Board Name: Intel Curie's Tiny Tile
Trying to update two characteristic every 10ms.
The nrf Connect app which is used to receive data gets hanged after few receiving few data packets.
I have also asked the question in GitHub. Here's the link,
- https://github.com/arduino/ArduinoCore-arc32/issues/594
- Can't send BLE data less than 25ms? 路 Issue #593 路 arduino/ArduinoCore-arc32 路 GitHub
Can anyone please find the mistake/bug in the below code
#include <CurieBLE.h>
#include <CurieIMU.h>
#define MAX_IMU_RECORD 1
typedef struct {
聽 聽int index;
聽 聽unsigned int slot[3];
} imuFrameType;
// Buffer to hold IMU data
imuFrameType imuBuf[MAX_IMU_RECORD];
unsigned seqNum = 0;
BLEService bleImuService("A7580001-153E-D4F6-F26D-43D8D98EEB13"); // Tx IMU data Characteristic
BLECharacteristic bleImuChar("F7580003-153E-D4F6-F26D-43D8D98EEB13", // standard 128-bit characteristic UUID
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 BLERead | BLENotify, sizeof(imuBuf)); 聽 // remote clients will be able to
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽// get notifications if this characteristic changes 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽
聽 聽 聽Serial.begin(9600); 聽 聽// initialize serial communication
聽 聽bool txpower_set = BLE.setTxPower(4);
聽 聽BLE.begin();
聽 聽CurieIMU.begin();
聽 聽BLE.setLocalName("Imu");
聽 聽BLE.setAdvertisedServiceUuid(bleImuService.uuid()); 聽// add the service UUID
聽 聽//Accelerometer sampling rate = 200Hz
聽 聽CurieIMU.setAccelerometerRate(200);
聽 聽//Minimum, Maximum connection interval 7.5ms- 10ms (0x06=7.5/1.25, 0x08= 10/1.25)
聽 聽//0x028=50/1.25
聽 聽BLE.setConnectionInterval(0x06,0x28);
聽 聽BLE.addService(bleImuService); 聽 // Add the Imu service
聽 聽bleImuService.addCharacteristic(bleImuChar); // add the Imu characteristic
聽 聽bleImuService.addCharacteristic(bleImuChar1);
聽 聽bleImuService.addCharacteristic(bleImuChar2);
聽 聽bleImuService.addCharacteristic(bleImuChar3);
聽 聽BLE.advertise();
聽 聽BLEDevice central = BLE.central();
聽 聽// if a central is connected to peripheral:
聽 聽if (central)
聽 聽{
聽 聽 聽 聽long currentMillis, sentTime;
聽 聽 聽 聽// Send IMU data as long as the central is still connected
聽 聽 聽 聽currentMillis = sentTime = millis();
聽 聽 聽 聽while (central.connected())
聽 聽 聽 聽{
聽 聽 聽 聽 聽while(bleImuChar.canNotify())
聽 聽 聽 聽 聽{
聽 聽 聽 聽 聽 聽// update IMU data every 10ms
聽 聽 聽 聽 聽 聽if ((millis() - sentTime) >= 10)
聽 聽 聽 聽 聽 聽{
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽for(int i=0; i<=1; i++)
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽{
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽//Reads acc data
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽recordImuData(i);
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽delay(10);
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽}
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽bleImuChar.setValue((unsigned char *)&(imuBuf[0]), sizeof(imuBuf[0])); // Sets Tx buffer to
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 //the read acc data
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽sentTime = millis(); 聽//note what time data was sent
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽for(int j=0;j<=1;j++)
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽for(int k=0; k<=2; k++)
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽{
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽Serial.println(imuBuf[j].slot[k]);
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽imuBuf[j].slot[k]=0;
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽}
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽
聽 聽 聽 聽 聽 聽 聽 聽 }
聽 聽 聽 聽 聽 聽}
聽 聽 聽 聽}
聽 聽 聽 } // end of while loop
// This function records the IMU data that we send to the central
void recordImuData(int index)
聽 聽// Read IMU data.
聽 聽int ax, ay, az;
聽 聽imuBuf[index].index = seqNum++;
聽 聽CurieIMU.readAccelerometer(ax, ay, az);
聽 聽 聽 聽// the data into the buffer
聽 聽imuBuf[index].slot[0] = (unsigned int)(ax);
聽 聽imuBuf[index].slot[1] = (unsigned int)(ay);
聽 聽imuBuf[index].slot[2] = (unsigned int)(az);
