Using simple and single library for Dallas temp sensor....it only works on the single and not simple library. using other libraries I cannot get an address and suspect the dallas temperature probes have lost their address. It was working fine till a week ago now 4 of my probes behave this way. I cant figure this one out.
That's not possible - the address cannot be changed or lost.
So what did you change?
Is this wired on solderless breadboard(s)?
If so, they are prone to losing connections when disturbed...
We can't see you code, and we can't see your hardware setup - so neither can we!
Please post your code, your schematic (aka "circuit diagram"), and some good, clear photos of your setup.
// This works fine
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 13
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress insideThermometer;
- Setup function. Here we do the basics
void setup(void)
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// locate devices on the bus
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// Assign address manually. The addresses below will beed to be changed
// to valid device addresses on your bus. Device address can be retrieved
// by using either oneWire.search(deviceAddress) or individually via
// sensors.getAddress(deviceAddress, index)
// Note that you will need to use your specific address here
//insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
// Method 1:
// Search for devices on the bus and assign based on an index. Ideally,
// you would do this to initially discover addresses on the bus and then
// use those addresses and manually assign them (see above) once you know
// the devices on your bus (and assuming they don't change).
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
// method 2: search()
// search() looks for the next device. Returns 1 if a new address has been
// returned. A zero might mean that the bus is shorted, there are no devices,
// or you have already retrieved all of them. It might be a good idea to
// check the CRC to make sure you didn't get garbage. The order is
// deterministic. You will always get the same devices in the same order
// Must be called before search()
//oneWire.reset_search();
// assigns the first address found to insideThermometer
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
// method 1 - slower
//Serial.print("Temp C: ");
//Serial.print(sensors.getTempC(deviceAddress));
//Serial.print(" Temp F: ");
//Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
// method 2 - faster
float tempC = sensors.getTempC(deviceAddress);
if(tempC == DEVICE_DISCONNECTED_C)
Serial.println("Error: Could not read temperature data");
return;
Serial.print(tempC);
Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
- Main function. It will request the tempC from the sensors and display on Serial.
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// It responds almost immediately. Let's print out the data
printTemperature(insideThermometer); // Use a simple function to print out the data
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// This doesnt work same circuit
- The setup function. We only start the sensors here
void setup(void)
// Start up the library
sensors.begin();
- Main function, get and show the temperature
void loop(void)
//m1 call sensors.requestTemperatures() to issue a global temperature
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
float tempC = sensors.getTempCByIndex(0);
// Check if reading was successful
if(tempC != DEVICE_DISCONNECTED_C)
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(tempC);
Please put code in code tags(the <CODE/> button).
* The setup function. We only start the sensors here
void setup(void)
sensors.begin();
* Main function, get and show the temperature
void loop(void)
// this works fine same circuit
* Setup function. Here we do the basics
void setup(void)
sensors.begin();
// Method 1:
return;
* Main function. It will request the tempC from the sensors and display on Serial.
void loop(void)
nothing has changed, working fine in the cloud using iot then nothing. and cant get majority of the dallas libraries to work. tried other probes and even a nano as well as other wroom boards. got me stumped when it works in the (single library sketch).
Thank you for the revised posts.
Thanks for the code.
Now for the schematic and photos ... ?
1. Connect only one DS18B20 temperature sensor with UNO as per Fig-1.
Figure-1:
2. Upload the following sketch and check that you have got the 8-byte address/ROM Code of the device on the Serial Monitor.
#include<OneWire.h>
OneWire ds(4);
byte addr[8]; //to ho;d 8-byte address/ROM code of sensor
ds.reset();
ds.search(addr); //collect 64-bit ROM code from sensor (DS)
for (int i = 0; i < 8; i++)
byte y = addr[i];
if (y < 0x10)
Serial.print('0'); /forcing to print leading zero
Serial.print(addr[i], HEX); //shows 8-byte address/ROM code
void loop() {}
If you have one faulty in the bus the others won’t read , if one gets wet ( eg the water proof ones !!) the bus won’t work .
There is a library example for reading multiple sensors with the Dallas library.
I would use 4k7 rather than 2k2 on your bus and if that works good , if not try lower values . Test individually as per prev post
Contradicting comments:
Is Onewire connected to pin 2 or pin 13?
It is not recomended to use pin 13 on Uno/Nano because it occupied with board LED and can works incorrectly in some cases
Actually, that line shows just one byte from the 8-byte Address/ROM code.
The i starts from 0 and ends at 7; so, 8-byte appears on the screen.
Yes, but that line only prints a single byte - which is not what the comment says!
That line would loop for eight times; so, eight bytes will appear on the Serial Monitor.
Pin 5 , pin 13 neither work I get "0000000000000000"
hey thanks
Does it work for DPin-4?
If you are using the Dallas library ( as you are ) , there is working example codes for single and multiple temp sensors .
If you google there are lots of examples for finding addresses of sensors based on the one wire library ( which might even have suitable examples ).
As said try sensors individually to see if they are separately ok. Record their addresses too .
Job done
