cross voltages from neighbor analog input?
Hello all,
I am using 4 piezos (and more comings) connected on a muxshield on analog inputs 0 to 3.
My code was working but I now encounter a problem.
If one of my sensor is unplugged e.g. pin 3 and I push the one on pin 2 a voltage is detected also on pin3. If I replug everything goes back to normal.
I have tried to remove the mux shield and changed the code to read arduino analog inputs and I have the same issue.
The piezo are connected in parrallel with a 5,1 zener and a 1Mohm resistor.
I have now tried to input 5volt on pin 2 with pin 3 unplugged and get the same issue (the consequence here is two midi notes playing at the same time.
I think I have burnt something on my UNO board...maybe one of you have another idea?
here is my code.
Thanks a lot,
Rok
// User settable variables
//exemple avec millis
//http://forum.arduino.cc/index.php/topic,76140.msg574940.html#msg574940
#include <MuxShield.h> // for the muxshield library (optional?)
unsigned char PadNote[6] = {52,53,54,55,56,57};         // MIDI notes from 0 to 127 (Mid C = 60)
unsigned char CurrentPadNote[6] = {0,0,0,0,0,0};         // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {600,600,600,600,600,600};           // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {90,90,90,90,90,90};               // Cycles before a 2nd hit is allowed
#define  midichannel    0;                              // MIDI channel from 0 to 15 (+1 in "real world")
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0};                   // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0};                     // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Multitasking
// Time periods of blinks in milliseconds (1000 milliseconds to a second).
// Time variable and constants are always unsigned long
const unsigned long MidiOutSendInterval = 1UL ;
const unsigned long MidiInReadInterval = 50UL ;
// Variable holding the timer value so far. One for each "Timer"
unsigned long MidiOutSendTimer = 0 ;
unsigned long MidiInReadTimer = 0 ;
// Midi In Variables
byte statusIN;
byte PitchIN;
byte VelocityIN;
//Initialize the Mux Shield
MuxShield muxShield;
// Setup
 //Set I/O 1,  as analog inputs
muxShield.setMode(1,ANALOG_IN);
 MidiOutSendTimer = millis () ;
MidiInReadTimer	= millis () ;
// connect to the serial port 31250 for MIDI communication
 Serial.begin(31250);
//Serial.begin(9600);
// Main Program
// First, check if it is time to send Midi
  if ( (millis () - MidiOutSendTimer) >= MidiOutSendInterval ) {
  for(int pin=0; pin < 4; pin++)
    //hitavg = analogRead(pin);
    // read the input pin, classic input version
	hitavg = muxShield.analogReadMS(1,pin); // read muxShield analog value on pin pin, row 1
    if((hitavg > PadCutOff[pin]))
      if((activePad[pin] == false))
        if((CurrentPadNote[pin] != PadNote[pin])){
        CurrentPadNote[pin] = PadNote[pin];
        MIDI_TX(144,PadNote[pin],127);
        PinPlayTime[pin] = 0;
        activePad[pin] = true;
        PinPlayTime[pin] = PinPlayTime[pin] + 1;
    else if((activePad[pin] == true))
      if(PinPlayTime[pin] > MaxPlayTime[pin])
        activePad[pin] = false;
        MIDI_TX(128,CurrentPadNote[pin],127);
  // end of the loop Reset timer with current time at end
  //Check if is time to read midi in
  if ( (millis () - MidiInReadTimer) >= MidiInReadInterval ) {
  // ok it is time
	checkMIDI();
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
  status = MESSAGE + midichannel;
  Serial.write(status);
  Serial.write(PITCH);
  Serial.write(VELOCITY);
// Receive MIDI Message
void checkMIDI(){
  do{
    if (Serial.available()){
      statusIN = Serial.read();//read first byte
      PitchIN = Serial.read();//read next byte
      VelocityIN = Serial.read();//read final byte
      if (statusIN == 145 && PitchIN != 0 && VelocityIN != 0){//if Chan 2 note on
	  digitalWrite(13,HIGH);//turn on led
	   //assign value to pad note
      PadNote[0] = PitchIN;
        digitalWrite(13,LOW);//turn of led
  while (Serial.available() > 24);//when three bytes available
This is normal, you have the pin in a "floating" state, and it is very susceptible to tiny voltages, even bringing your hand near it will change the reading. Adding pullup/down resistors will fix it.
Another suggestion, is to read the analog input twice. First read discard, second read keep.
Thanks to both of you,
I have done some other tests keeping the resistor and the zener plugged, without the piezo, and they are sufficient to correct this. What surprised me is that I had a threshold at 600 for the analog value and was still getting some "false positive".
Also reading two times
didn't change anything. This tiny voltages seems to stay too long.
