Simple Waveform generator with Arduino Due -DAC0 doesn't work
When I built the code in my Arduino Due with copying the code of
https://www.arduino.cc/en/Tutorial/DueSimpleWaveformGenerator
and change "t_sample" to "sample",
it worked to generate a waveform with the channle DAC1, but failed with the channel DAC0.
What is the problem? I have no idea to fix it.
  * connect two push buttons to the digital pins 2 and 3
    with a 10 kilohm pulldown resistor to choose the waveform
    to send to the DAC0 and DAC1 channels
  * connect a 10 kilohm potentiometer to A0 to control the
    signal frequency
#include "Waveforms.h"
#define oneHzSample 1000000/maxSamplesNum  // sample for the 1Hz signal expressed in microseconds
const int button0 = 2, button1 = 3;
volatile int wave0 = 0, wave1 = 0;
int i = 0;
int sample;
  analogWriteResolution(12);  // set the analog output resolution to 12 bit (4096 levels)
  analogReadResolution(12);   // set the analog input resolution to 12 bit
  attachInterrupt(button0, wave0Select, RISING);  // Interrupt attached to the button connected to pin 2
  attachInterrupt(button1, wave1Select, RISING);  // Interrupt attached to the button connected to pin 3
  // Read the the potentiometer and map the value  between the maximum and the minimum sample available
  // 1 Hz is the minimum freq for the complete wave
  // 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
  sample = map(analogRead(A0), 0, 4095, 0, oneHzSample);
  sample = constrain(sample, 0, oneHzSample);
  analogWrite(DAC0, waveformsTable[wave0][i]);  // write the selected waveform on DAC0
  analogWrite(DAC1, waveformsTable[wave1][i]);  // write the selected waveform on DAC1
  i++;
  if(i == maxSamplesNum)  // Reset the counter to repeat the wave
    i = 0;
  delayMicroseconds(sample);  // Hold the sample value for the sample time
// function hooked to the interrupt on digital pin 2
void wave0Select() {
  wave0++;
  if(wave0 == 4)
    wave0 = 0;
// function hooked to the interrupt on digital pin 3
void wave1Select() {
  wave1++;
  if(wave1 == 4)
    wave1 = 0;
#ifndef _Waveforms_h_
#define _Waveforms_h_
#define maxWaveform 4
#define maxSamplesNum 120
static int waveformsTable[maxWaveform][maxSamplesNum] = {
  // Sin wave
    0x7ff, 0x86a, 0x8d5, 0x93f, 0x9a9, 0xa11, 0xa78, 0xadd, 0xb40, 0xba1,
    0xbff, 0xc5a, 0xcb2, 0xd08, 0xd59, 0xda7, 0xdf1, 0xe36, 0xe77, 0xeb4,
    0xeec, 0xf1f, 0xf4d, 0xf77, 0xf9a, 0xfb9, 0xfd2, 0xfe5, 0xff3, 0xffc,
    0xfff, 0xffc, 0xff3, 0xfe5, 0xfd2, 0xfb9, 0xf9a, 0xf77, 0xf4d, 0xf1f,
    0xeec, 0xeb4, 0xe77, 0xe36, 0xdf1, 0xda7, 0xd59, 0xd08, 0xcb2, 0xc5a,
    0xbff, 0xba1, 0xb40, 0xadd, 0xa78, 0xa11, 0x9a9, 0x93f, 0x8d5, 0x86a,
    0x7ff, 0x794, 0x729, 0x6bf, 0x655, 0x5ed, 0x586, 0x521, 0x4be, 0x45d,
    0x3ff, 0x3a4, 0x34c, 0x2f6, 0x2a5, 0x257, 0x20d, 0x1c8, 0x187, 0x14a,
    0x112, 0xdf, 0xb1, 0x87, 0x64, 0x45, 0x2c, 0x19, 0xb, 0x2,
    0x0, 0x2, 0xb, 0x19, 0x2c, 0x45, 0x64, 0x87, 0xb1, 0xdf,
    0x112, 0x14a, 0x187, 0x1c8, 0x20d, 0x257, 0x2a5, 0x2f6, 0x34c, 0x3a4,
    0x3ff, 0x45d, 0x4be, 0x521, 0x586, 0x5ed, 0x655, 0x6bf, 0x729, 0x794
  // Triangular wave
    0x44, 0x88, 0xcc, 0x110, 0x154, 0x198, 0x1dc, 0x220, 0x264, 0x2a8,
    0x2ec, 0x330, 0x374, 0x3b8, 0x3fc, 0x440, 0x484, 0x4c8, 0x50c, 0x550,
    0x594, 0x5d8, 0x61c, 0x660, 0x6a4, 0x6e8, 0x72c, 0x770, 0x7b4, 0x7f8,
    0x83c, 0x880, 0x8c4, 0x908, 0x94c, 0x990, 0x9d4, 0xa18, 0xa5c, 0xaa0,
    0xae4, 0xb28, 0xb6c, 0xbb0, 0xbf4, 0xc38, 0xc7c, 0xcc0, 0xd04, 0xd48,
    0xd8c, 0xdd0, 0xe14, 0xe58, 0xe9c, 0xee0, 0xf24, 0xf68, 0xfac, 0xff0,
    0xfac, 0xf68, 0xf24, 0xee0, 0xe9c, 0xe58, 0xe14, 0xdd0, 0xd8c, 0xd48,
    0xd04, 0xcc0, 0xc7c, 0xc38, 0xbf4, 0xbb0, 0xb6c, 0xb28, 0xae4, 0xaa0,
    0xa5c, 0xa18, 0x9d4, 0x990, 0x94c, 0x908, 0x8c4, 0x880, 0x83c, 0x7f8,
    0x7b4, 0x770, 0x72c, 0x6e8, 0x6a4, 0x660, 0x61c, 0x5d8, 0x594, 0x550,
    0x50c, 0x4c8, 0x484, 0x440, 0x3fc, 0x3b8, 0x374, 0x330, 0x2ec, 0x2a8,
    0x264, 0x220, 0x1dc, 0x198, 0x154, 0x110, 0xcc, 0x88, 0x44, 0x0
  // Sawtooth wave
    0x22, 0x44, 0x66, 0x88, 0xaa, 0xcc, 0xee, 0x110, 0x132, 0x154,
    0x176, 0x198, 0x1ba, 0x1dc, 0x1fe, 0x220, 0x242, 0x264, 0x286, 0x2a8,
    0x2ca, 0x2ec, 0x30e, 0x330, 0x352, 0x374, 0x396, 0x3b8, 0x3da, 0x3fc,
    0x41e, 0x440, 0x462, 0x484, 0x4a6, 0x4c8, 0x4ea, 0x50c, 0x52e, 0x550,
    0x572, 0x594, 0x5b6, 0x5d8, 0x5fa, 0x61c, 0x63e, 0x660, 0x682, 0x6a4,
    0x6c6, 0x6e8, 0x70a, 0x72c, 0x74e, 0x770, 0x792, 0x7b4, 0x7d6, 0x7f8,
    0x81a, 0x83c, 0x85e, 0x880, 0x8a2, 0x8c4, 0x8e6, 0x908, 0x92a, 0x94c,
    0x96e, 0x990, 0x9b2, 0x9d4, 0x9f6, 0xa18, 0xa3a, 0xa5c, 0xa7e, 0xaa0,
    0xac2, 0xae4, 0xb06, 0xb28, 0xb4a, 0xb6c, 0xb8e, 0xbb0, 0xbd2, 0xbf4,
    0xc16, 0xc38, 0xc5a, 0xc7c, 0xc9e, 0xcc0, 0xce2, 0xd04, 0xd26, 0xd48,
    0xd6a, 0xd8c, 0xdae, 0xdd0, 0xdf2, 0xe14, 0xe36, 0xe58, 0xe7a, 0xe9c,
    0xebe, 0xee0, 0xf02, 0xf24, 0xf46, 0xf68, 0xf8a, 0xfac, 0xfce, 0xff0
  // Square wave
    0xfff, 0xfff, 0xfff, 0xfff, 0xfff, 0xfff, 0xfff, 0xfff, 0xfff, 0xfff,
    0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
#endif
Maybe your DAC0 is burned....
There is an easy test you can do with the code below. Always hook a resistor in serie with DAC0 and DAC1, at least 2KOhms, never connect directly a DAC to a speaker.
See Arduino DUE pin current output for DAC0 and DAC1:
  pinMode(DAC0, OUTPUT);
  pinMode(DAC1, OUTPUT);
  analogWrite(DAC0, 2048);
  analogWrite(DAC1, 2048);
The output voltage either on DAC0 or DAC1 should be close to 3.3V/2 = 1.65V.
Thank you for the answer...
There is no problem to light up two LEDs with the channel DAC0 and DAC1,
so I think DAC0 is OK.
Kent_Kimura:
Arduino Due DAC pins are known to be fragile, always use a series current limiting resistor with it, the
DAC pins do not tolerate short circuits and do not tolerate GND or Vdd as their output
range is not the full 0..3.3V. The datasheet is hopeless on the DAC section's electrical
characteristics, alas. It only mentions the output voltage range restriction once, in an
obscure place!
The only sensible thing to do with the DAC pins is feed them into opamp inputs in non-inverting mode. This will have been assumed implicitly by the chip designers as the only sensible thing you'd ever
do with them. They are designed for ac coupled audio, not general purpose DAC, I think.
They are also very poorly performing, much less than 12 bits effective, use an external SPI
DAC with the Due, much much better.
Post your code between code tags.
There should be a pinMode(button0, INPUT) and pinMode(buton1,INPUT) before attachInterrupt().
See the example code below to ouput a sin wave on both DACs:
/*   DAC0 and DAC1 output of a sin wave - Frequency of sin = 44.1 KHz / sinsize    */
const uint32_t sinsize  = 256 ;   // Size of buffer must be a power of 2
uint32_t sinus[2][sinsize];
volatile uint32_t bufn;
void dac_setup () {
  PMC->PMC_PCER1 = PMC_PCER1_PID38;     // DACC power ON
  DACC->DACC_CR = DACC_CR_SWRST ;       // Reset DACC
  DACC->DACC_MR = DACC_MR_TRGEN_EN                   // Hardware trigger select
                  | DACC_MR_TRGSEL(0b011)            // Trigger by TIOA2
                  | DACC_MR_TAG_EN                   // enable TAG to set channel in CDR
                  | DACC_MR_WORD_WORD                // write to both channels
                  | DACC_MR_REFRESH (1)
                  | DACC_MR_STARTUP_8
                  | DACC_MR_MAXS;
  DACC->DACC_IER |= DACC_IER_TXBUFE;                 // Interrupt used by PDC DMA
  DACC->DACC_ACR = DACC_ACR_IBCTLCH0(0b10)
                   | DACC_ACR_IBCTLCH1(0b10)
                   | DACC_ACR_IBCTLDACCORE(0b01);
  NVIC_EnableIRQ(DACC_IRQn);                         // Enable DACC interrupt
  DACC->DACC_CHER = DACC_CHER_CH0                    // enable channel 0 = DAC0
                    | DACC_CHER_CH1;                 // enable channel 1 = DAC1
  /*************   configure PDC/DMA  for DAC *******************/
  DACC->DACC_TPR  = (uint32_t)sinus[0];         // DMA buffer
  DACC->DACC_TCR  = sinsize;
  DACC->DACC_TNPR = (uint32_t)sinus[1];         // next DMA buffer (circular buffer)
  DACC->DACC_TNCR = sinsize;
  bufn = 1;
  DACC->DACC_PTCR = DACC_PTCR_TXTEN;            // Enable PDC Transmit channel request
void DACC_Handler() {
  uint32_t status = DACC->DACC_ISR;   // Read and save DAC status register
  if (status & DACC_ISR_TXBUFE) {     // move DMA pointer to next buffer
    bufn = (bufn + 1) & 1;
    DACC->DACC_TNPR = (uint32_t)sinus[bufn];
void tc_setup() {
  PMC->PMC_PCER0 |= PMC_PCER0_PID29;                      // TC2 power ON : Timer Counter 0 channel 2 IS TC2
  TC0->TC_CHANNEL[2].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK2  // MCK/8, clk on rising edge
                              | TC_CMR_WAVE               // Waveform mode
                              | TC_CMR_WAVSEL_UP_RC        // UP mode with automatic trigger on RC Compare
                              | TC_CMR_ACPA_CLEAR          // Clear TIOA2 on RA compare match
                              | TC_CMR_ACPC_SET;           // Set TIOA2 on RC compare match
  TC0->TC_CHANNEL[2].TC_RC = 238;  //<*********************  Frequency = (Mck/8)/TC_RC = 44.1 MHz
  TC0->TC_CHANNEL[2].TC_RA = 40;  //<********************   Any Duty cycle in between 1 and TC_RC
  TC0->TC_CHANNEL[2].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC2 counter and enable
  for(int i = 0; i < sinsize; i++)
   uint32_t chsel = (0<<12) | (1<<28);                      // LSB on DAC0, MSB DAC1 !!
   sinus[0][i]  = 2047*sin(i * 2 * PI/sinsize) + 2047;      //  0 < sinus [i] < 4096
   sinus[1][i] = sinus[0][i] |= sinus[0][i] <<16 | chsel;   // two buffers formated
                                                            // MSB [31:16]on channel 1
                                                            // LSB [15:0] on chanel 0
  tc_setup();
  dac_setup();
For full swing DACs (0V <-> 3.3V), you will have to add some hardware:
Thank you for the advice. :slight_smile:
However, I'm sorry to say it was failed to fix with adding "pinMode(button0, INPUT) and pinMode(buton1,INPUT)".
Kent_Kimura:
No, I'm talking about the pin used as a DAC, not as a digital GPIO pin.
You have to test it after using analogWrite() to the pin.
The Due pins have very much lower current ratings than the Uno, beware of this, many
can only handle 3mA, some can handle more, none can handle the "standard" LED current of 20mA,
so if testing with an LED use at least 1k series resistor unless you've checked the limit for that
particular pin.
DAC0 and DAC1 in DAC mode I'd limit with 2k resistor or more...
So you'd mean the internal IC chip for the DAC0 digital output and analog one have different circuit
and the analog one might be burned out.
I've buit ard_newbie's code and only a LED of DAC1 is lighted up but the one of DAC0 is not.
So it means your concern of the first answer is true.
I understand what you mean.
thank you, everyone.
I'll be more careful so as not to short cirdcuits.
