Yes i did. Just with the setup part and empty loop. I obtained the message above in the serial monitor.
Here is my full code :
#include <SPI.h>
#include <SD.h>
#include <RTClib.h>
#include <Wire.h>
#include <AHTxx.h>
#include "DHT.h"
#include "arduinoFFT.h"
MASSE
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 8; //mcu > HX711 dout pin
const int HX711_sck = 7; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
const int chipSelect = 4;
File myFile;
RTC_DS1307 rtc;
//TEMP EXT
#define brocheDHText 6 // La ligne de communication du DHT22 sera donc branchée sur la pin D6 de l'Arduino
#define brocheDHT_posA 9
#define brocheDHT_posB 10
#define brocheDHT_posC 19
#define typeDeDHT DHT22 // Ici, le type de DHT utilisé est un DHT22 (que vous pouvez changer en DHT11, DHT21, ou autre, le cas échéant)
DHT dht_ext(brocheDHText, typeDeDHT);
DHT dht_intA(brocheDHT_posA, typeDeDHT);
DHT dht_intB(brocheDHT_posB, typeDeDHT);
DHT dht_intC(brocheDHT_posC, typeDeDHT);
//capteur son
arduinoFFT FFT = arduinoFFT(); /* Create FFT object */
#define CHANNEL A0
const uint16_t samples = 128; //This value MUST ALWAYS be a power of 2
const double samplingFrequency = 1212; //Hz, must be less than 10000 due to ADC
unsigned int sampling_period_us;
unsigned long microseconds;
double vReal[samples];
double vImag[samples];
#define SCL_INDEX 0x00
#define SCL_TIME 0x01
#define SCL_FREQUENCY 0x02
#define SCL_PLOT 0x03
#ifndef ESP8266
while (!Serial); // wait for serial port to connect. Needed for native USB
#endif
sampling_period_us = round(1000000 * (1.0 / samplingFrequency));
if (! rtc.begin()) {
Serial.println(F("Couldn't find RTC"));
Serial.flush();
while (1) delay(10);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running, let's set the time!");
// When time needs to be set on a new device, or after a power loss, the
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
Serial.println("ok");
dht_ext.begin();
dht_intA.begin();
dht_intB.begin();
dht_intC.begin();
//rtc.adjust(DateTime(2023, 5, 8, 22, 06, 0));
SD.begin()
//Serial.println(F("initialization done."));
myFile = SD.open("data.txt", FILE_WRITE);
if (myFile) {
Serial.println(F("File opened ok"));
myFile.println("Date,Time,Temperature_ruche_A (ºC),Humidity_ruche_A (%),Temperature_ruche_B (ºC),Humidity_ruche_B (%),Temperature_ruche_C (ºC),Humidity_ruche_C (%),Temperature_ext,Humidity_ext, Poids (kg), Frequence (Hz)");
myFile.close();
// if the file didn't open, print an error:
Serial.println(F("error opening data.txt"));
//rtc.adjust(DateTime(2023, 3, 8, 21, 33, 0));
/* rtc
void loggingTime() {
DateTime now = rtc.now();
if (myFile) {
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(',');
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(':');
myFile.print(now.second(), DEC);
myFile.print(",");
myFile.close();
/*temp
void loggingTemperature() {
float hum = dht_ext.readHumidity();
float temp = dht_ext.readTemperature();
float hum_A = dht_intA.readHumidity();
float temp_A = dht_intA.readTemperature();
float hum_B = dht_intB.readHumidity();
float temp_B = dht_intB.readTemperature();
float hum_C = dht_intC.readHumidity();
float temp_C = dht_intC.readTemperature();
if (myFile) {
myFile.print(temp_A);
myFile.print(",");
myFile.print(hum_A);
myFile.print(",");
myFile.print(temp_B);
myFile.print(",");
myFile.print(hum_B);
myFile.print(",");
myFile.print(temp_C);
myFile.print(",");
myFile.print(hum_C);
myFile.print(",");
myFile.print(temp);
myFile.print(",");
myFile.print(hum);
myFile.print(",");
myFile.close();
/*MASSE
void calibrate() {
Serial.println(F("***"));
Serial.println(F("Start calibration:"));
Serial.println(F("Place the load cell an a level stable surface."));
Serial.println(F("Remove any load applied to the load cell."));
Serial.println(F("Send 't' from serial monitor to set the tare offset."));
boolean _resume = false;
while (_resume == false) {
LoadCell.update();
if (Serial.available() > 0) {
char inByte = Serial.read();
if (inByte == 't') LoadCell.tareNoDelay();
if (LoadCell.getTareStatus() == true) {
Serial.println(F("Tare complete"));
_resume = true;
Serial.println(F("Now, place your known mass on the loadcell."));
Serial.println(F("Then send the weight of this mass (i.e. 100.0) from serial monitor."));
float known_mass = 0;
_resume = false;
LoadCell.update();
known_mass = Serial.parseFloat();
if (known_mass != 0) {
Serial.print(F("Known mass is: "));
Serial.println(known_mass);
_resume = true;
LoadCell.refreshDataSet(); //refresh the dataset to be sure that the known mass is measured correct
float newCalibrationValue = LoadCell.getNewCalibration(known_mass); //get the new calibration value
Serial.print(F("New calibration value has been set to: "));
Serial.print(newCalibrationValue);
Serial.println(F(", use this as calibration value (calFactor) in your project sketch."));
Serial.print(F("Save this value to EEPROM adress "));
Serial.print(calVal_eepromAdress);
Serial.println("? y/n");
_resume = false;
if (inByte == 'y') {
EEPROM.begin(512);
#endif
EEPROM.put(calVal_eepromAdress, newCalibrationValue);
EEPROM.commit();
#endif
EEPROM.get(calVal_eepromAdress, newCalibrationValue);
Serial.print(F("Value "));
Serial.print(F(" saved to EEPROM address: "));
Serial.println(calVal_eepromAdress);
_resume = true;
else if (inByte == 'n') {
Serial.println(F("Value not saved to EEPROM"));
_resume = true;
Serial.println("End calibration");
Serial.println(F("To re-calibrate, send 'r' from serial monitor."));
Serial.println(F("For manual edit of the calibration value, send 'c' from serial monitor."));
void changeSavedCalFactor() {
float oldCalibrationValue = LoadCell.getCalFactor();
Serial.print(F("Current value is: "));
Serial.println(oldCalibrationValue);
Serial.println(F("Now, send the new value from serial monitor, i.e. 696.0"));
float newCalibrationValue;
newCalibrationValue = Serial.parseFloat();
if (newCalibrationValue != 0) {
Serial.print(F("New calibration value is: "));
Serial.println(newCalibrationValue);
LoadCell.setCalFactor(newCalibrationValue);
_resume = true;
_resume = false;
EEPROM.begin(512);
#endif
EEPROM.commit();
#endif
_resume = true;
_resume = true;
Serial.println(F("End change calibration value"));
Serial.println("***");
void PrintVector(double *vData, uint16_t bufferSize, uint8_t scaleType)
for (uint16_t i = 0; i < bufferSize; i++)
double abscissa;
/* Print abscissa value */
switch (scaleType)
case SCL_INDEX:
abscissa = (i * 1.0);
case SCL_TIME:
abscissa = ((i * 1.0) / samplingFrequency);
case SCL_FREQUENCY:
abscissa = ((i * 1.0 * samplingFrequency) / samples);
/*loop
void frequency() {
microseconds = micros();
for (int i = 0; i < samples; i++)
vReal[i] = analogRead(CHANNEL);
vImag[i] = 0;
while (micros() - microseconds < sampling_period_us) {
//empty loop
microseconds += sampling_period_us;
/* Print the results of the sampling according to time */
PrintVector(vReal, samples, SCL_TIME);
FFT.Windowing(vReal, samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD); /* Weigh data */
FFT.Compute(vReal, vImag, samples, FFT_FORWARD); /* Compute FFT */
PrintVector(vReal, samples, SCL_INDEX);
PrintVector(vImag, samples, SCL_INDEX);
FFT.ComplexToMagnitude(vReal, vImag, samples); /* Compute magnitudes */
double x = FFT.MajorPeak(vReal, samples, samplingFrequency);
Serial.println(x, 6);
if (myFile) {
myFile.print(x, 6);
myFile.println(",");
myFile.close();
if (!SD.begin(chipSelect)) {
Serial.println(F("initialization failed!"));
return;
loggingTime();
//loggingTemperature();
frequency();
Serial.println("OK");
/*SAMPLING*/
//LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
