Hey all, i'm trying to create an ON/Off switch for a program I am running.
Simply put, if the switch is off it says "Turn Freddy On for a good time"
If the switch is on it runs the addition program. I've put my loop below. maybe someone can point out my error.
void loop() // run over and over again
digitalRead(switchPin);
delay (10000);
if (switchPin==LOW)
{Serial.println ("Turn Freddy on for some fun");}
if (switchPin==HIGH)
{Serial.print("Read switch input 1: ");
Serial.println(digitalRead(switchPin));
int val= digitalRead(switchPin);
delay(1000);}
{Serial.print("Read switch input 2: ");
Serial.println(digitalRead(switch2Pin));
int val2= digitalRead(switch2Pin);
delay(1000);}
{Serial.print("Read switch input 3: ");
Serial.println(digitalRead(switch3Pin));
int val3= digitalRead(switch3Pin);
delay(1000);}
{Serial.print("Read switch input 4: ");
Serial.println(digitalRead(switch4Pin));
int val4= digitalRead(switch4Pin);
delay(1000);}
{Serial.print("Read switch input 5: ");
Serial.println(digitalRead(switch5Pin)); // Read the pin and display the value
int val5= digitalRead(switch5Pin);
delay(1000);}
int total= ((val2 + val3 + val4 + val5) * 10 );
{Serial.println(total);}
