Decimal Precision and Strain Gauges
Hi guys,
I think this is quite simple, but I am stuck and needed some assistance.
Currently I am using the HX711 library for a strain gauge.
My problem is that Serial.println(scale.get_units(), 4); grabs the value with 4 decimal places. This works great.
But I need to store the scale.get_units value as a floating point digit. How would I store this value efficiently?
I tried Serial.available() and using the command value = scale.get_units(); but this only stores 2 decimal places.
Hopefully there is a way to grab what the serial buffer has in it or simply store the scale object value in a variable.
I can post a longer segment of code, but all the examples in the HX711 library never store the value to a variable.
-NB
float x = scale.get_units(); ?
This does work, but only returns two decimal places.
While Serial.print(scale.get_units(),4); returns 4 places.
I need 4 decimal places.
Would fixed point math work?
The "4" in Serial.print(something,4) specifies the number of digits after the decimal point to display. You can change that.
The precision of a floating point number is 6-7 digits total.
Nolebrain:
Don't be silly - if it "works" here Serial.println(scale.get_units(), 4);, then
Serial.println(x, 4);
"works" just as well.
Okay AWOL good call!
I assumed it was getting cut short when storing it as a float value, but really it was just not displaying the full value when printing it.
Thank you so much!! :slight_smile:
If you want all the precision there is to be had, use:
long read();
or
long read_average(byte times = 10);
and do all your math in 32-bit integers. But, you’ll have to take care of offset, tare, and conversion to real-world units yourself.
