Merry Christmas and a happy new year. So I have kind of an odd one. I am using a AZERTY keyboard and a Arduino nano ESP32. I found out that the characters aren't the ones that the examples says. So I made an Excel file of it: |Column 1 | Column 2 | Column 3 | Column 4|
HEX
DEC
button
Shift?
0x00
1
no
0x01
2
no
0x02
3
no
0x03
4
no
0x04
5
no
0x05
6
no
0x06
7
no
0x07
8
no
0x08
9
backspace
no
0x09
10
tab
no
0x0a
11
enter
no
0x0b
12
no
0x0c
13
no
0x0d
14
no
0x0e
15
no
0x0f
16
no
0x10
17
no
0x10
18
no
0x11
19
no
0x12
20
no
0x13
21
no
0x14
22
no
0x15
23
no
0x16
24
no
0x17
25
no
0x18
26
no
0x19
27
no
0x1a
28
no
0x1b
29
no
0x1c
30
no
0x1d
31
no
0x1e
32
no
0x1f
33
no
0x20
34
space
no
0x21
35
1
yes
0x22
36
yes
0x23
37
3
yes
0x24
38
4
yes
0x25
39
5
yes
0x26
40
7
yes
0x27
41
ù
no
0x28
42
9
yes
0x29
43
0
yes
0x2a
44
8
yes
0x2b
45
shift
yes
0x2c
46
no
0x2d
47
no
0x2e
48
no
0x2f
49
no
0x30
50
à
no
0x31
51
no
0x32
52
é
no
0x33
53
no
0xa9
171
no
0xaa
172
no
0xab
173
no
0xac
174
è
no
0xad
175
_
no
0xae
176
ç
no
0xaf
177
à
no
0xb0
178
enter
no
0xb1
179
esc
no
0xb2
180
backspace
no
0xb3
181
tab
no
0xb4
182
space
no
0xb5
183
no
0xb6
184
no
0xb7
185
no
0xb8
186
no
0xb9
187
no
0xba
188
no
0xbb
189
m
no
0xbc
190
ù
no
0xbd
191
²
no
0xbe
192
no
0xbf
193
no
0xc0
194
no
0xc1
195
shiftlock
no
0xc2
196
F1
no
0xc3
197
F2
no
0xc4
198
F3
no
0xc5
199
F4
no
0xc6
200
F5
no
0xc7
201
F6
no
0xc8
202
F7
no
0xc9
203
F8
no
0xca
204
F9
no
0xcb
205
F10
no
0xcc
206
F11
no
0xcd
207
F12
no
0xce
208
printscreen
no
0xcf
209
break
no
0xd0
210
pause
no
0xd1
211
insert
no
0xd2
212
begin
no
0xd3
213
page up
no
0xd4
214
suppr
no
0xd5
215
end
no
0xd6
216
page down
no
0xd7
217
arrow right
no
0xd8
218
arrow left
no
0xd9
219
arrow down
no
0xda
220
arrow up
no
0xdb
221
numlock
no
0xdc
222
no
0xdd
223
no
0xde
224
no
0xdf
225
no
0xe0
226
enter
no
0xe1
227
no
0xe2
228
no
0xe3
229
no
0xe4
230
no
0xe5
231
no
0xe6
232
no
0xe7
233
no
0xe8
234
no
0xe9
235
no
0xea
236
no
0xeb
237
no
0xec
238
no
0xed
239
doc
no
0xee
240
no
0xef
241
no
0xf0
242
no
0xf1
243
no
0xf2
244
no
0xf3
245
no
0xf4
246
no
0xf5
247
no
0xf6
248
no
0xf7
249
no
0xf8
250
no
0xf9
251
no
0xfa
252
no
0xfb
253
no
0xfc
254
no
0xfd
255
no
0xfe
256
no
0xff
257
no
There is in the whole table no ctrl at all. And (this is less important) there is also not one windows or alt code.
I have read the library code, and there it says to use the Keyboard.press(KEY_LEFT_CTRL); command. It is the HEX code 0x80, but if you look at the table it is nothing. So it's not that.
I have read thousands of forums, but it is still possible that I missed the one with the solution. So if there is, could you please send a URL?
Hi @siebe. The Arduino ESP32 Boards platform is a fork of the "esp32" boards platform. I see the developers of the esp32 platform have recently made several bug fixes/enhancements to the library, which might be relevant:
Those changes are not present in the Arduino ESP32 Boards platform because it is based on an older version of the esp32 platform.
The esp32 platform does have support for the Nano ESP32 board (though its support is not validated by Arduino so we do recommend the average user to use the Arduino ESP32 Boards platform instead). If you like, you can give it a try to see if the Ctrl emulation will work as you expect with the latest version of the library. Follow the installation instructions here:
Make sure you install the latest version 3.1.0 of the platform instead of an older version (e.g., 3.0.7), as the second change I linked above is only available from that version.
After you install the platform, select Tools > Board > esp32 > Arduino Nano ESP32 from the Arduino IDE menus and then upload the test sketch to your board again. That will cause the latest version of the library to be used.
When you want to go back to using the official platform, select Tools > Board > Arduino ESP32 Boards > Arduino Nano ESP32 from the Arduino IDE menus.
However, if I then select the Arduino Nano ESP32 board from the "esp32" boards platform version 3.1.0 in Arduino IDE and upload the exact same sketch to the board, then I see the expected keypresses.
Version 2.0.17 of the "esp32" boards platform is installed on the Arduino Cloud servers, so you won't have the bug fix when using Arduino Cloud. Unfortunately I don't know how to fix the bug when using Arduino Cloud.
