Hello everyone,
my current project involves different lights to create "scenes" based upon sound. I found this excellent DALI project and was able to rebuild it. On this gitpage is also a good cheatsheet for the commands.
My current setup is
I rewrote the code in the example to send commands directly in binary form in order to play around.
#include <Arduino.h>
#include <Dali.h>
#include<Logger.h>
bool DEBUGLOG = 1;
uint8_t MODE = 0;
uint8_t OK = 0;
#define BROADCAST_DP 0b11111110
#define BROADCAST_C 0b11111111
#define ON_DP 0b11111110
#define OFF_DP 0b00000000
#define ON_DP1 0b00111111
#define ON_DP2 0b11010100
#define ON_DP3 0b11100001
#define ON_C 0b00000101
#define OFF_C 0b00000000
# define QUERY_STATUS 0b10010000
# define RESET 0b00100000
dali.setupTransmit(3);
dali.setupAnalogReceive(A7);
dali.busTest();
dali.msgMode = true;
Logger::log("--- Dali EXP ---");
bool scanByte(byte &result) {
bool byteArr[8];
bool ERR = 0;
bool scandone = 0;
while(Serial.available()) {
// byte _temp = Serial.read();
// Serial.print("-");Serial.print(_temp);Serial.print("-");
uint8_t _temp = Serial.read();
// Logger::log("-",_temp);
if(_temp==124) { // begin scan
for(int n=7;n>=0;n--) {
uint8_t temp = Serial.read();
if(temp==49) {
byteArr[n] = 1;
} else if(temp==48) {
byteArr[n] = 0;
ERR = 1;
scandone=1;
// else if(_temp==88) {
// MODE=0;
// Serial.println("X");
// return false;
if(scandone) {
if(Serial.read()==124) { // end scan
result = 0;
for(int i=0;i<8;i++) {
if(byteArr[i]) {
result = result | (1<<i);
if(ERR) {
return false;
return true;
return false;
bool dimmer = false;
uint8_t dimlevel = 0b00000101;
String comMsg;
if(MODE==0) {
comMsg = comMsg + (char)(Serial.read());
if(comMsg == "C") {
MODE = 1;
Serial.print("C");
comMsg = "";
if(comMsg == "X") {
MODE = 0;
Serial.print("X");
if(comMsg == "ini") {
Serial.println(comMsg);
dali.initialisation();
if(comMsg == "scan") {
dali.scanShortAdd();
if(comMsg == "response") {
bool res = dali.getResponse;
Logger::log("Response: ");
Serial.println(res);
if(comMsg == "help") {
Logger::log("help");
if(comMsg== "on") {
dali.transmit(BROADCAST_C, ON_C);
if (comMsg == "off") {
dali.transmit(BROADCAST_C, OFF_C);
if (comMsg == "dimoff") {
dimlevel = 0;
dimmer = false;
Serial.print("OFF: dim = "); Serial.println(dimlevel);
dali.transmit(BROADCAST_DP,OFF_DP);
} else if(comMsg == "dim1") {
dali.transmit(BROADCAST_DP,ON_DP1);
} else if(comMsg == "dim2") {
dali.transmit(BROADCAST_DP,ON_DP2);
} else if(comMsg == "dim3") {
dali.transmit(BROADCAST_DP,ON_DP3);
} else if(comMsg == "dim4") {
dali.transmit(BROADCAST_DP,ON_DP);
} else if(comMsg == "dimon") {
dimlevel = 10;
dimmer = true;
Serial.print("ON: dim = "); Serial.println(dimlevel);
dali.transmit(BROADCAST_DP,dimlevel);
} else if(comMsg == "up" && dimmer) {
dimlevel += 5;
Serial.print("dim = "); Serial.println(dimlevel);
} else if(comMsg == "down" && dimmer) {
dimlevel -= 5;
if(MODE==1) {
if(Serial.available()) {
byte result,result1;
OK = scanByte(result);
OK &= scanByte(result1);
if(OK) {
Serial.print(result,BIN); Serial.print(" "); Serial.println(result1,BIN);
// Logger::log("result = ",result,BIN);
// Logger::log("result1 = ",result1,BIN);
dali.transmit(result,result1);
uint8_t resp = dali.receive();
Serial.print("Respons: "); Serial.print(resp); Serial.print(" "); Serial.println(resp,BIN);
Serial.flush();
delay(250);
With the serial input I can "scan", "ini" and "dimon\dimoff". The basic commands work. With the Serial input "C" it is possible to go into command-mode. Then the commands can be sent directly using following style
|YAAAAAAS||xxxxxxxx|
I bought two DALI drivers from skydance. Every channel should have its own address. Unfortunately I can not detect every single channel, but only get one address per driver. I would like to control each channel individually.
Here is the output of the short addresses after startup and using "scan"
--- Dali EXP ---
Short addresses:
BIN: 0 DEC: 0 HEX: 0 Get response
BIN: 1 DEC: 1 HEX: 1 No response
BIN: 10 DEC: 2 HEX: 2 No response
BIN: 11 DEC: 3 HEX: 3 No response
BIN: 100 DEC: 4 HEX: 4 No response
BIN: 101 DEC: 5 HEX: 5 No response
BIN: 110 DEC: 6 HEX: 6 No response
BIN: 111 DEC: 7 HEX: 7 No response
BIN: 1000 DEC: 8 HEX: 8 No response
BIN: 1001 DEC: 9 HEX: 9 No response
BIN: 1010 DEC: 10 HEX: A No response
BIN: 1011 DEC: 11 HEX: B No response
BIN: 1100 DEC: 12 HEX: C No response
BIN: 1101 DEC: 13 HEX: D No response
BIN: 1110 DEC: 14 HEX: E No response
BIN: 1111 DEC: 15 HEX: F No response
BIN: 10000 DEC: 16 HEX: 10 No response
BIN: 10001 DEC: 17 HEX: 11 No response
BIN: 10010 DEC: 18 HEX: 12 No response
BIN: 10011 DEC: 19 HEX: 13 No response
BIN: 10100 DEC: 20 HEX: 14 No response
BIN: 10101 DEC: 21 HEX: 15 No response
BIN: 10110 DEC: 22 HEX: 16 No response
BIN: 10111 DEC: 23 HEX: 17 No response
BIN: 11000 DEC: 24 HEX: 18 No response
BIN: 11001 DEC: 25 HEX: 19 No response
BIN: 11010 DEC: 26 HEX: 1A No response
BIN: 11011 DEC: 27 HEX: 1B No response
BIN: 11100 DEC: 28 HEX: 1C No response
BIN: 11101 DEC: 29 HEX: 1D No response
BIN: 11110 DEC: 30 HEX: 1E No response
BIN: 11111 DEC: 31 HEX: 1F No response
BIN: 100000 DEC: 32 HEX: 20 No response
BIN: 100001 DEC: 33 HEX: 21 No response
BIN: 100010 DEC: 34 HEX: 22 No response
BIN: 100011 DEC: 35 HEX: 23 No response
BIN: 100100 DEC: 36 HEX: 24 No response
BIN: 100101 DEC: 37 HEX: 25 No response
BIN: 100110 DEC: 38 HEX: 26 No response
BIN: 100111 DEC: 39 HEX: 27 No response
BIN: 101000 DEC: 40 HEX: 28 No response
BIN: 101001 DEC: 41 HEX: 29 No response
BIN: 101010 DEC: 42 HEX: 2A No response
BIN: 101011 DEC: 43 HEX: 2B No response
BIN: 101100 DEC: 44 HEX: 2C No response
BIN: 101101 DEC: 45 HEX: 2D No response
BIN: 101110 DEC: 46 HEX: 2E No response
BIN: 101111 DEC: 47 HEX: 2F No response
BIN: 110000 DEC: 48 HEX: 30 No response
BIN: 110001 DEC: 49 HEX: 31 No response
BIN: 110010 DEC: 50 HEX: 32 No response
BIN: 110011 DEC: 51 HEX: 33 No response
BIN: 110100 DEC: 52 HEX: 34 No response
BIN: 110101 DEC: 53 HEX: 35 No response
BIN: 110110 DEC: 54 HEX: 36 No response
BIN: 110111 DEC: 55 HEX: 37 No response
BIN: 111000 DEC: 56 HEX: 38 No response
BIN: 111001 DEC: 57 HEX: 39 No response
BIN: 111010 DEC: 58 HEX: 3A No response
BIN: 111011 DEC: 59 HEX: 3B No response
BIN: 111100 DEC: 60 HEX: 3C No response
BIN: 111101 DEC: 61 HEX: 3D No response
BIN: 111110 DEC: 62 HEX: 3E No response
BIN: 111111 DEC: 63 HEX: 3F No response
I can directly send commands to the address "0" (e.g. |00000001||00011010| for lower light), but all the channels respond equally.
Is there a special way to initialize each channel? How can I separate the driver from its channels?
Dali.cpp (10.7 KB) Dali.h (3.5 KB) Logger.cpp (527 Bytes) Logger.h (296 Bytes)
