current transformer switch relay (errormessage)
I have copied a sketch from a youtube video and its the first sketch for me.
I want to do the exact same thing as in the video, switching a relay when AC current is detected to control a fan.
Im stuck with the code tho, it will not compile the sketch, just a lot of error messages. Any help is appriciated.
Here is the error message:
Arduino:1.8.5 (Windows Store 1.8.10.0) (Windows 10), Kort:"Arduino Nano, ATmega168"
C:/CTfet.ino: In function 'void loop()':
CTfet:76: error: expression cannot be used as a function
RELAY1 (ON);
CTfet:81: error: expression cannot be used as a function
RELAY1 (OFF);
CTfet:87: error: 'relayState' was not declared in this scope
if (relayState == OFF) {
C:CTfet.ino: At global scope:
CTfet:106: error: expected initializer before 'if'
if (desiredState == relayState) {
CTfet:111: error: expected unqualified-id before 'if'
if (desiredState == ON) if ( abs(millis() - switch_request_time) > 3000 ) {
CTfet:121: error: expected unqualified-id before 'if'
if (desiredState == OFF) if ( abs(millis() - switch_request_time) > 8000 ) {
CTfet:130: error: expected declaration before '}' token
exit status 1
CTfet.ino (3.78 KB)
This is not the way to do it . You need to play with your Arduino and run the examples, learn how they work , learn how to code and debug stuff . Downloading something off the web that you don’t understand is not the way to do it and makes it hard to help- the web is full of stuff that doesn’t work.
Sorry
OpenSourceE:
Sold as "green powerboard".
Leo..
