DAC support
Hey there,
I tried the DACC on the Arduino Due, but it doesn't work as expected. I used the function analogWrite() for setting a new DAC value. The following code will work as expected:
byte value;
  analogWrite(DAC0, value++);
Same applies if you replace DAC0 with DAC1. For some unknown reason, I couldn't get both DACs to work simultaneously. The following code does not work:
byte value;
  analogWrite(DAC1, value * 2);
I think it has something to do with the code in hardware/arduino/sam/cores/arduino/wiring_analog.c. In the function analogWrite() there is the following lines:
 // Write user value
 ulValue = mapResolution(ulValue, _writeResolution, DACC_RESOLUTION);
 dacc_write_conversion_data(DACC_INTERFACE, ulValue);
I'm missing the channel selection before writing conversion data. Did someone else use the DACs before with analogWrite()? Is the reported behaviour bug or feature?
mfg, Stefan.
smay4finger,
I fear that you’re right, the analogWrite on DACs didn’t work if you write on both DACs.
I don’t know why, but seems that nobody (including me) ever dreamed to test BOTH channels together.
I’ll put the fix to this in the to-do list, before the next beta release 1.5.1 (that is very close).
C
Fix was trivial. Please find attached the patch for wiring_analog.c. Should I make bug report?
mfg, Stefan.
wiring_analog.c (9.62 KB)
patch (1.65 KB)
smay4finger,
thank for the patch I'm testing it in the next hours, in case may you open a pull request on github so i can merge it?
C
I tested your patch and I think it works!
I attach a sketch that generates a sine wave on both the DAC outputs phase shifted of pi. To prove I add the screen capture of the oscilloscope.
+1 Karma is deserved :slight_smile:
DAC_Sine_Due.ino (2.63 KB)
I made a bug report here: http://code.google.com/p/arduino/issues/detail?id=1092
Please use the patch attached to the ticket. There is also a bugfix regarding corruption of the data register, when writing too fast.
Done, thank you.
C
“I tried the DACC on the Arduino Due, but it doesn’t work as expected. I used the function analogWrite() for setting a new DAC value. The following code will work as expected:”
byte value;
Hello, when i test the DAC on the DUE i measured an Outputvoltage from 0,55V (value 0) to 2,77V (value 255). I thought the DAC has a range from 0V to 3,3V?! Do anybody knows more or can help me?
greets
parasound
"Hello, when i test the DAC on the DUE i measured an Outputvoltage from 0,55V (value 0) to 2,77V (value 255). I thought the DAC has a range from 0V to 3,3V?! Do anybody knows more or can help me?"
Hi all! I would be interested in this too. Could not figure out yet why DAC range ist approx. 0,54V - 2.74V (both channels). andy_G
Hi parasound and andy_g,
I could find no information about the DAC range in the SAM3X datasheet. But on page 1059 of SAM3*S* datasheet, it is said that the voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF. So I suspect, the same applies to SAM3U, and range is 1/6 x 3.3V = 0.55V to 5/6 x 3.3V = 2.75V, which is verified by your measures.
wibauxl
Ok. Thank you wibauxl.
wibauxl: Hi parasound and andy_g,
wibauxl
That seems pretty limiting. You mean one can't measure output signals between below .55 volt? There must be more to the subject then that?
Lefty
@retrolefty
We're talking about the DAC here. The ADC works at voltages below 0.55v. As far as the DAC is concerned it's a pity to have such limits but I guess for audio applications there are way to circumvent the issue.
m
[quote author=Massimo Banzi link=topic=129765.msg993253#msg993253 date=1352733776] @retrolefty
m [/quote]
Well I don't yet own a Due and not up to the task just yet of taking on the huge datasheet for this uP, but they must talk about this range restriction if indeed it's a hardware based restriction. I just find it very hard to except at this time that there is a legitimate reason for this. I guess it could be compensated for with external op-amp with a -.55v offset, but still there just must be more to this subject then 'that's just the way it is'? It's really not a problem for audio type applications as one could just capacitance couple the signal, but for precision DC DAC applications, not being able to reach ground potential is a pretty big deal, no?
Lefty
...what would also make sense resolution-wise: LSB seems to be 0.5mV (measured) which is in line with wibauxl's theory ((2.75-0.55)/4096=0.537mV). This DAC behaviour -and te lack of it's documentation- is a little odd to my opinion, but at least there's an explanation that makes sense.
MANY THANKS FOR ALL YOUR INPUTS!!
andy_g
andy_g
The Due is still in beta, there is still work to be done on the documentation.
m
wibauxl: I could find no information about the DAC range in the SAM3X datasheet. But on page 1059 of SAM3*S* datasheet, it is said that the voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF. So I suspect, the same applies to SAM3U, and range is 1/6 x 3.3V = 0.55V to 5/6 x 3.3V = 2.75V, which is verified by your measures.
I've just checked with Atmel support and they confirm that SAM3S and SAM3X features the same DAC IP, what you have measured is correct.
[quote author=Massimo Banzi link=topic=129765.msg993253#msg993253 date=1352733776] As far as the DAC is concerned it's a pity to have such limits but I guess for audio applications there are way to circumvent the issue. [/quote]
Yes, for audio applications, if voltage range of the DAC is from (1/6) x VADVREF to (5/6) x VADVREF then you use a differential op-amp with the second input connected to (1/2) x VADVREF - though it would require a symmetric power supply. Or just use a DC blocking capacitor.
It is a surprising limitation for other uses, though.
Hello,
i’am experiencing the same problem as smay4finger described in original post, using this code:
  analogWriteResolution(12);
  analogWrite(DAC0, 4095);
  analogWrite(DAC1, 4095);
void loop(){}
however, this code set correct output values:
  delay(2);
  analogWrite(DAC0, 2047);
  analogWrite(DAC1, 1023);
i suspect problem in this line in wiring_analog.c:
while ((dacc_get_interrupt_status(DACC_INTERFACE) & DACC_ISR_TXRDY) == 0);
but you guys know better.
Regards,Vladimir
@vdorr
Hi, Are you using the amended code (Reply #2)?
Jim
