I'm ussing the Data Logging Shield for Arduino. In my code, the data will be logged. This works, but I have a problem with the RTC. In my logged Data on the SD Card, I don't get the real time. I get only the real time in ste serial monitor.
The is the code:
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include "RTClib.h"
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
RTC_Millis rtc;
File dataFile;
const int audioPin = A0;
const int sensitivity = 450;
const int chipSelect = 10;
rtc.begin(DateTime(F(DATE), F(TIME)));
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(SS, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1) ;
Serial.println("card initialized.");
// Open up the file we're going to log to!
dataFile = SD.open("datalog.txt", FILE_WRITE);
if (! dataFile) {
Serial.println("error opening datalog.txt");
// Wait forever since we cant write data
while (1) ;
// make a string for assembling the data to log:
String dataString = "";
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
dataString += (now.year(), DEC);
Serial.print('/');
dataString = ('/');
Serial.print(now.month(), DEC);
dataString += (now.month(), DEC);
Serial.print('/');
dataString += ('/');
Serial.print(now.day(), DEC);
dataString += (now.day(), DEC);
Serial.print(' ');
dataString += (' ');
Serial.print(now.hour(), DEC);
dataString +=(now.hour(), DEC);
Serial.print(':');
dataString += (':');
Serial.print(now.minute(), DEC);
dataString += (now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
dataString += (now.second(), DEC);
int soundWave = analogRead(audioPin);
Serial.println(soundWave);
dataString += String(soundWave);
if (soundWave>sensitivity) {
Serial.println("Achtung!! Lärm!!");
dataString += ("Achtung!! Lärm!!");
delay(2000);
dataFile.println(dataString);
Serial.println(dataString);
dataFile.flush();
Maybe some can help me?
Thanks
code.txt (2.31 KB)
