I'm having issues with two objects of the same class type. I have a LED class, which has functions to fade in and out, a LED. In my code, I create two objects of this class, and on the board, I fade them in and out.
Code is in my FadingLED.h file, which I #include.
I instantiate these classes - and then in my setup(), I call an Init function on the classes to initialise them and pass all the parameters I need.
And then in the loop, I just keep calling an Update method, which internally, uses Millis() to handle updating the brightness of the LED.
But I think I am having cross contamination of the objects. Because if I trigger them both to fadein and out at the same time, only the first LED fades. If I stagger them, the 2nd LED works, but it's timing seems to be out. It seems like maybe I'm somehow mixing member variables within the class. I'm new to this, so it's probably an obvious fault?
My calling code:
// This #include statement was automatically added by the Particle IDE.
#include "Buzzer.h"
#include "FadingLED.h"
// Pins being used by devices.
int LED1_PIN = A4;
int LED2_PIN = A5;
int PIR_PIN = 3;
int BUZZER_PIN = 0;
// Instantiate the objects
FadingLED LED_1;
FadingLED LED_2;
Buzzer buzzer;
// Setup global variables.
bool AllStill = true;
// Setup.
// Initialise the two LEDs
LED_1.Init(LED1_PIN, 500, 0, true);
LED_2.Init(LED2_PIN, 500, 250, true);
// Set the PIR pinmode.
pinMode(PIR_PIN, INPUT);
Particle.publish("Device","Board initialised", PUBLIC);
buzzer.Beep(100, 2200);
// Function to check if movement has been detected.
bool CheckMovement() {
// Read the pin value.
int val = digitalRead(PIR_PIN);
// Has a new movement been detected?
if(val==true && AllStill==true) {
buzzer.Beep(200, 2200);
AllStill = false;
Particle.publish("Device", "Movement Detected", PUBLIC);
AllStill = !val; // All still is false if we have movement.
return val != 0;
// Check for moment.
bool val = CheckMovement();
// Update connected devices.
LED_1.Update(val);
LED_2.Update(val);
buzzer.Update();
Below is the class it's self. It's pretty basic... Just runs up and down the brightness for the given period that the LED must be on for. So in my code, I'm just telling it how long it must complete one fade cycle (Fade up, and down in that time). It's a bit messy (The way to works out the brightness) but it works for now. The issue seems to be - my classes are mixing variables, I think.
- A class that manages a fading LED. This needs to be on PWM pin.
class FadingLED {
int delayedStart = 0; // Period to wait before starting.
int ledPin = -1; // The pin to control - Note, as we're fading, we must use an ANALOG pin.
long fadePeriod = 0; // The time to do a full light and dim cycle.
unsigned long previousMillis = 0; // The previous millis value.
bool debug = false; // Should we output stuff?
float fadeChangeGap = 0; // Calculated gap between brightness changes.
unsigned long firstMillis = -1;
public:
void Init(int LedPin, int FadePeriod, int DelayedStart, bool Debug) {
ledPin = LedPin;
fadePeriod = FadePeriod;
delayedStart = DelayedStart;
debug = Debug;
pinMode(ledPin, OUTPUT);
Particle.publish("Debug", "LED Initialised on " + String(ledPin) + ", Fade Period is " + String(fadePeriod) + ", Start Delay is " + String(delayedStart), PUBLIC);
void Update(bool isOn) {
// Get the current millis since the board was started.
// Is this the first time this code is running?
if(firstMillis == -1)
firstMillis = currentMillis; // Set the first time this class was run.
// Adjust the current time to be based on the current time since the object was created.
currentMillis = currentMillis - firstMillis;
// Calculate the difference bwteen the last update and now.
unsigned long diff = currentMillis - previousMillis;
int brightness = 0;
// Check if we have a delay set. If so, don't light up yet.
if(delayedStart > 0 && currentMillis < delayedStart) {
Particle.publish("LED", "In Delay Start...", PUBLIC);
return;
// Map the difference which is betweem 0 and the cycle time, to a value between 0 and 512.
// Map the difference, which is between 0 and the fade period, to a value between 0 at 512.
int b = map(diff, 0, fadePeriod, 0, 512); // 512, as we'll brighten to 256, then then fade from 256 to 512.
// Check if we should be bringtning, or fading...
if(b > 255) {
brightness = 255 - (b-255);
brightness = b;
if(isOn == false) {
brightness = 0;
// Set the brightness.
analogWrite(ledPin, brightness);
// And then save the timestamp.
if(currentMillis - previousMillis >= fadePeriod) {
Any help would be great. Am I creating objects in the wrong way?
If I create just one object... it works fine.
I've tried:
FadingLED LED_1 = new FadingLED();
But get:
"conversion from 'FadingLED*' to non-scalar type 'FadingLED' requested"
