Dataloging acceleration with an SD reader. SD card won't open and log properly
Hi guys
I'm running the 3.3V Arduino Pro 328 with a H3LIS331DL 400g accelerometer. I need to record the impact acceleration of a payload in a crash frame falling 10m. To log the data I'm using an Arduino SD Shield from LC Studio. My code is below. The SD card will initialise when I run the script, but it will not open the "log.txt" file and thus will not record an data. I have chekced the voltage accross the chips with a multimeter and have tried using an external 5V to run the SD shield solely. I have also checked the memory amount before the FILE_WRITE function. There is around 700 bytes and so should be sufficient. I have tried two different SD cards, both formatted to FAT32. Neither have worked everytime. About 1 run out of 5 or so the data will be logged. Can anyone find any problems in the code or suggestion any possible solutions?
Cheers
#include "SparkFun_LIS331.h"
#include <SPI.h>
#include <SD.h>
LIS331 xl;
unsigned long time;
//[2] = Accelerometer
//[1] = SD Shield
const int chipSelect = 10;
pinMode(9,OUTPUT); // CS_2 for SPI
pinMode(10, OUTPUT); // CS_1 for SPI
digitalWrite(9, HIGH); // Make CS_1 high
pinMode(11, OUTPUT); // MOSI for SPI
pinMode(12, INPUT); // MISO for SPI
pinMode(13, OUTPUT); // SCK for SPI
SPI.begin();
xl.setSPICSPin(9); // This MUST be called BEFORE .begin() so
// .begin() can communicate with the chip
xl.begin(LIS331::USE_SPI); // Selects the bus to be used and sets
// the power up bit on the accelerometer.
// Also zeroes out all accelerometer
// registers that are user writable.
xl.setODR(LIS331::DR_1000HZ);//Options:1000,400,100,50
xl.setFullScale(LIS331::HIGH_RANGE);//HIGH=400,MED=200,LOW=100
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
String dataString = " ";
digitalWrite(9,HIGH); //Make CS_2 HIGH
int16_t x, y, z;
xl.readAxes(x, y, z); // The readAxes() function transfers the
// current axis readings into the three
// parameter variables passed to it.
int xg = xl.convertToG(6,x);
//int xg = x;
int yg = xl.convertToG(6,y);
//int yg = y;
int zg = xl.convertToG(6,z);
//int zg = z;
dataString += String(xg);
dataString += ",";
dataString += String(yg);
dataString += ",";
dataString += String(zg);
digitalWrite(9,LOW);//Make CS_2 Low
digitalWrite(10,HIGH);//Make CS_1 High
File dataFile = SD.open("log", FILE_WRITE);
if (dataFile) {
// if the file didn't open, print an error:
Serial.println("error opening log.txt");
dataFile.println(dataString);
dataFile.close();
Serial.println(dataString);
Please post your code properly, using code tags.
Use of String variables is not recommended. They cause memory problems, and the Arduino to crash.
What other variable type would you use in this situation?
Edit your post, please.
Use C-strings (zero terminated character arrays).
