I'm programming for arduino for quite a while now and since there's not that much information about the DCF77 Signal from Mainflingen, Germany, I thought I open a topic for it.
I've wrote a decoder for the signal wich works perfect (at least, for me ;))
I'm from holland, so excuse me for my translation work ![]()
attachInterrupt(0, DCF, CHANGE);
void DCF()
static volatile unsigned long timeLastRun;
volatile unsigned long timeDifference;
static volatile byte bitNr, check;
static volatile byte minuteSecondary, minutePrimary, ourSecondary, ourPrimary;
volatile boolean value;
volatile byte temp, temp2;
timeDifference = millis() - timeLastRun;
timeLastRun = millis();
if(timeDifference > 40){ //ivm af en toe een timeDifference van 0...
//Signal Decoder:
if (timeDifference < 160){
value = false;
check++;
} else if (timeDifference < 270){ //a 0 has a duration of 100ms and a 1 200ms
value = true;
check++;
} else if (timeDifference < 1200){
bitNr++;
check = 0;
} else{ //marker end of minute
bitNr = 0;
check = 0;
//Start decoding signal:
if(bitNr >= 21 && bitNr <= 35 && check == 1){ //bitnumbers in wich to operate to extract time
//minute second digit:
if(bitNr <= 24){
minuteSecondary >>= 1;
if(value) minuteSecondary |= 0x80;
//minute first digit:
} else if(bitNr <= 27){
minutePrimary >>= 1;
if(value) minutePrimary |= 0x80;
//Parity bit:
} else if(bitNr == 28){
//Put the values gotten into the right place
minuteSecondary >>= 4;
minutePrimary >>= 5;
temp = minuteSecondary ^ minutePrimary;
temp2 = 0;
//count the amount of 1's:
for(int i=0; i<8; i++){
if(bitRead(temp, i)) temp2++;
//and add the parity bit:
if(value) temp2++;
if(temp2 % 2 == 0){
//the DCF77 signal was probably good, unless there were 2 or more failures
Serial.print("Minutes: ");
Serial.println(minutePrimary*10 + minuteSecondary);
//our second digit:
} else if(bitNr <= 32){
ourSecondary >>= 1;
if(value) ourSecondary |= 0x80;
//our primary digit:
} else if(bitNr <= 34){
ourPrimary >>= 1;
if(value) ourPrimary |= 0x80;
//Parity bit:
} else if(bitNr == 35){
ourSecondary >>= 4;
ourPrimary >>= 6;
temp = ourPrimary ^ ourSecondary;
temp2 = 0;
if(value) temp2++;
if(temp2 % 2 == 0){
Serial.print("Our: ");
Serial.println(ourPrimary*10+ourSecondary);
DCF77 spits out the LSB first, MSB last.
This code is also easially adaptable to get the current date
Hope I've helped some of you guys! If some want to have a library, I don't exactly know how to build one, though it should be not that hard ![]()
