Hello everyone,
I am trying to use an accelerometer and register the datas on a SD card...but the initialization fails everytime.
May I ask for some help ?
The setup is:
Adafruit Feather M0 adalogger
Adafruit LIS3DH Triple-axis acceleromter
Philips 16gb microSD
Thank you for the help !
My code is probably wrong somewhere...but I can't find where.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
#include "RTClib.h"
#include "SdFat.h"
// I2C clock speed
#define I2C_SPEED 1000000
// Set range to 2G, 4G, 8G, 16G
#define ACCEL_RANGE LIS3DH_RANGE_8_G
// 5khz data rate
#define ACCEL_DATARATE LIS3DH_DATARATE_LOWPOWER_5KHZ
// Decimal precision for acceleration
#define ACCEL_PRECISION 3
// Separator character
#define SEP ","
#define DEBUG
#ifdef DEBUG
#define DEBUG_PRINT(x) Serial.print (x)
#define DEBUG_PRINTLN(x) Serial.println (x)
#else
#endif
// change this to match your SD shield or module;
// Adafruit SD shields and modules: pin 10
const int chipSelect = 4;
// Filename format: YYYYMMDDHHmm.csv
char filename[17];
unsigned long begin_us;
unsigned long begin_epoch;
unsigned long start_us;
unsigned long stop_us;
unsigned long counter = 0;
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
// set up variables using the SD utility library functions:
// File system object.
SdFat sd;
// Log file.
SdFile dataFile;
* Setup procedures.
#ifdef DEBUG
while (!Serial); // will pause Zero, Leonardo, etc until serial console opens
#endif
* Initialize the accelerometer.
DEBUG_PRINTLN("Initializing LIS3DH Sensor...");
if (! lis.begin(LIS3DH_DEFAULT_ADDRESS)) { // change this to 0x19 for alternative i2c address
DEBUG_PRINTLN("Couldnt start");
while (1);
// Set I2C high speedmode
Wire.setClock(I2C_SPEED);
lis.setRange(ACCEL_RANGE);
lis.setDataRate(ACCEL_DATARATE);
DEBUG_PRINTLN("LIS3DH initialized.");
* Initialize the SD card and log file.
DEBUG_PRINTLN("Initializing SD card...");
if (!sd.begin(chipSelect, SD_SCK_MHZ(50))) {
DEBUG_PRINTLN("Card failed, or not present");
// don't do anything more:
while (1);
DEBUG_PRINTLN("Card initialized.");
if (! dataFile.open(filename, O_CREAT | O_APPEND | O_WRITE)) {
DEBUG_PRINTLN("Could not open file...");
while (1);
// Write header row to file.
dataFile.println("timestamp (s), start (µs), accel x (G), accel y (G), accel z (G)");
dataFile.flush();
// Check to see if the file exists:
if (! sd.exists(filename)) {
DEBUG_PRINTLN("Log file doesn't exist.");
while (1);
DEBUG_PRINTLN("Ready!");
DEBUG_PRINTLN("timestamp (s), start (µs), delta (µs), accel x (G), accel y (G), accel z (G)");
* Main Loop
read_accel();
log_timers();
log_accel();
counter++;
if (counter >= 1000) {
write_sd();
counter = 0;
* Read from the accelerometer sensor and measure how long the op takes.
void read_accel() {
start_us = micros();
lis.read();
stop_us = micros();
* Output the timing info.
void log_timers() {
DEBUG_PRINT(begin_epoch + ((stop_us - begin_us) / 1000000));
DEBUG_PRINT(SEP);
DEBUG_PRINT(stop_us);
DEBUG_PRINT(SEP);
// Include time delta in debug output.
DEBUG_PRINT(stop_us - start_us);
DEBUG_PRINT(SEP);
// Write timestamp to file.
// Roughly equivalent to calling rtc.now().unixtime(), without 1ms latency.
dataFile.print(begin_epoch + ((stop_us - begin_us) / 1000000));
dataFile.print(SEP);
// Write timers to file.
dataFile.print(stop_us);
* Output the acceleration info.
void log_accel() {
#ifdef DEBUG
Serial.print(lis.x_g, ACCEL_PRECISION);
Serial.print(SEP);
Serial.print(lis.y_g, ACCEL_PRECISION);
Serial.print(SEP);
Serial.print(lis.z_g, ACCEL_PRECISION);
#endif
// Write acceleration to file.
dataFile.print(lis.x_g, ACCEL_PRECISION);
dataFile.print(lis.y_g, ACCEL_PRECISION);
dataFile.print(lis.z_g, ACCEL_PRECISION);
// Write newline.
dataFile.println();
void write_sd() {
DEBUG_PRINTLN("Writing to SD card");
unsigned long pre_write = micros();
dataFile.flush();
DEBUG_PRINT("Write ops took: ");
DEBUG_PRINTLN(micros() - pre_write);
