DC Motor Change direction with push button l298
Hello,
Ihave a dc motor, which is meant to drive forward for 30s when pushing a push button. When this is finished and the button is pushed again, it is meant to drive the same time in the other direction.
I realised this by an l298 and with an if and else if. But the first rotation does not happen.
I gave the variable "ort" ehis is 0 in the setup. This means the starting plave, position 0. When the button is detected it is meant to dwitch to 1, so later it can drive to start position again.
I included the built in LED to look it the if-part works and the led shines for 30s but the motor does not start. In the next attempt the motor runs in the backwards direction, but never forwards.
Sorry, but I cant upload data, here is my Code:
int taster=2;
int tasterstatus=0;
int ort = 0;
int ena = 9;
int in1 = 8;
int in2 = 7;
  pinMode(taster, INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(ena, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  digitalWrite(ena, 255);
  tasterstatus=digitalRead(taster);
  if (tasterstatus == HIGH){
    if (ort == 0) {
      ort ++;
      digitalWrite(LED_BUILTIN, HIGH);
      digitalWrite(in1, HIGH);
      digitalWrite(in2, LOW);
      delay(30000);
      digitalWrite(LED_BUILTIN, LOW);
      digitalWrite(in1, LOW);
    else if (ort == 1){
      ort --;
      digitalWrite(in2, HIGH);
      delay(30000);
digitalWrite() needs HIGH or LOW, not a number
What data did you want to upload?
Hello plunderstueck
The IDE provides a lot of examples to get started.
To prevent the ussage of the delay function the BLINKWITHOUTDELAY example is good start with design of a time keeper. To read and take action on buttons the State Change Detection example can be used too.
Take a view.
Дайте миру шанс!
p.s. I love Plunderstücke for breakfast.
Thank you!
But I do not think that this is the problem here because it works in the forward direction, but I will set it to HIGH.
referring to the upload I thought about my circuit diagram.
Thank you for the answer, so you suggest the delay function as the reason why the motor does not run in both directions?
No, I agree it is not the problem, but it is incorrect, so I thought I should tell you.
I think that is what we need to see, because I can't see a reason why your code would cause the problem you described.
Yes, you are right.
I dismantled everything and reassembled it and now it works.
Thank you guys anyways, I think I will close this here.
