Debug others older posted project "Uncanny Eyes"
Greetings,
I'm am trying to get a great project of the "uncanny eyes" from 2018 Laurent Moll working.
His details are excellent however I'm having trouble getting this to work correctly . I had sent him a note about this however it may be due to the age of the project he may no longer looks at this project. My first ask is if this is an appropriate place to ask these type of questions as I cant seem to go any further. Apologies if I need to post this elsewhere. Not trying to cause any waves and just learn a few things. The code listed on the site was used and double checked to ensure nothing was missing etc. I believe that my wiring and sketches for both the main program ESP386 and the respective ESP386 nunchuck controller are correct. Tthe appropriate library changes have been made, My problem is that I cannot control the eye movement ( eye continues to move randomly)however I can change between the two eye types successfully.
Any and all help or direction appreciated
Saying that, the project is located at:
Halloween Skull Costume with Uncanny Eyes on ESP32 - Hackster.io.
Any help or direction is appreciated
If You extract code and schematics, and post it here, more helpers will take on Your question.
The code is contained in the original link however I have copied it here for easy reference.
The hardware uses 2 separate ESP386's ( main controller /nunchuck interface) connected together by one serial communication link at pin13 on both. The nunchuch handheld control (from a Nintendo Wii) connection is made using an adafruit nunchuck breakout board.board.
Below`` is the code for the controller:
// 2018 Modified by Laurent Moll for Uncanny Eyes costume
// https://www.hackster.io/projects/376a13/
// Based on Adafruit code  - Adafruit header below:
// Uncanny eyes for PJRC Teensy 3.1 with Adafruit 1.5" OLED (product #1431)
// or 1.44" TFT LCD (#2088).  This uses Teensy-3.1-specific features and
// WILL NOT work on normal Arduino or other boards!  Use 72 MHz (Optimized)
// board speed -- OLED does not work at 96 MHz.
// Adafruit invests time and resources providing this open source code,
// please support Adafruit and open-source hardware by purchasing products
// from Adafruit!
// Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
// MIT license.  SPI FIFO insight from Paul Stoffregen's ILI9341_t3 library.
// Inspired by David Boccabella's (Marcwolf) hybrid servo/OLED eye concept.
#include <SPI.h>
#include <Adafruit_GFX.h>      // Core graphics lib for Adafruit displays
#include <HardwareSerial.h>    // Needed for 2nd serial port on ESP32
// Slightly modified headers in the eye include files to be able to include 2 and switch between them
// The ESP32 has a lot of memory, so this works fine
#include "defaultEye.h"        // Standard human-ish hazel eye
#include "newtEye.h"           // Eye of newt
const uint16_t (*sclera)[SCLERA_WIDTH] = scleraDefault;
const uint8_t (*upper)[SCREEN_WIDTH] = upperDefault;
const uint8_t (*lower)[SCREEN_WIDTH] = lowerDefault;
const uint16_t (*polar)[80] = polarDefault;
const uint16_t (*iris)[IRIS_MAP_WIDTH] = irisDefault;
// DISPLAY HARDWARE CONFIG -------------------------------------------------
#include <Adafruit_SSD1351.h>  // OLED display library -OR-
typedef Adafruit_SSD1351 displayType; // Using OLED display(s)
#define DISPLAY_DC      2 // Data/command pin for BOTH displays
#define DISPLAY_RESET   4 // Reset pin for BOTH displays
#define SELECT_L_PIN    15 // LEFT eye chip select pin
#define SELECT_R_PIN    16 // RIGHT eye chip select pin
#define UART_RX_PIN     13 // Pin to receive UART commands from controller
// INPUT CONFIG (for eye motion -- enable or comment out as needed) --------
#define TRACKING          // If enabled, eyelid tracks pupil
#define IRIS_SMOOTH       // If enabled, filter input from IRIS_PIN
#define IRIS_MIN      150 // Clip lower analogRead() range from IRIS_PIN (WAS: 120) - Reduced range so that it doesn't look to odd with multiple eye pairs
#define IRIS_MAX      400 // Clip upper "                                (WAS: 720) - Reduced range so that it doesn't look to odd with multiple eye pairs
#define AUTOBLINK        // If enabled, eyes blink autonomously
// Probably don't need to edit any config below this line, -----------------
// unless building a single-eye project (pendant, etc.), in which case one
// of the two elements in the eye[] array further down can be commented out.
// Eye blinks are a tiny 3-state machine.  Per-eye allows winks + blinks.
#define NOBLINK 0     // Not currently engaged in a blink
#define ENBLINK 1     // Eyelid is currently closing
#define DEBLINK 2     // Eyelid is currently opening
typedef struct {
  uint8_t  state;     // NOBLINK/ENBLINK/DEBLINK
  uint32_t duration;  // Duration of blink state (micros)
  uint32_t startTime; // Time (micros) of last state change
} eyeBlink;
struct {
  displayType display; // OLED/TFT object
  uint8_t     cs;      // Chip select pin
  eyeBlink    blink;   // Current blink state
} eye[] = { // OK to comment out one of these for single-eye display:
  displayType(SELECT_L_PIN,DISPLAY_DC,0),SELECT_L_PIN,{NOBLINK},
  displayType(SELECT_R_PIN,DISPLAY_DC,0),SELECT_R_PIN,{NOBLINK},
#define NUM_EYES (sizeof(eye) / sizeof(eye[0]))
// INITIALIZATION -- runs once at startup ----------------------------------
HardwareSerial SerialIn(1);
void setup(void) {
  uint8_t e;
  Serial.begin(921600);
  SerialIn.begin(9600, SERIAL_8N1, UART_RX_PIN);
  randomSeed(analogRead(A3)); // Seed random() from floating analog input
  // Both displays share a common reset line; 0 is passed to display
  // constructor (so no reset in begin()) -- must reset manually here:
  pinMode(DISPLAY_RESET, OUTPUT);
  digitalWrite(DISPLAY_RESET, LOW);  delay(1);
  digitalWrite(DISPLAY_RESET, HIGH); delay(50);
  for(e=0; e<NUM_EYES; e++) { // Deselect all
    pinMode(eye[e].cs, OUTPUT);
    digitalWrite(eye[e].cs, HIGH);
    digitalWrite(eye[e].cs, LOW); // Select one eye for init
    eye[e].display.begin();
    digitalWrite(eye[e].cs, HIGH); // Deselect
  // One of the displays is configured to mirror on the X axis.  Simplifies
  // eyelid handling in the drawEye() function -- no need for distinct
  // L-to-R or R-to-L inner loops.  Just the X coordinate of the iris is
  // then reversed when drawing this eye, so they move the same.  Magic!
  eye[0].display.writeCommand(SSD1351_CMD_SETREMAP);
  eye[0
  ].display.writeData(0x76);
// EYE-RENDERING FUNCTION --------------------------------------------------9
SPISettings settings(16000000, MSBFIRST, SPI_MODE3); // 26.667MHz seems reliable on the ESP32.
void drawEye( // Renders one eye.  Inputs must be pre-clipped & valid.
  uint8_t  e,       // Eye array index; 0 or 1 for left/right
  uint32_t iScale,  // Scale factor for iris
  uint8_t  scleraX, // First pixel X offset into sclera image
  uint8_t  scleraY, // First pixel Y offset into sclera image
  uint8_t  uT,      // Upper eyelid threshold value
  uint8_t  lT) {    // Lower eyelid threshold value
  uint8_t  screenX, screenY, scleraXsave;
  int16_t  irisX, irisY;
  uint16_t p, a, burstIdx;
  uint32_t d;
  static uint16_t pBurst[SCREEN_WIDTH*SCREEN_HEIGHT]; // Full frame buffer possible on ESP32
  // Set up raw pixel dump to entire screen.  Although such writes can wrap
  // around automatically from end of rect back to beginning, the region is
  // reset on each frame here in case of an SPI glitch.
  scleraXsave = scleraX; // Save initial X value to reset on each line
  irisY       = scleraY - (SCLERA_HEIGHT - IRIS_HEIGHT) / 2;
  burstIdx = 0;
  for(screenY=0; screenY<SCREEN_HEIGHT; screenY++, scleraY++, irisY++) {
    scleraX = scleraXsave;
    irisX   = scleraXsave - (SCLERA_WIDTH - IRIS_WIDTH) / 2;
    for(screenX=0; screenX<SCREEN_WIDTH; screenX++, scleraX++, irisX++) {
      if((lower[screenY][screenX] <= lT) ||
         (upper[screenY][screenX] <= uT)) {             // Covered by eyelid
        p = 0;
      } else if((irisY < 0) || (irisY >= IRIS_HEIGHT) ||
                (irisX < 0) || (irisX >= IRIS_WIDTH)) { // In sclera
        p = sclera[scleraY][scleraX];
      } else {                                          // Maybe iris...
        p = polar[irisY][irisX];                        // Polar angle/dist
        d = (iScale * (p & 0x7F)) / 128;                // Distance (Y)
        if(d < IRIS_MAP_HEIGHT) {                       // Within iris area
          a = (IRIS_MAP_WIDTH * (p >> 7)) / 512;        // Angle (X)
          p = iris[d][a];                               // Pixel = iris
        } else {                                        // Not in iris
          p = sclera[scleraY][scleraX];                 // Pixel = sclera
      pBurst[burstIdx++] = p;
  SPI.beginTransaction(settings);
  eye[e].display.writeCommand(SSD1351_CMD_SETROW);    // Y range
  eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_HEIGHT - 1);
  eye[e].display.writeCommand(SSD1351_CMD_SETCOLUMN); // X range
  eye[e].display.writeData(0); eye[e].display.writeData(SCREEN_WIDTH  - 1);
  eye[e].display.writeCommand(SSD1351_CMD_WRITERAM);  // Begin write
  digitalWrite(eye[e].cs, LOW);                       // Chip select
  digitalWrite(DISPLAY_DC, HIGH);                     // Data mode
  // For ESP32, use writePixels function to transfer the whole framebuffer in one large burst
  SPI.writePixels((uint8_t*)pBurst, sizeof(pBurst));
  SPI.endTransaction();
// EYE ANIMATION -----------------------------------------------------------
const uint8_t ease[] = { // Ease in/out curve for eye movements 3*t^2-2*t^3
    0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,  1,  2,  2,  2,  3,   // T
    3,  3,  4,  4,  4,  5,  5,  6,  6,  7,  7,  8,  9,  9, 10, 10,   // h
   11, 12, 12, 13, 14, 15, 15, 16, 17, 18, 18, 19, 20, 21, 22, 23,   // x
   24, 25, 26, 27, 27, 28, 29, 30, 31, 33, 34, 35, 36, 37, 38, 39,   // 2
   40, 41, 42, 44, 45, 46, 47, 48, 50, 51, 52, 53, 54, 56, 57, 58,   // A
   60, 61, 62, 63, 65, 66, 67, 69, 70, 72, 73, 74, 76, 77, 78, 80,   // l
   81, 83, 84, 85, 87, 88, 90, 91, 93, 94, 96, 97, 98,100,101,103,   // e
  104,106,107,109,110,112,113,115,116,118,119,121,122,124,125,127,   // c
  128,130,131,133,134,136,137,139,140,142,143,145,146,148,149,151,   // J
  152,154,155,157,158,159,161,162,164,165,167,168,170,171,172,174,   // a
  175,177,178,179,181,182,183,185,186,188,189,190,192,193,194,195,   // c
  197,198,199,201,202,203,204,205,207,208,209,210,211,213,214,215,   // o
  216,217,218,219,220,221,222,224,225,226,227,228,228,229,230,231,   // b
  232,233,234,235,236,237,237,238,239,240,240,241,242,243,243,244,   // s
  245,245,246,246,247,248,248,249,249,250,250,251,251,251,252,252,   // o
  252,253,253,253,254,254,254,254,254,255,255,255,255,255,255,255 }; // n
#ifdef AUTOBLINK
uint32_t timeOfLastBlink = 0L, timeToNextBlink = 0L;
#endif
#define BCAST_ADDR 0
#define SER_CMD_SIZE 9
uint16_t serAddr = 1;
void frame( // Process motion for a single frame of left or right eye
  uint16_t        iScale) {     // Iris scale (0-1023) passed in
  static uint32_t frames   = 0; // Used in frame rate calculation
  static uint8_t  eyeIndex = 0; // eye[] array counter
  int16_t         eyeX, eyeY;
  uint32_t        t; // Time at start of function
  static char     serCmd[SER_CMD_SIZE+1];
  static uint16_t serCmdIdx = 0;
  static uint16_t serNewEyeCtrl = 0;
  static uint16_t serEyeCtrl = 0;
  // Process serial input
  // Command format: "#abxxxyyy_"
  // #: Address (0: bcast, other 1-6)
  // a: Eye position control
  //    O: Auto mode
  //    I: Controlled by xxxyyy
  // b: Eye type
  //    O: Default
  //    I: Newt
  // xxx: x position in zero-extended decimal   000-255
  // yyy: y position in zero-extended decimal 000-255
  // _: space character
  while (SerialIn.available()) {      // If anything comes in Serial,
    serCmd[serCmdIdx] = SerialIn.read();
    if (serCmd[serCmdIdx] == ' ') {
      serCmd[serCmdIdx] = '\0';
      //Serial.println(serCmd);
      if (serCmdIdx != SER_CMD_SIZE) {
        Serial.println("Error: Serial command too short.");
        if (serCmd[0] == '0' || serCmd[0] == '0' + serAddr) {
          if (serCmd[1] == 'I') {
            if (!isdigit(serCmd[3]) || !isdigit(serCmd[4]) || !isdigit(serCmd[5]) || !isdigit(serCmd[6]) || !isdigit(serCmd[7]) || !isdigit(serCmd[8])) {
              Serial.println("Error: Serial position not a number");
            } else { // If button is pressed, stop random eye movements and move (gracefully) to desired position
              serNewEyeCtrl = serEyeCtrl = 1;
              eyeX = 1020 - ((serCmd[3]-'0')*100 + (serCmd[4]-'0')*10 + (serCmd[5]-'0')) * 4;
              eyeY = ((serCmd[6]-'0')*100 + (serCmd[7]-'0')*10 + (serCmd[8]-'0')) * 4;
          } else if (serCmd[1] == 'O') {
            serNewEyeCtrl = serEyeCtrl = 0;
            Serial.println("Error: Serial command[1] unknown.");
          if (serCmd[2] == 'O') { // Switch eye type right away based on button
            sclera = scleraDefault;
            upper = upperDefault;
            lower = lowerDefault;
            polar = polarDefault;
            iris = irisDefault;
          } else if (serCmd[2] == 'I') {
            sclera = scleraNewt;
            upper = upperNewt;
            lower = lowerNewt;
            polar = polarNewt;
            iris = irisNewt;
            Serial.println("Error: Serial command[2] unknown.");
      serCmdIdx = 0;
      serCmdIdx++;
      if (serCmdIdx > SER_CMD_SIZE) {
        Serial.println("Error: Serial command too long.");
        serCmdIdx = 0;
  if(++eyeIndex >= NUM_EYES) eyeIndex = 0; // Cycle through eyes, 1 per call
  // X/Y movement
  t = micros();
  // Autonomous X/Y eye motion
  // Periodically initiates motion to a new random point, random speed,
  // holds there for random period until next motion.
  static boolean  eyeInMotion      = false;
  static int16_t  eyeOldX=512, eyeOldY=512, eyeCurX=512, eyeCurY=512, eyeNewX=512, eyeNewY=512;
  static uint32_t eyeMoveStartTime = 0L;
  static int32_t  eyeMoveDuration  = 0L;
  // Added to original code
  // If the controller sends a desired position, get out of random mode and move naturally to desired position
  if (serNewEyeCtrl) {
    eyeNewX = eyeX;
    eyeNewY = eyeY;
    eyeOldX = eyeCurX;                  // start from where we currently are
    eyeOldY = eyeCurY;
    eyeMoveDuration  = 100000;          // 100ms sec
    eyeMoveStartTime = t;               // Save initial time of move
    eyeInMotion      = true;            // Start move on next frame
    serNewEyeCtrl = 0;
  int32_t dt = t - eyeMoveStartTime;      // uS elapsed since last eye event
  if(eyeInMotion) {                       // Currently moving?
    if(dt >= eyeMoveDuration) {           // Time up?  Destination reached.
      if (serEyeCtrl) { // If serial controlled, we're done moving, but stay in motion
        eyeX = eyeOldX = eyeNewX;           // Save position
        eyeY = eyeOldY = eyeNewY;
        eyeInMotion      = false;           // Stop moving
        eyeMoveDuration  = random(3000000); // 0-3 sec stop
        eyeMoveStartTime = t;               // Save initial time of stop
    } else { // Move time's not yet fully elapsed -- interpolate position
      int16_t e = ease[255 * dt / eyeMoveDuration] + 1;   // Ease curve
      eyeX = eyeOldX + (((eyeNewX - eyeOldX) * e) / 256); // Interp X
      eyeY = eyeOldY + (((eyeNewY - eyeOldY) * e) / 256); // and Y
  } else {                                // Eye stopped
    eyeX = eyeOldX;
    eyeY = eyeOldY;
    if(dt > eyeMoveDuration) {            // Time up?  Begin new move.
      int16_t  dx, dy;
      uint32_t d;
      do {                                // Pick new dest in circle
        eyeNewX = random(1024);
        eyeNewY = random(1024);
        dx      = (eyeNewX * 2) - 1023;
        dy      = (eyeNewY * 2) - 1023;
      } while((d = (dx * dx + dy * dy)) > (1023 * 1023)); // Keep trying
      eyeMoveDuration  = random(72000, 144000); // ~1/14 - ~1/7 sec
  eyeCurX = eyeX;
  eyeCurY = eyeY;
  // Blinking
#ifdef AUTOBLINK
  // Similar to the autonomous eye movement above -- blink start times
  // and durations are random (within ranges).
  if((t - timeOfLastBlink) >= timeToNextBlink) { // Start new blink?
    timeOfLastBlink = t;
    uint32_t blinkDuration = random(36000, 72000); // ~1/28 - ~1/14 sec
    // Set up durations for both eyes (if not already winking)
    for(uint8_t e=0; e<NUM_EYES; e++) {
      if(eye[e].blink.state == NOBLINK) {
        eye[e].blink.state     = ENBLINK;
        eye[e].blink.startTime = t;
        eye[e].blink.duration  = blinkDuration;
    timeToNextBlink = blinkDuration * 3 + random(4000000);
#endif
  if(eye[eyeIndex].blink.state) { // Eye currently blinking?
    // Check if current blink state time has elapsed
    if((t - eye[eyeIndex].blink.startTime) >= eye[eyeIndex].blink.duration) {
      // No buttons, or other state...
        if(++eye[eyeIndex].blink.state > DEBLINK) { // Deblinking finished?
          eye[eyeIndex].blink.state = NOBLINK;      // No longer blinking
        } else { // Advancing from ENBLINK to DEBLINK mode
          eye[eyeIndex].blink.duration *= 2; // DEBLINK is 1/2 ENBLINK speed
          eye[eyeIndex].blink.startTime = t;
  // Process motion, blinking and iris scale into renderable values
  // Iris scaling: remap from 0-1023 input to iris map height pixel units
  iScale = ((IRIS_MAP_HEIGHT + 1) * 1024) /
           (1024 - (iScale * (IRIS_MAP_HEIGHT - 1) / IRIS_MAP_HEIGHT));
  // Scale eye X/Y positions (0-1023) to pixel units used by drawEye()
  eyeX = map(eyeX, 0, 1023, 0, SCLERA_WIDTH  - 128);
  eyeY = map(eyeY, 0, 1023, 0, SCLERA_HEIGHT - 128);
  if(eyeIndex == 1) eyeX = (SCLERA_WIDTH - 128) - eyeX; // Mirrored display
  // Horizontal position is offset so that eyes are very slightly crossed
  // to appear fixated (converged) at a conversational distance.  Number
  // here was extracted from my posterior and not mathematically based.
  // I suppose one could get all clever with a range sensor, but for now...
  eyeX += 4;
  if(eyeX > (SCLERA_WIDTH - 128)) eyeX = (SCLERA_WIDTH - 128);
  // Eyelids are rendered using a brightness threshold image.  This same
  // map can be used to simplify another problem: making the upper eyelid
  // track the pupil (eyes tend to open only as much as needed -- e.g. look
  // down and the upper eyelid drops).  Just sample a point in the upper
  // lid map slightly above the pupil to determine the rendering threshold.
  static uint8_t uThreshold = 128;
  uint8_t        lThreshold, n;
#ifdef TRACKING
  int16_t sampleX = SCLERA_WIDTH  / 2 - (eyeX / 2), // Reduce X influence
          sampleY = SCLERA_HEIGHT / 2 - (eyeY + IRIS_HEIGHT / 4);
  // Eyelid is slightly asymmetrical, so two readings are taken, averaged
  if(sampleY < 0) n = 0;
  else            n = (upper[sampleY][sampleX] +
                       upper[sampleY][SCREEN_WIDTH - 1 - sampleX]) / 2;
  uThreshold = (uThreshold * 3 + n) / 4; // Filter/soften motion
  // Lower eyelid doesn't track the same way, but seems to be pulled upward
  // by tension from the upper lid.
  lThreshold = 254 - uThreshold;
#else // No tracking -- eyelids full open unless blink modifies them
  uThreshold = lThreshold = 0;
#endif
  // The upper/lower thresholds are then scaled relative to the current
  // blink position so that blinks work together with pupil tracking.
    uint32_t s = (t - eye[eyeIndex].blink.startTime);
    if(s >= eye[eyeIndex].blink.duration) s = 255;   // At or past blink end
    else s = 255 * s / eye[eyeIndex].blink.duration; // Mid-blink
    s          = (eye[eyeIndex].blink.state == DEBLINK) ? 1 + s : 256 - s;
    n          = (uThreshold * s + 254 * (257 - s)) / 256;
    lThreshold = (lThreshold * s + 254 * (257 - s)) / 256;
    n          = uThreshold;
  // Pass all the derived values to the eye-rendering function:
  drawEye(eyeIndex, iScale, eyeX, eyeY, n, lThreshold);
// AUTONOMOUS IRIS SCALING (if no photocell or dial) -----------------------
// Autonomous iris motion uses a fractal behavior to similate both the major
// reaction of the eye plus the continuous smaller adjustments that occur.
uint16_t oldIris = (IRIS_MIN + IRIS_MAX) / 2, newIris;
void split( // Subdivides motion path into two sub-paths w/randimization
  int16_t  startValue, // Iris scale value (IRIS_MIN to IRIS_MAX) at start
  int16_t  endValue,   // Iris scale value at end
  uint32_t startTime,  // micros() at start
  int32_t  duration,   // Start-to-end time, in microseconds
  int16_t  range) {    // Allowable scale value variance when subdividing
  if(range >= 8) {     // Limit subdvision count, because recursion
    range    /= 2;     // Split range & time in half for subdivision,
    duration /= 2;     // then pick random center point within range:
    int16_t  midValue = (startValue + endValue - range) / 2 + random(range);
    uint32_t midTime  = startTime + duration;
    split(startValue, midValue, startTime, duration, range); // First half
    split(midValue  , endValue, midTime  , duration, range); // Second half
  } else {             // No more subdivisons, do iris motion...
    int32_t dt;        // Time (micros) since start of motion
    int16_t v;         // Interim value
    while((dt = (micros() - startTime)) < duration) {
      v = startValue + (((endValue - startValue) * dt) / duration);
      if(v < IRIS_MIN)      v = IRIS_MIN; // Clip just in case
      else if(v > IRIS_MAX) v = IRIS_MAX;
      frame(v);        // Draw frame w/interim iris scale value
// MAIN LOOP -- runs continuously after setup() ----------------------------
// Autonomous iris scaling -- invoke recursive function
  newIris = random(IRIS_MIN, IRIS_MAX);
  split(oldIris, newIris, micros(), 10000000L, IRIS_MAX - IRIS_MIN);
  oldIris = newIris;
Nunchuck controller code:
// Uncanny eyes controller
// 2018 Laurent Moll
// MIT License
#include <WiiChuck.h>
Accessory nunchuck;
HardwareSerial SerialOut(1); // 2nd UART, going to the skulls
  Serial.begin(921600); // Super fast because the WiiChuck library dumps data to serial and it adds lag into the reading at lower speeds
  SerialOut.begin(9600, SERIAL_8N1, -1, 13); // Tx only, no Rx
  nunchuck.begin();
  nunchuck.type = NUNCHUCK;
  char serCmd[11];
  static char oldSerCmd[11] = "          ";
  nunchuck.readData();    // Read inputs and update maps
  serCmd[0] = '0';
  serCmd[1] = (nunchuck.getButtonC() ? 'I' : 'O');
  serCmd[2] = (nunchuck.getButtonZ() ? 'I' : 'O');
  int joyX = nunchuck.getJoyX();
  serCmd[3] = '0' + ((joyX/100) % 10);
  serCmd[4] = '0' + ((joyX/10) % 10);
  serCmd[5] = '0' + ((joyX/1) % 10);
  int joyY = nunchuck.getJoyY();
  serCmd[6] = '0' + ((joyY/100) % 10);
  serCmd[7] = '0' + ((joyY/10) % 10);
  serCmd[8] = '0' + ((joyY/1) % 10);
  serCmd[9] = ' ';
  serCmd[10] = '\0';
  if (strcmp(serCmd, oldSerCmd)) { // Only send serial command when the serial command has changed
    SerialOut.write(serCmd);
    strcpy(oldSerCmd, serCmd);
What I am not understanding is why the X/Y information does not appear to be read by the controller board and processed to change the eye information. The eyes are always moving random which I would think should be static until the joystick on the nunchuck is moved.The serial link between these two controllers appears to be working as selecting the button will change the eye type. Hopefully this is not all clear as mud. A read-through from the original link provided should be of help as it is well written.
Thanks again
Still waiting for schematics.
Sorry hand drawn is al I have right now.
FYI: If you look at line 251 of the main board program sketch
I think you can see where its looking for a toggle signal from the nunchuck (button "C") however this is not working. Button "Z" does toggle the eye appearance.
I suspect the "wiichuck" has a gyro that is not tuned, or the gyro is broken, and producing random data. The "eye" can move in location (x, y) or action (look left, look up, blink)... can you describe or show "moving random?"
Thanks for the reply.
From reading the description in the original creators details my understanding is that the eyes move randomly by default. When the "C" button is selected the random eye movement is supposed to stop and allow the joystick to control the eyes. This change does not happen. This is the problem. The "Z" button on the Wii nunchuck does toggle the default eye to a dragon eye as expected.
Hope that helps. Just for reference the nunchuck was tested and works correctly.
I will guess the change does not happen because the "C" button is not detected.
I am guessing that this (above) reads all the buttons and places that data in serCmd[]. Print this array to the serial terminal, press the "Z" button and watch for changes in all the elements. If nothing changes, my guess is wrong. If one element does change, you found "Z" so then press the "C" button and watch for changes. If no changes, you have a broken "C" button. If you see changes, stop testing. You found the "C" button.
Using the serCmd[] element on the wii, see if it arrived at the "eyes" microcontroller.
[edit]
This (above) is the receiving code to look for the "C" (any button, it seems). Monitor this (Serial.print() to Serial Monitor) for activity when you press Z or C.
Thank you again. This is good information however (apologies) I'm wondering if you would mind offering how I would do this?
Sorry your details were cut off on my pc until I looked again...mumble. Ill try this
The code in the code block (window) scrolls, so "click" inside the window and "arrow" right or use a scroll-mouse and "shift-scroll-down"
Place Serial.print() statements in places to read the data... I think you want to read serCmd[] values so the line will be something like this...
Serial.print(serCmd[x]); // "x" is an element in the serCmd[] array
I now see the line that looks for the "C" button...
This means ... "IF nunchuck.getButtonC() is HIGH, then the second element of the array ( serCmd[1] ) will contain "I" (upper case, ninth letter of the alphabet), otherwise serCmd[1] will contain "O" (upper case, fifteenth letter of the alphabet).
Find the output of serCmd[1] on the "eyes" side... something like this...
[edit]
I believe your "C" button is broken.
Thanks again
I verified my nunchuck buttons were working on an Arduino and then returned to this setup. I then placed the
in the control sketch and verified that both the C and Z buttons output an "I" when looking at the serial monitor. I also replaced the wire connect3d to both ESP32 pin 13 connections just to be sure.  Unfortunately no change in the result.
The text portion of post #14 inside the code block reads:
You will need to "follow the "I" after "C" is pressed - after the Serial.print(serCmd[1]);, where is serCmd[1] next tested for "I"?
What is that wire's job? Why was it removed? Why was it re-installed?
If the formatting of this chunk of code is correct (it is), serCmd[1] will be tested for "I" only if serCmd[0] is '0' or '0'+serAddr
What are the contents of serCmd[0] and what is serAddr when "C" is pressed (and maybe for testing press "Z")
Look at serCmd[3] through serCmd[8] on the input side and the output side. Those are the joystick movement commands. If joystick movement occurs on both input and output, and the "C" command changes on the output, then you can focus on the output code not servicing the "C"..
