Dc motor identification help
Help with working out what the motor is and wiring information.
Or away to work out which wire does what.
Red green yellow black blue white.
It may be pwm encoder type?
I am new to arduino coding and understanding of coding.
If You can present the text on the label of the motor the chances to reply would be better.
Just the color of the cables is very unsafe to go for.
HI, @tobywil
Welcome to the forum.
Have you put the model and or manufacturer through Google.
It looks like from a partial model number to be a motor and gearbox.
Possibly with an encoder on the back.
Thanks... Tom.... :smiley: :+1: :coffee: :australia:
Yes, motor gearbox. The PCB and chips could suggest brushless.
What does the label on the gearbox say? And what is the 28 pin chip on the board?
Some motors are hard to identify as they look as though there is no information on them. If you catch them in the right light, some will carry very faint laser etched ID.
Looks like brushless motor with built-in driver.
Similar to this:
So I wonder what the red motor driver module supposed to do there...
I'd say the OP, not knowing about the motor, assumed he needed that controller.
Makes sense.. Hopefully OP arrived here before he tried with the driver all the possible wiring combinations.
That looks the same
Hi, @tobywil
I did a check with chatGPT and cross referenced and it agrees with the type that @kmin has linked to.
So that wiring table that they give would be a good start.
Thanks. Sorry late in nz. Wiring information? Could not see it. Downloaded data sheet
It was on the link I posted.
Remeber to share GND between arduino and 24V PSU.
Thanks you.
Bit slow.
Thanks all
Worked out thanks to you all.
Toby
