Hey guys,
I've been doing sensor data logging for some time now and recently faced some unexpected troubles. I am using adafruits rtc data logging shield with uno.
Case 1: Code for case 1 below. Had no problems what so ever.
//LED.
int db1 = 3;
int db2 = 5;
//RTC.
#include "Wire.h"
#include <RTClib.h>
RTC_DS1307 RTC;
//RHT.
int SHT_clockPin = 7;
int SHT_dataPin = 4;
//SD.
const int chipSelect = 10; // Adafruit 10 - Arduino 4
#include <SPI.h>
#include <SD.h>
//S gen.
unsigned long starttime;
unsigned long sampletime_ms = 30000;
int S60 = 9;
float s60_avg = 0;
unsigned long S60_duration_1;
unsigned long S60_occupancy_1 = 0;
float S60_ratio_1 = 0;
float val[100];
int sample = 0;
Wire.begin();
RTC.begin();
pinMode(10, OUTPUT);
pinMode(S60,INPUT);
pinMode(db1, OUTPUT);
pinMode(db2, OUTPUT);
digitalWrite(db1, LOW);
digitalWrite(db2, LOW);
digitalWrite(db1, HIGH);
//if (! RTC.isrunning()) {
//RTC.adjust(DateTime(__DATE__, __TIME__));}
if (!SD.begin(chipSelect)) {
return;}
File dataFile = SD.open("data.txt", FILE_WRITE);
if (dataFile){
dataFile.close();}
s60_avg = 0;
sample = 0;
float time = millis();
while ((millis()-time) < 290000){
float arvo = getS60();
val[sample] = arvo;
sample++;}
for(int i=0; i<(sample+1); i++){
s60_avg = s60_avg + val[i];}
s60_avg = s60_avg / sample;
digitalWrite(db2, HIGH);
saveSD();
float getS60(){
starttime = millis();
while ((millis()-starttime) < sampletime_ms){
S60_duration_1 = pulseIn(S60, LOW);
S60_occupancy_1 = S60_occupancy_1 + S60_duration_1;}
S60_ratio_1 = S60_occupancy_1 / (sampletime_ms*10.0);
return S60_ratio_1;}
void saveSD(){
float temperature = getTemperature();
float humidity = getHumidity();
DateTime now = RTC.now();
if (dataFile){
dataFile.print(s60_avg);
dataFile.print("\t");
dataFile.print(humidity);
dataFile.print(temperature);
dataFile.print(now.month(), DEC);
dataFile.print('/');
dataFile.print(now.day(), DEC);
dataFile.print(now.year(), DEC);
dataFile.print(' ');
dataFile.print(now.hour(), DEC);
dataFile.print(':');
dataFile.print(now.minute(), DEC);
dataFile.println(now.second(), DEC);
dataFile.close();}
Serial.print(s60_avg);
Serial.print("\t");
Serial.print(humidity);
Serial.print("\t");
Serial.println(temperature);
float getTemperature(){
SHT_sendCommand(B00000011, SHT_dataPin, SHT_clockPin);
SHT_waitForResult(SHT_dataPin);
int val = SHT_getData(SHT_dataPin, SHT_clockPin);
SHT_skipCrc(SHT_dataPin, SHT_clockPin);
return (float)val * 0.01 - 40; //convert to celsius
float getHumidity(){
SHT_sendCommand(B00000101, SHT_dataPin, SHT_clockPin);
return -4.0 + 0.0405 * val + -0.0000028 * val * val;
Case 2: Code for case 2 below. Arduino had stalled data logging unexpectedly. It had logged for little over 2 days, then stopped. Everything else seemed ok otherwise. Also data was randomly missing dataFile.print("\t"); command. So the data looked like this:
4/13/2016 1:15:54 7.33 0.32 8.49 40.38 198.17
4/13/2016 1:31:126.89 0.14 8.35 40.41 203.83 <--- error
4/13/2016 1:36:19 6.67 0.27 8.26 40.73 203.50
I was thinking could this have something to do with the time that writing on SD card takes? Or maybe outdoor humidity/temperature change?Basically the difference in codes 1 and 2 is the order of logging sensor data and timestamp. Funny thing is that everything seems to work when I test them at my lab but when the real measurements start everything goes fubar. Also, never have I ever before had arduino fail to start data logging at all. Also I tried with different cards and boards I don't think thats the problem.
//RTC.
#include "Wire.h"
#include <RTClib.h>
#include "Adafruit_HTU21DF.h"
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
RTC_DS1307 RTC;
//SD.
#include <SPI.h>
#include <SD.h>
//RHT.
//Sgen.
//S60.
int S60 = 8;
float s60_avg = 0;
//S42.
int S42 = 9;
float s42_avg = 0;
unsigned long S42_duration_1;
unsigned long S42_occupancy_1 = 0;
float S42_ratio_1 = 0;
//Dp.
int dp_count = 30;
float dp_val[30];
float dp = 0;
float dpa = 0;
float paine = 0;
//Gen.
float val_S60[5];
float val_S42[5];
float temp = 0;
float hum = 0;
Wire.begin();
RTC.begin();
pinMode(10,OUTPUT);
pinMode(S60,INPUT);
pinMode(S42,INPUT);
if (!htu.begin()) {
Serial.println("Couldn't find HTU21D-F");
while (1);
return;}
if (dataFile){
dataFile.close();}
s60_avg = 0;
s42_avg = 0;
for(int i=0; i<5; i++){
val_S60[i] = getS60();
val_S42[i] = getS42();}
s60_avg = s60_avg + val_S60[i];
s42_avg = s42_avg + val_S42[i];}
s60_avg = s60_avg / 5;
s42_avg = s42_avg / 5;
temp = getTemperature();
hum = getHumidity();
paine = differentialPressure();
saveSD();
////////////FUNCTIONS////////////
float differentialPressure() {
dp = 0;
for(int i=0; i<dp_count; i++){
dp_val[i] = analogRead(A3);
delay(1);}
dp = dp + dp_val[i];}
dp = dp / dp_count;
return dp;}
float getS60(){
float getS42(){
S42_duration_1 = pulseIn(S42, LOW);
S42_occupancy_1 = S42_occupancy_1 + S42_duration_1;}
S42_ratio_1 = S42_occupancy_1 / (sampletime_ms*10.0);
return S42_ratio_1;}
void saveSD(){
if (dataFile){
dataFile.print(now.second(), DEC);
dataFile.print(s42_avg);
dataFile.print(temp);
dataFile.print(hum);
dataFile.println(paine);
dataFile.close();}
E: Had to take part of the code out for too long message.
