Hi!
Pretty brand new to arduino, but the forums and help sections have been great guidance in creating a solid foundation for me. However, now, I need some help! I tried creating a pause function in my program and it's running as expected. Basically, I have 2 "run" program buttons: Run1 and Run2 with a Pause button and a Continue button. When I press Run1, the "program" runs - it's just a simple Serial.println command. However, when the Pause button is pressed, the logic doesn't stop. The Pause is executed after Run1 has finished. I was hoping someone could take a look at my code and point out where I messed up my logic, etc.
Thanks in advanced!
#include <genieArduino.h>
#define BUT_RUN1 0x00
#define BUT_RUN2 0x03
#define BUT_RUN 0x06
#define BUT_PAUSE 0x07
#define BUT_CONT 0x08
//#define ACTION_NONE 0
//#define ACTION_RUN 1
//#define ACTION_RUN1 2
//#define ACTION_RUN2 3
//#define ACTION_PAUSE 4
int x,z;
int a,b;
int runParam[2];
int previousZ;
int startZ;
int runID = 0;
int action;
void run1(){
a = runParam[0];
startZ==previousZ;
for(int z=startZ; z<=a; z++){
Serial.println("Run 1: ");
Serial.println(z);
delay (3000);
previousZ==z;
void run2(){
b = runParam[1];
startZ==previousZ;
for(int z=startZ; z<=b; z++){
Serial.println("Run 2: ");
Serial.println(z);
delay (3000);
previousZ==z;
// Test for the pressing of the pause button.
// return true if it was pressed, false if not
boolean pausePressed(){
genieFrame Event;
genieDoEvents();
if (genieDequeueEvent(&Event)) {
if(Event.reportObject.object == GENIE_OBJ_WINBUTTON){
if (Event.reportObject.index == 0x07) {
return true;
Serial.println('True');
return false;
Serial.println('False');
// Wait for the user to press the continue button
void pause(){
genieFrame Event;
while(1) { //while(1) creates an infinite loop that you can break out of if the statement becomes false
genieDoEvents();
if(Event.reportObject.index == 0x08) {
//return;
delay(100);
void myGenieEventHandler() {
int action = 0; //Case 0 ACTION_NONE
genieFrame Event;
genieDequeueEvent(&Event);
if (Event.reportObject.object == GENIE_OBJ_WINBUTTON) {
if(Event.reportObject.index == 0x00){
runParam[0]=10;
Serial.println("run1 on");
action = 2; //Case 2 ACTION_RUN1
//runID = 1;
if(Event.reportObject.index == 0x03){
runParam[1]=10;
Serial.println("run2 on");
action = 3; //Case 3 ACTION_RUN2
//runID = 2;
if(Event.reportObject.index == 0x06){
Serial.println("Pressed Run: ");
action = 1; //Case 1 ACTION_RUN
if(Event.reportObject.index == 0x07){
Serial.println("Button [Pause] Pressed");
action = 4; //Case 4 ACTION_PAUSE
pausePressed();
switch(action) {
case 1: //ACTION_RUN:
if (runID == 1) break;
if (runID & 0) {
run1();
if (pausePressed()) {
// the pause button was pressed while run1() was executing
pause();
if (runID & 2){
run2();
runID = 0;
case 2: //ACTION_RUN1:
runID |= 1;
case 3: //ACTION_RUN2:
runID |= 2;
case 4: //ACTION_PAUSE:
Serial.println ("Pause");
pause(); //waiting for the continue button to be pressed
Serial.println ("Continue");
//return action;
void setup(){
genieBegin(GENIE_SERIAL_1, 9600);
genieAttachEventHandler(myGenieEventHandler);
pinMode(4, OUTPUT);
digitalWrite(4,1);
delay(100);
digitalWrite(4,0);
delay(3500);
genieDoEvents();
delay(100);
