We have developed a custom board around Adafruit Feather M4 express. Custom board has SAMD51 microcontroller and Ublox Wifi NINA W152 module. I have been trying to use Wifi and WifiNINA libraries to get Wifi module working. But somehow i cannot connect the module to the WiFi.
I've been wondering how SAMD51 and Wifi nina module are communicating with each other? What exact pins are required according to the WIFININA libraries? Would Wifi module be needed both SPI and UART connections with MCU to get connected to the WiFi?
I cannot be of much help by guessing what you did on your custom board. Posting a schematic, not a frizzy thing and links to technical information on each of the hardware devices will help us help you. Check the schematic and the library source, it will show you what pins are used for what.
What I don't get is so far I've just made modifications to the UART TX and RX signals in the variant files. Do I need to add SPI pins for the WifiNINA as well in the variant files for the W152 module?
Please let me know if you need any other technical information. Thanks for the help.
I went through the post "Ublox nina minimum pins". I've got some questions regarding the pins usage here.
Do we really need UART TX/RX pins to get wifi NINA W152 connected to the Wifi (OR) we just need SPI interface? I am asking this because W152 module does not give you the capability to use UART and SPI at the same time. So its one at a time.
As stated in the post NINA itself acts like a microcontroller, which has a ESP32 module integrated in it....Can I use UART RTS/CTS/DSR/DTS pins as 4-SPI pins as they are GPIOs as well? Please refer the images above I posted yesterday. FYI, I haven't connected pins 31,32,35,36, which are dedicated SPI pins, to the SAMD51.
Alright! Can you also please tell me what module of NINA and MCU you have used in your testing? Have you tested on your own custom board or some other dev boards?
Yes I have already gone through that document. My only question is according to the schematic attached above in my earlier posts, I have connected Tx,Rx,rts,cts,dsr.dtr to the microcontroller and since they are GPIO pins as well, so what if I use them as my 4-SPI pins? According to Wifi and WifiNINA libraries, they use SPI interface in order to get wifi working.
Please give me the suggestions if those 6 GPIOs can be used as SPI pins?
I get it what you are saying. I did configure the SERCOM0 as my SPI pins on the SAMD51 side.
But on the other head, according to my schematic above, you also meant to say it is impossible to connect NINA to the WiFi as per the pin connections? Since UART pins also function as GPIOs, can't I use GPIOs as SPI pins?
Technically, you can connect to WIFI whether you have a SAMD51 connected or not since the ESP32 on the NINA itself is a programmable MCU. You are not required to connect the NINA to any external hardware to be able to connect to WIFI.
I am not sure if the pins on the NINA are multiplexed and can be configured just like the SERCOMs on the SAMD51, my guess is not.
I think you have to define the role of each MCU in your project. Is the SAMD51 the main MCU and you are just using the NINA to provide WIFI connectivity? Or vice versa? In either case, the pins you have on the NINA is the UART pins, so my guess is these can only be used as UART pins and not SPI. But that doesn't stop you from connecting to WIFI since the ESP32 itself can be programmed independently from the SAMD51
That's good to hear that I can connect NINA to the wifi.
Yes you are correct that SAMD51 is the main MCU in our custom board and ublox NINA W152 is just integrated to provide WiFi functionality.
Since I cannot configure pins (which I have on NINA) as SPI and its gonna work as UART only. Now the question comes how I can program NINA via UART pins such that it can connect to my Wifi independently from the SAMD51. What libraries should be used in this scenario. I believe WifiNINA uses only SPI interface right?
What are your suggestions and inputs here? I'd appreciate your help.
There are some AT libraries available to talk to an ESP32 running AT firmware. Or you can always write your own and talk to the NINA ESP32 from the SAMD51 using UART and AT commands
Something like (from the SAMD51)
Serial.println("AT+");
The NINA ESP32 replies with "OK";
Serial.println("AT+CONNECT");
The NINA connects to WIFI and replies "connected..."
You have to read through the manual to determine the exact "AT commands" to command the NINA to do something (or use someone else' AT library)
I have uploaded the sketch as well as my variant files where Serial1 is my Serial hardware Port. I've made the changes in the variant files acc. to the RX and TX pins.
As you can see on .ino file, I am trying to send command "AT" and i am trying to receive something but I am not receiving anything.
I'd really appreciate if you could please review the files if you have some time and let me know where I could go wrong.
