Data send two arduino uno to esp8266 in webpage with nrf24l01 module
I have arduino uno and use esp8266 to send data to web page by nrf24l01. Data is received separately in the esp 8266 but is not visible in the web page. ..I need help.
transceiver code( arduino uno)
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <DHT.h>
const uint64_t pipes[2] = {0xE8E8F0F0E1LL,0xE8E8F0F0E2LL};//0xE8E8F0F0E1LL,0xE8E8F0F0E2LL
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
RF24 radio(7, 8); //  CN and CSN  pins of nrf
int sensorPin = A0; //soil moister pin
struct sensor {
  uint32_t hum; // humidity
  uint32_t tem; // tempereture
  uint32_t soil; // soil moisture
  uint32_t sensorNum;
sensor amila;
  dht.begin();
  radio.begin();
  //radio.setAutoAck(false);
  radio.setDataRate(RF24_250KBPS);
  radio.openWritingPipe(pipes[1]);
  //amila.sensorNum=1;
  amila.hum = 10;//dht.readHumidity();
  amila.tem =20;// dht.readTemperature();
  amila.soil =30;// analogRead(sensorPin);
  amila.sensorNum=1;
//  data1.h1 = 90;
//  data1.t1 = 30;
  if (isnan(amila.hum) || isnan(amila.tem)){
   Serial.println(F("Failed to read from DHT sensor!"));
   return;
  Serial.print("Humidity: ");
  Serial.print(amila.hum);
  Serial.println("Temperature: ");
  Serial.print(amila.tem);
  Serial.println("moisture");
  Serial.print(amila.soil);
  radio.write(&amila, sizeof(amila));
tranceiver 2 code  (arduino uno)
#include <SPI.h>
#include <RF24.h>
#include <DHT.h>
#define DHTPIN 4
struct sensor {
uint32_t sensorNum;
sensor hirusha;
dht.begin();
radio.begin();
// radio.setAutoAck(false);
hirusha.hum = 20;//dht.readHumidity();
hirusha.tem = 40;//dht.readTemperature();
hirusha.soil =60;// analogRead(sensorPin);
hirusha.sensorNum = 2;
// data1.h1 = 90;
// data1.t1 = 30;
if (isnan(hirusha.hum) || isnan(hirusha.tem)){
return;
Serial.print(hirusha.hum);
Serial.print(hirusha.tem);
Serial.println("moisture:");
Serial.print(hirusha.soil);
radio.write(&hirusha, sizeof(hirusha));
receiver esp8266  ( include  webpage )
/****** Edited by amila ****/
#include <SPI.h>
#include <RF24.h>
#include <ESP8266WiFi.h> //esp 2.7.4 board manager
int newhum;
int newtemp;
int newsoil;
int newhum2;
int newtemp2;
int newsoil2;
int hum1;
int temp1;
int hum2;
int temp2;
int soil1;
int soil2;
const char* ssid = "redmi_9";
const char* password = "amila1234";
WiFiServer server(80);
String header;
String pump1_State = "off";
String pump2_State = "off";
const int pump_1 = 0; //d3
const int pump_2 = 2; //d4
const uint64_t pipes[2] ={0xE8E8F0F0E1LL,0xE8E8F0F0E2LL};
RF24 radio(2, 15);
struct sensor {
uint32_t sensorNum;
sensor sensorData;
radio.begin();
radio.openReadingPipe(1, pipes[1]);
radio.openReadingPipe(2, pipes[2]);
radio.startListening();
pinMode(pump_1, OUTPUT);
pinMode(pump_2, OUTPUT);
digitalWrite(pump_1, LOW);
digitalWrite(pump_2, LOW);
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.print("IP address : ");
server.begin();
void loop(){
if ( radio.available() )
radio.read(&sensorData, sizeof(sensorData));
disp_sensor_data();
hum1 = newhum; //dht.readHumidity();// make a String to hold incoming data from the client
temp1 = newtemp; // dht.readTemperature();
soil1 = newsoil;
hum2 = newhum2;
 temp2 = newtemp2;
soil2 = newsoil2;
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
Serial.println("New Client"); // print a message out in the serial port
String currentLine = "";
currentTime = millis();
previousTime = currentTime;
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
  if (client.available()) {             // if there's bytes to read from the client,
    char c = client.read();             // read a byte, then
    Serial.write(c);                    // print it out the serial monitor
    header += c;
    if (c == '\n') {                    // if the byte is a newline character
      // if the current line is blank, you got two newline characters in a row.
      // that's the end of the client HTTP request, so send a response:
      if (currentLine.length() == 0) {
        // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
        // and a content-type so the client knows what's coming, then a blank line:
        client.println("Content-type:text/html");
        client.println("Connection: close");
        client.println();
        // turns the LEDs on and off
        if (header.indexOf("GET /1/on") >= 0) {
          Serial.println("LED 1 on");
          pump1_State = "on";
          digitalWrite(pump_1, HIGH);
        } else if (header.indexOf("GET /1/off") >= 0) {
          Serial.println("pump 1 off");
        } else if (header.indexOf("GET /2/on") >= 0) {
          Serial.println("pump 2 on");
          pump2_State = "on";
          digitalWrite(pump_2, HIGH);
        } else if (header.indexOf("GET /2/off") >= 0) {
          Serial.println("pump 2 off");
// Read the first line of the request
//float h = hh;
// Read temperature as Celsius (the default)
        // Display the HTML web page
        client.println("<!DOCTYPE html><html>");
        client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
        client.println("<link rel=\"icon\" href=\"data:,\">");
        client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
        client.println(".head { position: fixed; left: 0; top: 0; width: 100%; background-color: #34495e; font-size:35px; font-weight: bold; color: white; text-align: center; }");
        client.println(".footer { position: fixed; left: 0; bottom: 0; background-color: #ffff; width: 100%; color: white; text-align: center;}");
        client.println(".button { background-color: #1b33d1; border: none; color: #191b26; padding: 16px 40px; width: 150px;");
        client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
        client.println(".button2 {background-color: #e0b1bb; width: 150px;}");
        //client.println("thead { font-size: 35px;background-color: #33ABF4  ;border-style: solid;border-color: red;font-weight: bold;");
        //client.println("tbody { font-size: 35px;background-color: #33ABF4  ;border-style: solid;border-color: red;font-weight: bold;");
        client.println("table{ font-size: 30px;background-color: #49EFCE  ;border-style: solid;border-color: red;font-weight: bold;border-collapse: collapse;align:center;width: 100%;text-align: left;</style></head>");
        // Web Page Heading
        client.println("<div class=\"head\"> <p>Smart irrigation system</p> </div></br></br></br></br></br></br></br>");
         // client.println("<img src =\" https://en.wikipedia.org/wiki/File:Light_sensor.png "/>");
          client.println("<pre>");
          client.println("<table border =1>");
          client.println("<thead >");
          client.println("<tr>");//row 1 start
          client.println("<th colspan = 2 >");
          client.println("FIELD 1 DATA");
          client.println("</th>");
          client.println("FIELD 2 DATA");
          client.println("</tr>");
          client.println("</thead>");
          client.println("<tbody>");
          client.println("<td>");
          client.print("Humidity 1(%)     : ");
          client.println("</td>");
          client.println(hum1);
          client.print("Humidity 2 (%)     : ");
          client.println(hum2);
          client.println("</tr>");//row 2 end
          client.println("<tr>");//row 3 start
          client.print("Temperature 1 (°C) : ");
          client.println(temp1);
          client.print("Temperature 2 (°C) : ");
          client.println(temp2);
          client.println("</tr>");//row3 end
          client.print("Soil moisture 1 : ");
          client.println(soil1);
          client.print("Soil moisture 2    : ");
          client.println(soil2);
          client.println("</tbody>");
          client.println("</table>");
          client.println("</pre>");
Serial.print(newhum);
Serial.print(newhum2);
        client.println("<h3>pump 1</h3>");
        // If the pump1_State is off, it displays the ON button
        if (pump1_State=="off") {
          client.println("<p><a href=\"/1/on\"><button class=\"button button2\">OFF</button></a></p>");
          client.println("<p><a href=\"/1/off\"><button class=\"button\">ON </button></a></p>");
        // Display current state, and ON/OFF buttons for GPIO 4
        client.println("<h3>pump 2</h3>");
        // If the pump2_State is off, it displays the ON button
        if (pump2_State=="off") {
          client.println("<p><a href=\"/2/on\"><button class=\"button button2\">OFF</button></a></p>");
          client.println("<p><a href=\"/2/off\"><button class=\"button \">ON </button></a></p>");
        client.println("</body></html>");
        client.println();
        currentLine = "";
    } else if (c != '\r') {  // if you got anything else but a carriage return character,
      currentLine += c;      // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
void disp_sensor_data()
if(sensorData.sensorNum == 1)
newhum = sensorData.hum;
newtemp = sensorData.tem;
newsoil = sensorData.soil;
if(sensorData.sensorNum == 2)
newhum2 = sensorData.hum;
newtemp2 = sensorData.tem;
newsoil2 = sensorData.soil;
thanl you all..i need help
How do you know that the data is received, given no values are displayed on the web page?
Is a web page displayed at all (I'm asking because your HTML code contains errors)?
Edit your post and correct code tags!
