Hello everyone,
I’m working on a project that involves decoding a series of complex datastrings. I’ve identified some patterns and meanings for the characters, but I’m struggling to develop a reliable method to decode these strings consistently.
My issues appear because in this case not a character stands for only one other characters. Some characters appear to have more than one meaning and I dont manage to see a pattern yet. I know the meaning of each answer.
The device is an indicator that measures deflections in mm. Currently I am communicating with it via a serial port. The Buadrate is 9600, Data bits 8, stop bits 1, Parity even and no flow control. That’s how it’s set in the device and the receiver. Those settings are changeable (but please don’t go through settings with me, I have tested them all and went through it with support). Trust me when I tell you that’s it encoded. The terminator adds CR and LF. If I forgot anything please tell me.
The message is typically build up as following:
\!>|R||||||||
this one more specifically stands for GN00,+0000.0000CRLF
What Ive identified so far, is that only the last nine are interesting for me. R/P stand for a + and H/J for a - the rest are numbers 0000.0000.
Here are some examples:
|Nr.|Command|Measurement|Output|
|1.|GA00|0.0000mm|\!>xR|||||||||
|2.|GA00|0.0000mm|\!>|R|||||||||
|3.|GA00|0.0000mm|\!>|R|||||||||
|4.|GA00|0.0000mm|\!>|R|||||||||
|5.|GA00|0.0000mm|\!>|R|||||||||
|6.|GA00|0.0000mm|\!>|R|||x|||||
|7.|GA00|0.0000mm|\!>|R|||||||||
|8.|GA00|0.0000mm|X!>xR|||||||||
|9.|GA00|0.0000mm|\!>xR|||||||||
|10.|GA00|0.0000mm|X!>|R|||||||||
|11.|GA00|0.0005mm|\!>|R|||||||T|
|12.|GA00|0.0005mm|\!>|R|||||||T|
|13.|GA00|0.0005mm|\!>|R|||||||T|
|14.|GA00|0.0005mm|\!>|R|||||||T|
|15.|GA00|0.0005mm|\!>|Rx||||||T|
|16.|GA00|0.0005mm|\!>|R|||||||T|
|17.|GA00|0.0005mm|\!>|R|||||||T|
|18.|GA00|0.0005mm|\!>|R||x||||T|
|19.|GA00|0.0005mm|\!>|P|||||||T|
|20.|GA00|0.0005mm|\!>|R|||||||T|
|21.|GA00|0.0010mm|\!>|R||||||t>|
|22.|GA00|0.0010mm|\!>|R||||||t<|
|23.|GA00|0.0010mm|\!>|R|||xx|t>|
|24.|GA00|0.0010mm|X!>|R||||x|t<|
|25.|GA00|0.0010mm|\!>|R||||||t<|
|26.|GA00|0.0010mm|\!>|R|||||xt>|
|27.|GA00|0.0010mm|\!>|R||||||t>|
|28.|GA00|0.0010mm|\!>xR|||||xt<|
|29.|GA00|0.0010mm|\!>|R||||||t>|
|30.|GA00|0.0010mm|\!>|R||||||t>|
|31.|GA00|0.0020mm|\!>|R||||||l>|
|32.|GA00|0.0020mm|\!>|R||||||l>|
|33.|GA00|0.0020mm|\!>|R||||||l>|
|34.|GA00|0.0020mm|\!>|R||||||l>|
|35.|GA00|0.0020mm|\!>|R|||||xl>|
|36.|GA00|0.0020mm|\!>|P||||||l>|
|37.|GA00|0.0020mm|X!>|R||||||l>|
|38.|GA00|0.0020mm|\!>|R||||||l>|
|39.|GA00|0.0020mm|\!>|Rx|||||l>|
|40.|GA00|0.0020mm|\!>|R|||x||l>|
|41.|GA00|0.0030mm|\!>|R||||||d||
|42.|GA00|0.0030mm|X!>|R||||||d||
|43.|GA00|0.0030mm|X!>|R||||||d||
|44.|GA00|0.0030mm|\!>|R||||||d||
|45.|GA00|0.0030mm|\!>|R||||||d||
|46.|GA00|0.0030mm|\!>|R||||||d||
|47.|GA00|0.0030mm|\!>|Rx|||||d||
|48.|GA00|0.0030mm|\!>|R||||||d||
|49.|GA00|0.0030mm|\!>|P||||||`x|
|50.|GA00|0.0030mm|\!>|P||||||d||
|51.|GA00|0.0040mm|\!>|R||||||\>|
|52.|GA00|0.0040mm|\!>|R||||||\<|
|53.|GA00|0.0040mm|\!>|R||||||X>|
|54.|GA00|0.0040mm|\!>|R||||||\>|
|55.|GA00|0.0040mm|\!>|R||||x|\>|
|56.|GA00|0.0040mm|\!>|R||||||X>|
|57.|GA00|0.0040mm|\!>|R||||||X<|
|58.|GA00|0.0040mm|\!>|R|||||x\>|
|59.|GA00|0.0040mm|\!>|R||||||\>|
|60.|GA00|0.0040mm|\!>|R||||||\>|
|61.|GA00|0.0050mm|\!>|P|||||xT||
|62.|GA00|0.0050mm|\!>|R||||||T||
|63.|GA00|0.0050mm|\!>|R||x|||T||
|64.|GA00|0.0050mm|\!>|R||||||P||
|65.|GA00|0.0050mm|\!>|R|||||| ||
|66.|GA00|0.0050mm|\!>|R||||||T||
|67.|GA00|0.0050mm|\!>|R||||x|T||
|68.|GA00|0.0050mm|\!>|R||x|||T||
|69.|GA00|0.0050mm|\!>|Px|||||T||
|70.|GA00|0.0050mm|\!>|R||||||T||
|71.|GA00|0.0060mm|\!>|R||||||L||
|72.|GA00|0.0060mm|X!>|R||||||L||
|73.|GA00|0.0060mm|\!>|R|||x||L||
|74.|GA00|0.0060mm|\!>|R||||||L||
|75.|GA00|0.0060mm|\!>|P||||||L||
|76.|GA00|0.0060mm|\!>|R||||||Lx|
|77.|GA00|0.0060mm|\!>|P||||||H||
|78.|GA00|0.0060mm|\!>|R|||x||H||
|79.|GA00|0.0060mm|\!>|R||||||L||
|80.|GA00|0.0060mm|\!>|R||||||L||
|81.|GA00|0.0070mm|\!>|R||||||D>|
|82.|GA00|0.0070mm|\!>|Rx|||||D>|
|83.|GA00|0.0070mm|\!>|R||||||D<|
|84.|GA00|0.0070mm|\!>|P||||||D>|
|85.|GA00|0.0070mm|\!>|R||||||D>|
|86.|GA00|0.0070mm|\!>|R||||||D>|
|87.|GA00|0.0070mm|\!>|R||||||D>|
|88.|GA00|0.0070mm|\!>|R||||||D<|
|89.|GA00|0.0070mm|\!>|R||||||D>|
|90.|GA00|0.0070mm|\!>|R||||||D>|
|91.|GA00|0.0080mm|\!>|P||||||<>|
|92.|GA00|0.0080mm|X!>|R|||x||<<|
|93.|GA00|0.0080mm|\!>|R||||||<<|
|94.|GA00|0.0080mm|\!>|R||||x|<>|
|95.|GA00|0.0080mm|\!>|P||x|||<>|
|96.|GA00|0.0080mm|\!>|R||||||<>|
|97.|GA00|0.0080mm|\!>|R||||||<>|
|98.|GA00|0.0080mm|\!>|R||||||<>|
|99.|GA00|0.0080mm|\!>|Rx|||x|<>|
|100.|GA00|0.0080mm|\!>|R||||||<>|
|101.|GA00|0.0090mm|\!>|R||||||4||
|102.|GA00|0.0090mm|X!>|R||||||4||
|103.|GA00|0.0090mm|\!>|R||||||4||
|104.|GA00|0.0090mm|\!>|R||||||4||
|105.|GA00|0.0090mm|\!>|R||x|||4||
|106.|GA00|0.0090mm|\!>|R||||||4||
|107.|GA00|0.0090mm|\!>|R||||||4||
|108.|GA00|0.0090mm|X!>|R||||||4||
|109.|GA00|0.0090mm|\!>|P||||||4||
|110.|GA00|0.0090mm|\!>|P||||x|4||
I could surely provide more examples.
That are all the possible meanings I have found so far:
‘-’ = H, J
‘+’ = R, P
9 = 4, &
8 = <, 8
7 = D
6 = L,
5 = T, *, (
4 = , F
3 = d
2 = l
1 = t, :
0 = |, <, >
x=|
X=\
Thank you!
