Hello all! I'm new to this group, and electronics.
I have a nema 23 stepper motor and rotary table that I'd like to use as a variable speed turntable for shooting video of our chocolate products for my chocolate store. I'll mount it table up, with a 12" aluminum disk, anodized black, for the tabletop.
I have no electronic experience. I've read that that working with the arduino circuit board is straight forward, and relatively easy, so I'd like to build this with an arduino.
I need variable speed 0-10 rpm, forward and reverse, knob or button controlled, because I would constantly be adjusting the speed. It would be nice to be able to run a specific rpm for a specific amount of time, stop for a specific amount of time, and then repeat that pattern as many times as I choose. Right now I just need the basic 0-10rpm and reverse, though.
If anyone out there is interested in helping, I need a list of hardware to complete this, and instructions on how to put it all together. I've attached an image of the stepper and rotary table.
I couldn't find a data sheet either. This motor is from the forth axis of one of my Taig cnc mills. What information do I need on the motor? I can call Taig tomorrow and get what is needed.
You need to know what current the motor requires so that you can get a suitable stepper driver board.
I would not be surprised if your motor is over-specced for your application. If the turntable is mounted on good bearings it should not require much torque to rotate it slowly.
It may be cheaper to buy a smaller motor so that you can work with a cheaper stepper driver. But that depends on the specs for your existing motor.
You may also find that a simple geared DC motor would do the job - unless you need the precise location that a stepper can provide.
I am sure you are aware a stepper motor is called that for a reason. It moves in steps and may cause all kinds of problems with your camera frame rate. Can you synchronize the camera framing with the stepper movement?
Thanks Robin. I'll order a Pololu stepper driver DRV8825. And I'm guessing that the Arduino Uno is all I need in addition. What would be the best controller for speed?
Paul: We shoot at 24p and 60p. When I video my cnc's running, there doesn't seem to be an issue.
livetosculpt:
John
Keep in mind, the stepper motor ALWAYS steps to the next step at the same speed. The pause between the steps is what you change with the controller. A lot of the power going to the stepper motor is for holding position between steps.
livetosculpt:
So then maybe I should get a DC motor, seeing that I don't need to hold position, just smoothly rotate at slow speeds.
As suggested in Reply #3
The advantage of the stepper is that it is trivially easy to make the speed accurate. And maybe, using microsteps, the jitter would not be a problem. If you already have the stepper motor it would be worth experimenting.
