In the file path /Arduino 1.8.19 / lib / theme / syntax /
there is two themes "Default.xml" and "Dark.xml" but I cannot select "Dark" in the Arduino preferences.
The options I Googled so far is to download the Dark theme from Github but it is already installed.
I did rename "Default" to "Default1" and "Dark" to "Default" start Arduino ide , nothing to select in preferences and theme is still not Dark.
Hi @mikedb. I think that file was the result of someone starting on creating an official dark theme for the IDE, but they never actually followed through to finish the project.
However, the Arduino community has created several themes. Maybe one of those will be to your liking. I'll share the list of all the themes I know of:
If you decide you want to modify an existing theme, or make your own from scratch, you can find documentation of the theme system and a dummy library and sketch to facilitate testing here:
Installation
You have two options for installing themes to the sketchbook: direct installation or installation as "ZIP" files.
I'll provide instructions for both options below:
Direct installation
This installation option is best if you are going to use a single custom theme.
Select File > Preferences... (or Arduino > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Take note of the path shown in the "Sketchbook location" field in the "Preferences" dialog.
This is the path to your "sketchbook folder".
Click the "Cancel" button.
Select File > Quit (or Arduino > Quit Arduino for macOS users) from the Arduino IDE menus.
All Arduino IDE windows will close.
Open the sketchbook folder in your file manager.
If you are using Windows, this would be File Explorer.
Create a subfolder in your sketchbook folder named theme.
Put the theme directly into the theme folder you created.
This installation option is best if you want to switch between multiple custom themes, or if you are using a pre-made theme that supports this installation method.
The second option is to put the theme in a "ZIP" file, then put that in the theme subfolder of the sketchbook folder.
This is the location of your "sketchbook folder".
Put the theme "ZIP" file directly into the theme folder you created.
Start Arduino IDE.
Select the theme from the File > Preferences > Theme menu.
Start Arduino IDE.
The theme you selected from the menu will now be active.
The folder and "ZIP" file structure must look like this:
There is a sort of tricky thing about this installation option. The theme must be in the root of the "ZIP" file, NOT in a subfolder. Some "ZIP" utilities make that difficult or even impossible (especially the macOS one), but a Windows user won't have any difficulty:
Select all the files of the theme in Windows File Explorer.
Right click on the selected files.
Select Send to > Compressed (zipped) folder from the menu.
The awesome thing about this option is it allows you to have multiple themes installed (each in its own "ZIP" file). You can chose which one you prefer via the "Theme" menu of Arduino IDE's "Preferences" dialog. This menu will include the option to select the "Default theme", which is the one installed with the IDE.
Let's say you had two themes, one you wanted to show up in the Theme menu as "MyCoolTheme" and another you wanted to show up as "MyOtherCoolTheme", the folder structure should look like this:
For Arduino IDE 2.x, you install themes under a folder you create at the following path on your hard drive:
C:\Users\<username>\.arduinoIDE\plugins
However, that is only for additional themes you install. It appears you are using the built-in "Dark High Contrast" theme in Arduino IDE 2.x. The source of that theme is here:
A community member shared information on the Arduino IDE 2.x theme system here:
Way to complicated to start my own theme , I just edit the theme.
I tested a few themes and ended up with the "conrad91"theme.
I manage to change the back ground from grey to black and the comments from white to green.
Still need to make the green brighter and change the pinkish to Orange.
