Can I use a DC motor with an arduino uno. without a sheild or a transistor and how?
NO
what else do I need?
hilaaa:
A transistor, resistor and diode at least.
See
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
if I don't have A transistor but I have Led and resistor?
hilaaa:
Then you are stuffed as to driving a motor. Note a diode is not an LED.
Depends on the motor rating (volts and amps). I ran a tiny dc motor on the arduino bus just as an experiment. It "worked" but other things became flakey because of commutator noise .
What you need is a power stage rated for the motor volts and amps and controlled by the Arduino. At the motor terminals you need an RC snubber and a diode to keep some sort of control of the noise which the commutator and motor armature inductance generate.
But the chances are very slim that the poster's motor is a <30mA stall current rated nanomotor.... I'd
vote for a 2 orders of magnitude mismatch at least.
you never gave us the specs of your motor.
I have DC 3-6v Gear Motor
That's likely to have a stall current in the 0.5 to 1.5A range if its smallish but not ultra small. Some
sort of motor shield or driver necessary.
