Cross-platform support via ifdefs
I'm working on Tensorflow for microcontrollers and the same C++ source is used to build for (among others) Linux as well as Arduino.
I would like to use #ifdefs to separate out the platform specific code.
For example:
void my_function() {
... // common code to both Arduino and Linux
#ifdef MICRO_BUILD // embedded target
... // Arduino-specific implementation.
#else // Linux
... // More general implementation, with say dynamic memory allocation or Linux-only matrix math libraries.
#endif
This pattern works fine with the arduino-cli:
arduino-cli compile --build-properties compiler.cpp.extra_flags=-DMICRO_BUILD
However, I can not figure out how to specify -DMICRO_BUILD for the Tensorflow Arduino library when it is built via the Arduino IDE as part of a sketch.
Is there a way to specify some custom cflags for a library? Maybe something similar to the ldflags that can be specified in library.properties so that any sketch that uses the Tensorflow Arduino library will build that library with -DMICRO_BUILD?
You could use #ifdef ARDUINO, it's defined by the Arduino builder.
Also, all hardware platforms and architectures have their own defines, so you could even differentiate between ARM and AVR, for example.
Pieter
Thanks! I knew about the hardware platform defines but a blanket ifdef ARDUINO does the trick for me.
