ServoDecode.h
// ServoDecodeClass.h
//This library decodes typical RC composite servo inputs into individual channel pulse widths
#ifndef ServoDecode_H
#define ServoDecode_H
#include
//#include //removed for 0012
typedef uint8_t byte;
#define icpPin 8 // this interrupt handler must use pin 8
#define TICKS_PER_uS 2 // number of timer ticks per microsecond
typedef enum {
NULL_state=-1, NOT_SYNCHED_state, ACQUIRING_state, READY_state, FAILSAFE_state
} decodeState_t;
#define MAX_CHANNELS 8 // maximum number of channels we can store, don't increase this above 8
#define MIN_IN_PULSE_WIDTH (750 * TICKS_PER_uS) //a valid pulse must be at least 750us (note clock counts in 0.5 us ticks)
#define MAX_IN_PULSE_WIDTH (2250 * TICKS_PER_uS) //a valid pulse must be less than 2250us
#define SYNC_GAP_LEN (3000 * TICKS_PER_uS) // we assume a space at least 3000us is sync (note clock counts in 0.5 us ticks)
#define FAILSAFE_PIN 13 // if defined, this will set the given pin high when invalid data is received
class ServoDecodeClass
public:
ServoDecodeClass(); //Constructor
void begin();
decodeState_t getState(); //State Function
int GetChannelPulseWidth(byte chan); // this is the access function for channel data
void setFailsafe(byte chan, int value); // pulse width to use if invalid data, value of 0 uses last valid data
void setFailsafe();// setFailsafe with no arguments sets failsafe for all channels to their current values
// useful to capture current tx settings as failsafe values
byte getChanCount();
private:
extern ServoDecodeClass ServoDecode; // make an instance for the user
#endif
ServoDecode.cpp
//ServoDecode.cpp
#include "ServoDecode.h"
#include
#include
#define PULSE_START_ON_RISING_EDGE 0
#define PULSE_START_ON_FALLING_EDGE (1< ACQUISITION_COUNT) {
State = READY_state; // this is the second sync and all channel data is ok so flag that channel data is valid
NbrChannels = Channel; // save the number of channels detected
else if( State == FAILSAFE_state) {
if(Channel == NbrChannels){ // did we get good pulses on all channels
Channel = 0; // reset the channel counter
ISR(TIMER1_OVF_vect){
if(State == READY_state){
State = FAILSAFE_state; // use fail safe values if signal lost
ISR(TIMER1_CAPT_vect)
// we want to measure the time to the end of the pulse
if( (_SFR_BYTE(TCCR1B) & (1<= SYNC_GAP_LEN){ // is the space between pulses big enough to be the SYNC
processSync();
else if(Channel < MAX_CHANNELS) { // check if its a valid channel pulse and save it
if( (ICR1 >= MIN_IN_PULSE_WIDTH) && (ICR1 <= MAX_IN_PULSE_WIDTH) ){ // check for valid channel data
Pulses[++Channel] = ICR1 / TICKS_PER_uS; // store pulse length as microsoeconds
else if(State == READY_state){
State = FAILSAFE_state; // use fail safe values if input data invalid
ServoDecodeClass::ServoDecodeClass(){
void ServoDecodeClass::begin(){
pinMode(icpPin,INPUT);
Channel = 0;
State = NOT_SYNCHED_state;
TCCR1A = 0x00; // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
TCCR1B = 0x02; // 16MHz clock with prescaler means TCNT1 increments every .5 uS (cs11 bit set
TIMSK1 = _BV(ICIE1)|_BV (TOIE1); // enable input capture and overflow interrupts for timer 1
for(byte chan = 1; chan <= MAX_CHANNELS; chan++)
Failsafe[chan] = Pulses[chan]= 1500; // set midpoint as default values for pulse and failsafe
decodeState_t ServoDecodeClass::getState(){
return State;
byte ServoDecodeClass::getChanCount(){
return NbrChannels;
void ServoDecodeClass::setFailsafe(byte chan, int value){
if( (chan > 0) && (chan <= MAX_CHANNELS) ) {
Failsafe[chan] = value;
void ServoDecodeClass::setFailsafe(){
// usefull to capture current tx settings as failsafe values
for(byte chan = 1; chan <= MAX_CHANNELS; chan++) {
Failsafe[chan] = Pulses[chan];
int ServoDecodeClass::GetChannelPulseWidth( uint8_t channel)
int result = 0; // default value
if( channel <= MAX_CHANNELS) {
if( (State == FAILSAFE_state)&& (Failsafe[channel] > 0 ) )
result = Failsafe[channel]; // return the channels failsafe value if set and State is Failsafe
else if( (State == READY_state) || (State == FAILSAFE_state) ){
cli(); //disable interrupts
result = Pulses[channel] ; // return the last valid pulse width for this channel
sei(); // enable interrupts
return result;
// make one instance for the user
ServoDecodeClass ServoDecode = ServoDecodeClass() ;
ServoDecode.pde Test Sketch
// ServoDecodeTest
#include
char * stateStrings[] = {
"NOT_SYNCHED", "ACQUIRING", "READY", "in Failsafe"};
void setup() // run once, when the sketch starts
Serial.begin(38400);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
ServoDecode.begin();
ServoDecode.setFailsafe(3,1234); // set channel 3 failsafe pulse width
void loop() // run over and over again
int pulsewidth;
// print the decoder state
if( ServoDecode.getState()!= READY_state) {
Serial.print("The decoder is ");
Serial.println(stateStrings[ServoDecode.getState()]);
for ( int i =0; i <=MAX_CHANNELS; i++ ){ // print the status of the first four channels
Serial.print("Cx"); // if you see this, the decoder does not have a valid signal
Serial.print(i);
Serial.print("= ");
pulsewidth = ServoDecode.GetChannelPulseWidth(i);
Serial.print(pulsewidth);
Serial.print(" ");
Serial.println("");
else {
// decoder is ready, print the channel pulse widths
for ( int i =1; i <=MAX_CHANNELS; i++ ){ // print the status of the first four channels
Serial.print("Ch");
Serial.print(i);
Serial.print("= ");
Serial.print(" ");
Serial.println("");
digitalWrite(12,LOW);
digitalWrite(13,LOW);
delay(500); // update 2 times a second
