Data acquisition system of measuring the temperature and atmospheric pressure.
I greet you all.
I must make a data acquisition system of measuring the temperature and atmospheric pressure.
I use this for data acquisition system, a sensor BMP080, a platform "Arduino Uno R3", a display LCD 1602 16X2 and the protocol of communications I2C.
Electronic layout is below.
I am interested how can measure this sensor BMP080 the temperature of around,the atmospheric pressure and the mode of transmission of data packets (data of the sensor BMP080) from equipment from other equipment,using communications interface I2C.
Thank you.
What did you find when you googled "BMP080 Arduino"?
Sending data TO other equipment makes sense. Getting BMP080 data FROM other equipment does not.
Google "arduino i2c lcd" to learn how to connect and use the display.
