I am fairly new to micro-controllers and have only a short background in electrical theory and terminology. So please bear with me.
I have a pH sensor that connects to the rx and tx pins on the arduino. I am using pins 2 and 3
However, I would like to output an analog voltage that correlates to the sensors read values from one of the arduino pins. This will be so that the signal can be read by a separate board I prefer to use for my project that can only handle analog inputs.
I found an example on how to do the conversion, although it is using a single input pin_3 in this case. and converting that into an analog output pin_9. In my case I have both the rx and tx pins plugged into the Arduino communicating with the sensor and desire to output the analog signal say thu pin_9. How would I go about coding my "inPin". How does the coding need to be changed to incorporate the rx and tx values? Can I just simply use my rx pin as my "inpin" ?
I understand that analogwrite outputs a PWM wave but that is ok. The form I am following shows how to build a filter to turn it into a analog output.
I have pasted both the example code I intend to follow for the conversion and for the ph sensor itself below.
int pwmPin = 9; // output pin supporting PWM
int inPin = 3; // voltage connected to analog pin 3, e.g. a potentiometer
int val = 0; // variable to store the read value
float volt = 0; // variable to hold the voltage read
pinMode(pwmPin, OUTPUT); // sets the pin as output
val = analogRead(inPin); // read the input pin
volt =(5.0 * val) / 1023;
val = 255 * (volt / 5);
analogWrite(pwmPin, val);
pH sensor code I am working with:
#include <SoftwareSerial.h> //we have to include the SoftwareSerial library, or else we can't use it.
#define rx 2 //define what pin rx is going to be.
#define tx 3 //define what pin tx is going to be.
SoftwareSerial myserial(rx, tx); //define how the soft serial port is going to work.
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
float ph; //used to hold a floating point number that is the pH.
void setup() { //set up the hardware
Serial.begin(9600); //set baud rate for the hardware serial port_0 to 9600
myserial.begin(9600); //set baud rate for software serial port_3 to 9600
inputstring.reserve(10); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() { //if the hardware serial port_0 receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if (inchar == '\r') {
input_stringcomplete = true; //if the incoming character is a <CR>, set the flag
void loop() { //here we go...
if (input_stringcomplete) { //if a string from the PC has been received in its entirety
myserial.print(inputstring); //send that string to the Atlas Scientific product
inputstring = ""; //clear the string
input_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the PC
if (myserial.available() > 0) { //if we see that the Atlas Scientific product has sent a character.
char inchar = (char)myserial.read(); //get the char we just received
sensorstring += inchar;
sensor_stringcomplete = true; //if the incoming character is a <CR>, set the flag
if (sensor_stringcomplete) { //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(sensorstring); //send that string to the PC's serial monitor
ph = sensorstring.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
if (ph >= 7.0) { //if the pH is greater than or equal to 7.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
if (ph <= 6.999) { //if the pH is less than or equal to 6.999
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the pH as a number and not as a string
sensorstring = ""; //clear the string:
sensor_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
So just after you convert the sensorstring to a float, output that on an analog output.
Note that the Arduino's analogWrite() function does not produce a true analog output on most Arduinos. Depending on the next device, this may or may not work. You may need to add an analog filter to turn the PWM output back into true analog.
Ok, great I will give it a try. So if I understand correct, you are saying to analogRead(ph). With ph being my input signal? I'm just curious how that works, because hasn't that value already been converted from the bit level value to a value between 0-14 for the ph scale?
I'm going to plug it all in now and give it a whirl. Unfortunately I dont have an oscilloscope on hand to check the reading, but I do have a low pass filter built to finish the conversion from PWM to a true analog wave.
Well no, you would have to convert the 0-14.0 range to 0-255 which represents 0-5V output. You would need to know the volts-per-pH that the target device is expecting.
Ok, I see. Well unfortunately after attempting to follow your advice there still seems to be a problem. Here is the code I edited. Did I correctly do what you suggested? I have a low pass filter wired up and the schematic has been double checked, but I still seem to be getting a sine wave output voltage. I am using a 3.9K resistor and a 0.1uF capacitor.
//This code was written to be easy to understand.
//Code efficiency was not considered.
//Modify this code as you see fit.
//This code will output data to the Arduino serial monitor.
//Type commands into the Arduino serial monitor to control the pH circuit.
//This code was written in the Arduino 1.6.5 IDE
//An Arduino UNO was used to test this code.
int pwmPin=9; //output pin supporting PWM
int val=0; //variable to store the read value
float volt = 0; //variable to hold the voltage read
val = analogRead(ph); // read the input pin
volt=(5.0*val)/1023;
val=255*(volt/5);
analogWrite(pwmPin,val);
You just read pH from Serial. Why would you want to analogRead() a value too? In fact you've done worse than that because you're reading from pin number 7.5 (or whatever the floating point value is.)
Get the indentation right too. Use the auto-format tool to show you the right way. It is very good. If it appears to scramble your code then the code is wrong.
Ok, I understand. I was thinking I had to tell the controller to read analog, but I realize now that the function is for when you are plugging into an analog pin. My bad. I believe I modified what you suggested correctly this time, but I am still getting a sine wave output that does not change when the ph is varied.
int pwmPin = 9; //output pin supporting PWM
volt = (5.0 * ph) / 1023;
ph = 255 * (volt / 5);
analogWrite(pwmPin, ph);
