battery.percentage();
battery_2.check_current();
My full website code :
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<script src="https://code.highcharts.com/highcharts.js"></script>
<style>
body {
min-width: 310px;
max-width: 800px;
height: 400px;
margin: 0 auto;
h2 {
font-family: Arial;
font-size: 2.5rem;
text-align: center;
</style>
</head>
<body>
<h2>Battery Managment System </h2>
<div id="chart-temperature" class="container"></div>
<p id="percentage_battery"></p>
<canvas id="DemoCanvas" width="1000" height="600"></canvas>
</body>
<script>
var chartT = new Highcharts.Chart({
chart:{ renderTo : 'chart-temperature' },
title: { text: ' Battery Temperature' },
series: [{
showInLegend: false,
data: []
plotOptions: {
line: { animation: false,
dataLabels: { enabled: true }
series: { color: '#059e8a' }
xAxis: { type: 'datetime',
dateTimeLabelFormats: { second: '%H:%M:%S' }
yAxis: {
title: { text: 'Temperature (Celsius)' }
credits: { enabled: false }
setInterval(function ( ) {
var x = (new Date()).getTime(),
y = parseFloat(this.responseText);
if(chartT.series[0].data.length > 40) {
chartT.series[0].addPoint([x, y], true, true, true);
chartT.series[0].addPoint([x, y], true, false, true);
xhttp.open("GET", "/temperature", true);
xhttp.send();
}, 30000 ) ;
} // end function
else {
} // end function
xhttp.send();
} // end function
</script>
</html>
