I am very new to arduino and have been searching to my wits end of a build online and have not come to any conclusion to that front on what parts to get to build something similar to LINK or LINK modified to run with arduino.
I am not sure which board can handle a motor like LINK.
I want it to be able to connect with software that is for 3d scanning. So I will probably have to ask about the code on their forums. But to start I'm not sure what to do as I read so many posts about the boards not being able to handle a certain voltage. I am guessing the software will call for the stepper motor to turn at small increments until a 360 degress rotation is fulfilled. Would I require certain drives that require additional modifications as in resistors, transistors or H-Bridge. This is all very new to me but I would very much enjoy the learning process to build my first rotating platform that is run by arduino.
The motor you link to is 6V, 0.18A rated. You'd best measure the stall current / winding resistance, though
its probably an amp or two.
It only generates 2Nm of torque so its probably underpowered for a large load like that, I'd suggest starting
at 10Nm as a more plausible value. Doubling the diameter of something means the torque goes up as the
cube or higher power due to the greater mass and greater radius and greater lever arm. 10Nm is the
sort of torque you can apply to a steering wheel easily. 2Nm is more like turning a screwdriver.
Of course you don't want to overdo the motor speed or torque either on safety grounds.
Find a junk recliner that has a rotating base. If you were closer, I would give you what you need to start. I assume you have a woodworking shop the make the rest of the parts similar to the examples you linked to.
Also, the drive belt will need to be a non-stretch type. Probably use a cog belt with a matching drive pulley on your motor of choice. Moving in small increments will require considerable torque to start-stop-hold position with the weight you are designing for.
Serial.println(“S�); // Send scan command to David scanner
You've got some funky unicode double quotes in the file somehow. Perhaps you
used an editor that uses literary double quotes, not ASCII double quotes. The
proper literary ones are a matched pair, 66, 99, not || as in ascii.
MarkT:
That funky code shows up as an "S"not sure why the copy and paste did that.
int MotorControl = 5; // Digital Arduino Pin used to control the motor
// the setup routine runs once when you press reset:
// declare pin 5 to be an output:
pinMode(MotorControl, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(MotorControl,HIGH);// NO3 and COM3 Connected (the motor is running)
delay(1000); // wait 1000 milliseconds (1 second)
digitalWrite(MotorControl,LOW);// NO3 and COM3 Disconnected (the motor is not running)
and this code causes a blinking light when the program is run
// Version 1.0.01 Demo
int inByte; // message from DLS
char outByte ;
delay(150);
if (Serial.available() > 0)
inByte = Serial.read();
if (inByte == 83) // S received from David
do_scan();
if (inByte == 84) // T received from David
stop_scan();
void do_scan()
Serial.println("scan now"); // send this back
void stop_scan()
Serial.println("G"); // Send command for grab texture to David
However I suspect you will need to eliminate ALL the delay()s from both programs and use millis() to manage timing without blocking as illustrated in several things at a time
Truthfullyit will probably be easiest to write a completely new program using the knowledge from the two separate ones.
