DC transducer signal protection
Hello all. This is my second arduino forum account.
I was having credential issues so I made another.
Anyway, I'm not really a "newb"
My current project is utilizing a DC amp transducer.
Supply voltage 15vdc output is 0-14vdc. The transducer data sheet shows that it can go 14v negative if reverse current is applied.
The equipment I'll be reading the amps from is a DC electric motor that can pull 150amps. I'm using a 300amp rated transducer as the data sheet shows the best linear output ramp as the transducer shows to knee pretty hard (assuming i use a 150 amp transducer)
Also for equipment longevity sake, i dont want to push a 150 amp transducer to its limits consistently. (electrohms HS300T01 is the transducer)
With electric motors having reverse voltage spikes, that would cause a revers amperage, yes?
My concern is a reverse amperage causing a reverse voltage in the signal and damaging the arduino. (analog input would potentially be significantly more than the tolerance. -?vdc to 5vdc)
My main question is:
What is the best option for keeping a clean positive signal?
Solutions I can think of:
  1. shottkey diode into voltage divider. (14v in 5v out)
    but then I would have to account for the voltage drop across the diode. Unless I used a duplicate circuit from the 15v to the AREF??
  2. some type of opAmp situation.
THANK YOU FOR YOUR TIME!!
Microprocessor inputs have protection diodes for both negative voltage inputs, and positive voltages higher than Vdd (supply voltage), but the diodes cannot tolerate more than about 1 mA of current.
A 15K resistor in series with the input should provide adequate protection from swings of -15 to 15V, but of course if the input is analog, you can't measure a voltage higher than Vdd (or the chosen analog reference voltage), so a voltage divider is probably required. That will offer additional protection if designed correctly.
A 100 nF capacitor from input to ground will help with spikes.
Excuse me for butting in here, but the specs and the wiring diagram both show the power is + and - 15 volts. Where are you getting the other 15 volts from?
That is against forum rules!
@horkus_flux ,
Please see the message I have sent you, you are not allowed multiple accounts.
Please log in using your other account and continue with this topic from that account.
Thank you.
@pert ,
Are you able to transfer ownership of this topic to the OP's original account please?
Thank you.
