Creating a library
Right now I am somewhat stuck with the seemingly trivial task of creating a library. My .h is
#ifndef EEPromWearLeveling_h
#define EEPromWearLeveling_h
#include <Arduino.h>
uint8_t get_next_count(const uint8_t count_limit);
#endif
The .cpp file is
#include <EEPromWearLeveling.h>
#include <../EEPROM/EEPROM.h>
extern EEPROMClass EEPROM;
uint8_t get_next_count(const uint8_t count_limit) {
	// n cells to use --> 1/n wear per cll --> n times the life time
	const uint16_t cells_to_use = 512;
	// default cell to change
	uint8_t change_this_cell  = 0;
	// value of the default cell
	uint8_t change_value = EEPROM.read(change_this_cell);
	// will be used to aggregate the count_limit
	// must be able to hold values up to cells_to_use*255 + 1
	uint32_t count = change_value;
	for (uint16_t cell = 1; cell < cells_to_use; ++cell) {
		uint8_t value = EEPROM.read(cell);
		// determine current count by cummulating all cells
		count += value;
		if (value != change_value ) {
			// at the same time find at least one cell that differs
			change_this_cell = cell;
	// Either a cell differs from cell 0 --> change it
	// Otherwise no cell differs from cell 0 --> change cell 0
	// Since a cell might initially hold a value of -1 the % operator must be applied twice
	EEPROM.write(change_this_cell, (EEPROM.read(change_this_cell) % count_limit + 1) % count_limit);
	// return the new count
	return (count + 1) % count_limit;
Both reside in the arduino-1.0/libraries/EEPromWearLeveling folder.
The sketch that fails to compile is
	uint8_t count = get_next_count(20);
	for (uint8_t pin = 0; pin < 20; ++pin) {
		pinMode(pin, OUTPUT);
		digitalWrite(pin, pin == count);
void loop() { }
The compiler always complains like this
/Blinkenlight_503_count_resets_with_library.cpp.o /tmp/build3254984387109484155.tmp/EEPromWearLeveling/EEPromWearLeveling.cpp.o /tmp/build3254984387109484155.tmp/core.a -L/tmp/build3254984387109484155.tmp -lm
EEPromWearLeveling/EEPromWearLeveling.cpp.o: In function `get_next_count(unsigned char)':
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:32: undefined reference to `EEPROM'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:32: undefined reference to `EEPROMClass::read(int)'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:39: undefined reference to `EEPROM'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:39: undefined reference to `EEPROMClass::read(int)'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:54: undefined reference to `EEPROM'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:54: undefined reference to `EEPROMClass::read(int)'
/home/udo/Desktop/arduino-1.0/libraries/EEPromWearLeveling/EEPromWearLeveling.cpp:54: undefined reference to `EEPROMClass::write(int, unsigned char)'
Would someone please hit me with a clue bat?
Try adding #include <EEPROM.h> in your .pde (or .ino) file. I suspect the arduino preprocessor isn't linking in the EEPROM.cpp file.
You nailed it. Thanks a lot. Any ideas how I can convince this stupid IDE to pick up its own libraries the way it should?
Here's the issue regarding it:
http://code.google.com/p/arduino/issues/detail?id=236
OK, thanks for the examplanation. To summarize it in my terms: the build + link process is broken, the IDE sucks. I should stick to make or scons unless I am writing tutorials :frowning:
