You do not need the while(true){} infinite loop
int speakerPin = 9;
//speaker connected to one of the PWM ports
int ledPins[] = {2,3,4,5,6,7,8,1,10,11,12,13};
#define c 261
#define d 294
#define e 329
#define f 349
#define g 391
#define gS 415
#define a 440
#define aS 455
#define b 466
#define cH 523
#define cSH 554
#define dH 587
#define dSH 622
#define eH 659
#define fH 698
#define fSH 740
#define gH 784
#define gSH 830
#define aH 880
//frequencies for the tones we're going to use
int index;
for(index = 0; index <= 11; index++)
pinMode(ledPins[index],OUTPUT);
pinMode(speakerPin, OUTPUT);
//sets the speakerPin to be an output
void loop() // run over and over again
oneAfterAnotherLoop();
void oneAfterAnotherLoop()
int index;
int delayTime = 30;
digitalWrite(ledPins[index], HIGH);
delay(delayTime);
march();
// while(true){}//remove for infinite loop
for(index = 11; index >= 0; index--)
digitalWrite(ledPins[index], LOW);
delay(delayTime);
march();
void beep (unsigned char speakerPin, int frequencyInHertz, long timeInMilliseconds)
//use led to visualize the notes being played
int x;
long delayAmount = (long)(1000000/frequencyInHertz);
long loopTime = (long)((timeInMilliseconds*1000)/(delayAmount*2));
for (x=0;x<loopTime;x++)
digitalWrite(speakerPin,HIGH);
delayMicroseconds(delayAmount);
digitalWrite(speakerPin,LOW);
delay(20);
//a little delay to make all notes sound separate
void march()
//for the sheet music see:
//http://www.musicnotes.com/sheetmusic/mtd.asp?ppn=MN0016254
//this is just a translation of said sheet music to frequencies / time in ms
//used 500 ms for a quart note
beep(speakerPin, a, 500);
beep(speakerPin, f, 350);
beep(speakerPin, cH, 150);
beep(speakerPin, a, 1000);
//first bit
beep(speakerPin, eH, 500);
beep(speakerPin, fH, 350);
beep(speakerPin, gS, 500);
//second bit...
beep(speakerPin, aH, 500);
beep(speakerPin, a, 350);
beep(speakerPin, a, 150);
beep(speakerPin, gSH, 250);
beep(speakerPin, gH, 250);
beep(speakerPin, fSH, 125);
beep(speakerPin, fH, 125);
beep(speakerPin, fSH, 250);
delay(250);
beep(speakerPin, aS, 250);
beep(speakerPin, dSH, 500);
beep(speakerPin, dH, 250);
beep(speakerPin, cSH, 250);
//start of the interesting bit
beep(speakerPin, cH, 125);
beep(speakerPin, b, 125);
beep(speakerPin, cH, 250);
delay(250);
beep(speakerPin, f, 125);
beep(speakerPin, f, 375);
beep(speakerPin, a, 125);
beep(speakerPin, cH, 500);
beep(speakerPin, a, 375);
beep(speakerPin, eH, 1000);
//more interesting stuff (this doesn't quite get it right somehow)
delay(250);
//repeat... repeat
delay(250);
beep(speakerPin, f, 250);
beep(speakerPin, c, 125);
//and we're done \??/
