Hello, this is my very simple lib to access timer interrupts API on ChipKIT/PIC32MX and Arduino/AVR without dealing with platform-specific headers and registers.
to install
cd ~/Arduino/libraries/
git clone https://github.com/sadr0b0t/arduino-timer-api.git
or on github page click Clone or download > Download ZIP, then install arduino-timer-api-master.zip ZIP via Arduino library installation menu.
restart IDE, examples would appear in File/Examples/arduino-timer-api menu
Basic example:
#include"timer-api.h"
// freq 5Hz == 5 ops per second <=>
// timer period = 200ms
timer_init_ISR_5Hz(TIMER_DEFAULT);
// freq 50Hz == 50 ops per second <=>
// timer period = 20мс
//timer_init_ISR_50Hz(TIMER_DEFAULT);
pinMode(13, OUTPUT);
Serial.println("Hello from loop!");
delay(5000);
// any code here: blocking or non-blocking
void timer_handle_interrupts(int timer) {
static unsigned long prev_time = micros();
unsigned long _time = micros();
unsigned long _period = _time - prev_time;
prev_time = _time;
static int count = 5;
// print message every 5th interrupt call
// (with interrupt freq 5Hz - print once per second)
if(count == 0) {
Serial.print("goodbye from timer: ");
Serial.println(_period, DEC);
digitalWrite(13, !digitalRead(13));
count = 5;
count--;
Procedure timer_handle_interrupts would be called with chosen frequency no matter what the main loop contains and doing, so this is a kind of specific multitasking in the same sketch.
Most common frequencies are available with corresponding calls in a cross-platform way:
void timer_init_ISR_100KHz(int timer);
void timer_init_ISR_50KHz(int timer);
void timer_init_ISR_20KHz(int timer);
void timer_init_ISR_10KHz(int timer);
void timer_init_ISR_5KHz(int timer);
void timer_init_ISR_2KHz(int timer);
void timer_init_ISR_1KHz(int timer);
void timer_init_ISR_100Hz(int timer);
void timer_init_ISR_50Hz(int timer);
void timer_init_ISR_20Hz(int timer);
void timer_init_ISR_10Hz(int timer);
void timer_init_ISR_5Hz(int timer);
You can also provide your own frequency setting by setting custom timer, prescaler and timer compare adjuster value
// http://www.robotshop.com/letsmakerobots/arduino-101-timers-and-interrupts
// 1. CPU frequency 16Mhz for Arduino
// 2. maximum timer counter value (256 for 8bit, 65536 for 16bit timer)
// 3. Divide CPU frequency through the choosen prescaler (16000000 / 256 = 62500)
// 4. Divide result through the desired frequency (62500 / 2Hz = 31250)
// 5. Verify the result against the maximum timer counter value (31250 < 65536 success) if fail, choose bigger prescaler.
// Arduino 16МГц
// Настроим и запустим таймер с периодом 20 миллисекунд (50 срабатываний в секунду == 50Гц):
// prescaler=1:8, adjustment=40000:
// 16000000/8/50=40000 (50Hz - срабатывает 50 раз в секунду, т.е. каждые 20мс)
// Обработчик прерывания от таймера - функция timer_handle_interrupts
// (с заданными настройками будет вызываться каждые 20мс).
//timer_init_ISR(TIMER_DEFAULT, TIMER_PRESCALER_1_8, 40000-1);
// ChipKIT PIC32MX 80МГц
// prescaler=1:64, adjustment=25000:
// 80000000/64/25000=50 (срабатывает 50 раз в секунду, т.е. каждые 20мс)
timer_init_ISR(TIMER_DEFAULT, TIMER_PRESCALER_1_64, 25000-1);
delay(5000);
// any code here: blocking or non-blicking
* Процедура, вызываемая прерыванием по событию таймера с заданным периодом.
prev_time = _time;
static int count = 50;
// печатаем статус каждые 50 вызовов прерывания,
// на частоте 50Гц - 1 раз в секунду
if(count == 0) {
count = 50;
count--;
But your code might lose cross-platformity in this case.
