Data send html webpage and database with esp8266
i will need show the data in webpage(html) and store the database(xampp server ) using esp8266. but not show the data in web page and data base. can you help me. thank you
esp8266 code
//#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h> //esp 2.7.4 board manager
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <SPI.h>
//D6 = Rx & D5 = Tx
SoftwareSerial nodemcu(12, 14);
const char* ssid     = "redmi_9";
const char* password = "amila1234";
char server1[] = "192.168.43.116";  //my ip address amila pc
WiFiClient client;
WiFiServer server(80);
String header;
String pump1_State = "off";
String pump2_State = "off";
const int pump_1 = 0; //d3
const int pump_2 = 2; //d4
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
  nodemcu.begin(9600);
  while (!Serial) continue;
  pinMode(pump_1, OUTPUT);
  pinMode(pump_2, OUTPUT);
  digitalWrite(pump_1, LOW);
  digitalWrite(pump_2, LOW);
  // Connect to Wi-Fi network with SSID and password
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.print("IP address : ");
//  server.begin();
  //Firebase.begin (FIREBASE_HOST, FIREBASE_AUTH);
void loop(){
  int humidity1 = 15;//dht.readHumidity();
  int temperature1 = 22;//dht.readTemperature();
  int soilmoisture1 = 55;
  int humidity2 = 23;//dht.readHumidity();
  int temperature2 = 33;//dht.readTemperature();
  int soilmoisture2 = 43;
  StaticJsonBuffer<1000> jsonBuffer;
  JsonObject& data = jsonBuffer.parseObject(nodemcu);
  if (data == JsonObject::invalid()) {
    //Serial.println("Invalid Json Object");
    jsonBuffer.clear();
    return;
//  int ehum1 = data["humidity1"];
//  Serial.println(ehum1);
//  int etem1 = data["temperature1"];
//  Serial.println(etem1);
//  int esoil1 =data["soil1"];
//  Serial.println(esoil1);
// int ehum2 = data["humidity2"];
//  Serial.println(ehum2);
//  int etem2 = data["temperature2"];
//  Serial.println(etem2);
//  int esoil2 =data["soil2"];
//  Serial.println(esoil2);
  WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client");          // print a message out in the serial port
    String currentLine = "";
//    int hum1= 88; //dht.readHumidity();// make a String to hold incoming data from the client
//    int temp1 =33; // dht.readTemperature();
//    int soil1 = 444;
//    int hum2 = 99;
//    int temp2 = 22;
//    int soil2 = 555;
    previousTime = currentTime;
    while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the LEDs on and off
            if (header.indexOf("GET /1/on") >= 0) {
              Serial.println("LED 1 on");
              pump1_State = "on";
              digitalWrite(pump_1, HIGH);
            } else if (header.indexOf("GET /1/off") >= 0) {
              Serial.println("pump 1 off");
            } else if (header.indexOf("GET /2/on") >= 0) {
              Serial.println("pump 2 on");
              pump2_State = "on";
              digitalWrite(pump_2, HIGH);
            } else if (header.indexOf("GET /2/off") >= 0) {
              Serial.println("pump 2 off");
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".head { position: fixed; left: 0; top: 0; width: 100%; background-color: #34495e; font-size:35px; font-weight: bold; color: white; text-align: center; }");
            client.println(".footer { position: fixed; left: 0; bottom: 0; background-color: #ffff; width: 100%; color: white; text-align: center;}");
            client.println(".button { background-color: #1b33d1; border: none; color: #191b26; padding: 16px 40px; width: 150px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #e0b1bb; width: 150px;}");
            //client.println("thead { font-size: 35px;background-color: #33ABF4  ;border-style: solid;border-color: red;font-weight: bold;");
            //client.println("tbody { font-size: 35px;background-color: #33ABF4  ;border-style: solid;border-color: red;font-weight: bold;");
            client.println("table{ font-size: 30px;background-color: #49EFCE  ;border-style: solid;border-color: red;font-weight: bold;border-collapse: collapse;align:center;width: 100%;text-align: left;</style></head>");
            // Web Page Heading
            client.println("<div class=\"head\"> <p>Smart irrigation system</p> </div></br></br></br></br></br></br></br>");
             // client.println("<img src =\" https://en.wikipedia.org/wiki/File:Light_sensor.png "/>");
              client.println("<pre>");
              client.println("<table border =1>");
              client.println("<thead >");
              client.println("<tr>");//row 1 start
              client.println("<th colspan = 2 >");
              client.println("FIELD 1 DATA");
              client.println("</th>");
              client.println("FIELD 2 DATA");
              client.println("</tr>");
              client.println("</thead>");
              client.println("<tbody>");
              client.println("<td>");
              client.print("Humidity 1(%)     : ");
              client.println("</td>");
              client.println((int)humidity1);
              client.print("Humidity 2 (%)     : ");
              client.println((int)humidity2);
              client.println("</tr>");//row 2 end
              client.println("<tr>");//row 3 start
              client.print("Temperature 1 (°C) : ");
              client.println((int)temperature1);
              client.print("Temperature 2 (°C) : ");
              client.println((int)temperature2);
              client.println("</tr>");//row3 end
              client.print("Soil moisture 1 : ");
              client.println((int)soilmoisture1);
              client.print("Soil moisture 2    : ");
              client.println((int)soilmoisture2);
              client.println("</tbody>");
              client.println("</table>");
              client.println("</pre>");
            client.println("<h3>pump 1</h3>");
            // If the pump1_State is off, it displays the ON button
            if (pump1_State=="off") {
              client.println("<p><a href=\"/1/on\"><button class=\"button button2\">OFF</button></a></p>");
              client.println("<p><a href=\"/1/off\"><button class=\"button\">ON </button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 4
            client.println("<h3>pump 2</h3>");
            // If the pump2_State is off, it displays the ON button
            if (pump2_State=="off") {
              client.println("<p><a href=\"/2/on\"><button class=\"button button2\">OFF</button></a></p>");
              client.println("<p><a href=\"/2/off\"><button class=\"button \">ON </button></a></p>");
            client.println("</body></html>");
            client.println();
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
   if (client.connect(server1, 80)) {
    Serial.println("connected");
    client.print("GET /testcode/dht.php?humidity1=");     //YOUR URL
    client.print(humidity1);
    client.print("&temperature1=");
    client.print(temperature1);
    client.print("&soilmoisture1=");
    client.print(soilmoisture1);
    client.print("&humidity2=");
    client.print(humidity2);
    client.print("&temperature2=");
    client.print(temperature2);
    client.print("&soilmoisture2=");
    client.print(soilmoisture2);
    client.print(" ");      //SPACE BEFORE HTTP/1.1
    client.print("HTTP/1.1");
    client.println();
    client.println("Host: 192.168.43.116 ");
    client.println();
    Serial.println("connection failed");
thank you
Sounds like Schrödinger's data.
there is something fundamental wrong in your code.
In general, there is no need to care about HTTP headers on a esp8266.
If you have something like
in your ESP8266 code, you have started wrong.
Just use the right examples.
for the webserver: ESP8266Webserver | HelloServer
for a webclient: ESP8266HTTPClient | BasicHttpclient
I suggest you start new from scratch with the right webserver.
