Datalogger with RTC, SD card and DHT22
I found this project on the website that works perfectly for what I need, but when I go to upload the code it shows an error in several lines of code, if anyone can help me solve the lines of the code that show an error and make the code work I would be grateful.
Here is the link to a video that shows the code working
 * Program to demonstrate Data Logging/Visualisation using Arduino
 * ###Connection with SD card module###
 * Vcc->5V
 * Gnd->Gnd
 * MISO->pin 12
 * MOSI->pin 11
 * SCK-> pin 13
 * CS-> pin 4
 * ###Connection with DS3231###
 * Vcc->5V
 * Gns->Gnd
 * SCL->pin A5
 * SDA-> pin A4
 * ###Connection with DT11###
 * Vcc->5V
 * Gnd->Gnd
 * Out-> pin 7
#include <DS3231.h> //Library for RTC module (Download from Link in article)
#include <SPI.h> //Library for SPI communication (Pre-Loaded into Arduino)
#include <SD.h> //Library for SD card (Pre-Loaded into Arduino)
#include <dht.h> //Library for dht11 Temperature and Humidity sensor (Download from Link in article)
#define DHT11_PIN 7 //Sensor output pin is connected to pin 7
dht DHT; //Sensor object named as DHT
const int chipSelect = 4; //SD card CS pin connected to pin 4 of Arduino
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
  // Setup Serial connection
  Initialize_SDcard();
  Initialize_RTC();
  Initialize_PlxDaq();
  Read_DHT11();
  Write_SDcard();
  Write_PlxDaq();
  delay(5000); //Wait for 5 seconds before writing the next data
void Write_PlxDaq()
    Serial.print("DATA"); //always write "DATA" to Indicate the following as Data
    Serial.print(","); //Move to next column using a ","
    Serial.print("DATE"); //Store date on Excel
    Serial.print("TIME"); //Store date on Excel
    Serial.print(DHT.temperature); //Store date on Excel
    Serial.print(DHT.humidity); //Store date on Excel
    Serial.println(); //End of Row move to next row
void Initialize_PlxDaq()
Serial.println("CLEARDATA"); //clears up any data left from previous projects
Serial.println("LABEL,Date,Time,Temperature,Humidity"); //always write LABEL, to indicate it as first line
void Write_SDcard()
    // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("LoggerCD.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.print(rtc.getDateStr()); //Store date on SD card
    dataFile.print(","); //Move to next column using a ","
    dataFile.print(rtc.getTimeStr()); //Store date on SD card
    dataFile.print(DHT.temperature); //Store date on SD card
    dataFile.print(DHT.humidity); //Store date on SD card
    dataFile.println(); //End of Row move to next row
    dataFile.close(); //Close the file
  Serial.println("OOPS!! SD card writing failed");
void Initialize_SDcard()
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  if (dataFile) {
    dataFile.println("Date,Time,Temperature,Humidity"); //Write the first row of the excel file
    dataFile.close();
void Initialize_RTC()
   // Initialize the rtc object
  rtc.begin();
//#### The following lines can be uncommented to set the date and time for the first time###
rtc.setDOW(FRIDAY);     // Set Day-of-Week to SUNDAY
rtc.setTime(18, 46, 45);     // Set the time to 12:00:00 (24hr format)
rtc.setDate(6, 30, 2017);   // Set the date to January 1st, 2014
void Read_DHT11()
int chk = DHT.read11(DHT11_PIN);
/*void Read_DateTime()
  // Send date
  Serial.print(rtc.getDateStr());
  Serial.print(" -- ");
  // Send time
  Serial.println(rtc.getTimeStr());
/*void Read_TempHum()
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
 // delay(1000);
Error
line 56: Compilation error: dht.h: No such file or directory
line 61: Compilation error: 'dht' does not name a type
line 67: Compilation error: no matching function for call to 'DS3231::DS3231(const uint8_t&, const uint8_t&)'
lines 119, 124, 160, 170, 234, 256: Compilation error: expected primary-expression before '.' token
You forgot to post these error messages.
I just posted the error messages
first it looks like you are missing the dht library - using Arduino IDE Library Manager (click Sketch>Include Library>Manage Libraries) instal dht
The DS3231 error is caused by using the wrong library. If I recall correctly, that constructor is used by the library from Rinky Dink Electronics.
I have the DHT library installed, that's the reason i don't understand that error
I already installed the library, but still don't work
Make sure you do not have multiple libraries with the same include file as the one you want, the compiler may be using the wrong library. Also if you are using Windows, the file system is not case-sensitive, so there is no way to distinguish the difference between dht.h and DHT.h
