Debugging SPI Code
I'm relatively new to arduino, but am working with a microSD card and an accelerometer. When I test my sensors individually, they work fine, but when I combine them, the code seems to stop detecting my accelerometer. Here's my code, and for reference it stops during the Adafruit sensor test section of setup.
#include <SPI.h>
#include <SD.h>
#include <Adafruit_ICM20649.h>
#include <Adafruit_Sensor.h>
Adafruit_ICM20649 icm;
const int chipSelect = 5;
uint16_t measurement_delay_us = 65535;
#define ICM_CS 6
#define ICM_SCK 7
#define ICM_MISO 8
#define ICM_MOSI 9
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  Serial.println("Adafruit ICM20649 test!");
  // Try to initialize!
  // if (!icm.begin_I2C()) {
  if (!icm.begin_SPI(ICM_CS)) {
    if (!icm.begin_SPI(ICM_CS, ICM_SCK, ICM_MISO, ICM_MOSI)) {
      Serial.println("Failed to find ICM20649 chip");
      while (1) {
        delay(10);
  Serial.println("ICM20649 Found!");
  // icm.setAccelRange(ICM20649_ACCEL_RANGE_4_G);
  Serial.print("Accelerometer range set to: ");
  switch (icm.getAccelRange()) {
  case ICM20649_ACCEL_RANGE_4_G:
    Serial.println("+-4G");
  case ICM20649_ACCEL_RANGE_8_G:
    Serial.println("+-8G");
  case ICM20649_ACCEL_RANGE_16_G:
    Serial.println("+-16G");
  case ICM20649_ACCEL_RANGE_30_G:
    Serial.println("+-30G");
  // icm.setGyroRange(ICM20649_GYRO_RANGE_500_DPS);
  Serial.print("Gyro range set to: ");
  switch (icm.getGyroRange()) {
  case ICM20649_GYRO_RANGE_500_DPS:
    Serial.println("500 degrees/s");
  case ICM20649_GYRO_RANGE_1000_DPS:
    Serial.println("1000 degrees/s");
  case ICM20649_GYRO_RANGE_2000_DPS:
    Serial.println("2000 degrees/s");
  case ICM20649_GYRO_RANGE_4000_DPS:
    Serial.println("4000 degrees/s");
  //  icm.setAccelRateDivisor(4095);
  uint16_t accel_divisor = icm.getAccelRateDivisor();
  float accel_rate = 1125 / (1.0 + accel_divisor);
  Serial.print("Accelerometer data rate divisor set to: ");
  Serial.println(accel_divisor);
  Serial.print("Accelerometer data rate (Hz) is approximately: ");
  Serial.println(accel_rate);
  //  icm.setGyroRateDivisor(255);
  uint8_t gyro_divisor = icm.getGyroRateDivisor();
  float gyro_rate = 1100 / (1.0 + gyro_divisor);
  Serial.print("Gyro data rate divisor set to: ");
  Serial.println(gyro_divisor);
  Serial.print("Gyro data rate (Hz) is approximately: ");
  Serial.println(gyro_rate);
  // make a string for assembling the data to log:
  sensors_event_t accel;
  sensors_event_t gyro;
  sensors_event_t temp;
  icm.getEvent(&accel, &gyro, &temp);
  Serial.print("\t\tTemperature ");
  Serial.print(temp.temperature);
  Serial.println(" deg C");
  /* Display the results (acceleration is measured in m/s^2) */
  Serial.print("\t\tAccel X: ");
  Serial.print(accel.acceleration.x);
  Serial.print(" \tY: ");
  Serial.print(accel.acceleration.y);
  Serial.print(" \tZ: ");
  Serial.print(accel.acceleration.z);
  Serial.println(" m/s^2 ");
  Serial.print("\t\tGyro X: ");
  Serial.print(gyro.gyro.x);
  Serial.print(gyro.gyro.y);
  Serial.print(gyro.gyro.z);
  Serial.println(" radians/s ");
  delay(100);
  String dataString = "";
  String temperature = "";
  String gyroscopeX = "";
  String gyroscopeY = "";
  String gyroscopeZ = "";
  String accelerometerX = "";
  String accelerometerY = "";
  String accelerometerZ = "";
  temperature += "\t\tTemperature ", temp.temperature," deg C";
  gyroscopeX += "\t\tGyro X: ", gyro.gyro.x;
  gyroscopeY += " \tGyro Y: ", gyro.gyro.y;
  gyroscopeZ += " \tGyro Z: ", gyro.gyro.z;
  accelerometerX += "\t\tAccel X: ", accel.acceleration.x;
  accelerometerY += " \tAccel Y: ", accel.acceleration.y;
  accelerometerZ += " \tAccel Z: ", accel.acceleration.z;
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(temperature);
    dataFile.println(gyroscopeX);
    dataFile.println(gyroscopeY);
    dataFile.println(gyroscopeZ);
    dataFile.println(accelerometerX);
    dataFile.println(accelerometerY);
    dataFile.println(accelerometerZ);
    dataFile.close();
    // print to the serial port too:
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
Where did you see this?
      while (1) {
        delay(10);
It looks odd and unnecessary to call the begin() method twice. Try
      while (1) {
      delay(10);
Also, some SD cards don't follow the rules for sharing SPI. What exact SD module do you have?
How are you powering the various sections of the project? What Arduino board are you using?
a7
I'm using an Arduino nano and am powering the various sections using AA battery pack. For reference, here's the SD module and the setup I used In-Depth Tutorial to Interface Micro SD Card Module with Arduino
It also looks like the ICM 20649 is an i2c device, not an SPI device so I'm not sure how that would even compile.
Yes, but the ICM 20649 can be configured to support SPI. Here's the datasheet I was using: Arduino | Adafruit ICM20649 Wide-Range 6-DoF IMU Accelerometer and Gyro | Adafruit Learning System
oh, okay. It looks like you uncommented both SPI begin lines. You should only uncomment 1 of them, depending on if you are using software SPI (you are) or hardware SPI (you are not)
Since the first if() statement is the hardware SPI, it fails and never gets to the second if() which is the software SPI. Your code should look like this
  // if (!icm.begin_SPI(ICM_CS)) {
      while (1) {
        delay(10);
Thanks for the feedback. I implemented it but it still gets stuck on that step...where it doesn't print "failed to find ICM20649 Chip" or that it found the ICM 20649 chip. Are there any other bugs in my code that I could fix?
Post an annotated schematic showing exactly how you have wired it. Be sure to include all power, ground, power sources and indicate any wire over 10"/25cm in length.
I'm not sure how to upload a schematic onto this forum, but I can list the pinouts. I'm using an Arduino Nano which is linked to the ICM 20649 and a MicroSD card adapter
Pinouts for ICM 20649:
  • 5V --> Vin
  • GND --> GND
  • D6 --> ChipSelect
  • D7 --> SCL
  • D8 --> AD0
  • D9 --> SDA
Pinouts for MicroSD Adapter
  • D5 --> ChipSelect
  • D11 --> MOSI
  • D12 --> MISO
  • D13 --> SCK
  • 5V --> VIN
  • GND --> GND
And I connected by battery pack to the arduino nano via VIN and GND. Let me know if that works in place of a schematic
You need to read the forum guidelines. I do not work with word schematics/pin outs. Also show what all of these CAN nodes are connected to.
If your battery pack is connected to Vin and both your sensor and SD module are also connected to Vin, then depending on the battery pack voltage, you could have damaged both modules.
As suggested, a schematic - hand drawn and photographed/scanned is fine - would help more than words.
Please post a picture of a hand drawn wiring diagram, with all pins, parts and connections clearly labeled.
Here's a photo of the hand drawn wiring diagram. Let me know if there's any issues with it
Ah, the drawing makes things clearer.
One suggestion would be to use D10 for one of your device CS signals. It's important that this pin is an output as it will cause the SPI hardware to switch to slave mode if it is left as an unused input.
If you are going to use the accelerometer in SPI mode, then it would seem sensible to use the hardware SPI interface.
Or, did you choose a software SPI interface because the SD card module didn't control the MISO line properly?
I'll try using D10...and yes, I chose to use software SPI because the Sd card didn't control MISO line properly
Just wanted to follow up after I updated to D10 --> I'm still getting the same issues, and for reference here's what's appearing on my serial monitor:
��8������؎�Initializing SD card...card initialized. Ada+�  � !��a�aInitializing SD card...card initialized. Ada+� � !��a�aInitializing SD card...card initialized. Ada+� � !�0a�a.
For reference, when I run this code, the accelerometer outputs data to the serial monitor normally, it's only upon adding the code to include the SD card that it doesn't work properly: `// Basic demo for accelerometer readings from Adafruit ICM20649
#include <Wire.h>
// For SPI mode, we need a CS pin
#define ICM_CS 6
// For software-SPI mode we need SCK/MOSI/MISO pins
#define ICM_SCK 7
#define ICM_MISO 8
#define ICM_MOSI 9
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
    while (1) {
      delay(10);
  //  /* Get a new normalized sensor event */
  delay(100);
  //  Serial.print(temp.temperature);
  //  Serial.print(",");
  //  Serial.print(accel.acceleration.x);
  //  Serial.print(","); Serial.print(accel.acceleration.y);
  //  Serial.print(","); Serial.print(accel.acceleration.z);
  //  Serial.print(gyro.gyro.x);
  //  Serial.print(","); Serial.print(gyro.gyro.y);
  //  Serial.print(","); Serial.print(gyro.gyro.z);
  //  Serial.println();
  //  delayMicroseconds(measurement_delay_us);
What voltage? If connected to Vin, it must be greater than about 6V.
I'm using less than 6V to power. Right now I'm using 5V DC from my PC and eventually plan to shift to 4.5V. What would you recommend I do if I can't connect to VIN?
You can power everything using from 5V (not through Vin), as long as there are 3.3V logic level shifters on the sensor and the SD card module.
Powering through Vin results in a significant voltage drop, which may account for the garbage characters in the serial output shown in post #16.
Better to use a 3.3V Arduino.
Everything is powered through 5V, and they both work when individually tested. However, the issues only arise when I combine them in the code, which makes me believe it's a coding issue. Is there anything in the code that could lead to the garbage character outputs?
