Hello All,
Please help to debug the attached code, as it not working while decrementing through pushbutton2.
Thanks in advance.
sketch_apr28a.ino (1.02 KB)
Hello All,
Thanks in advance.
Please post your code properly, in line, using code tags.
Describe exactly how you have the buttons wired (post a hand drawn diagram).
Define "not working". Describe what goes wrong.
jremington:
not able to decrease the value with push button2.
const int ButtonPin1 = 7; //connected button1 to pin 7
const int ButtonPin2 = 2; //connected button2 to pin 2
//Variable that will be change
int buttonstate1 = 0; //inital state of button1 set to zero
int buttonstate2 = 0; //inital state of button2 set to zero
int buttonpushcounter = 0; //initial state of counter to zero
int lastbuttonstate = 0; //previous state of counter
Serial.begin(9600); //open port for serial monitor
pinMode (ButtonPin1, INPUT); //set buttonpin1 as input
pinMode (ButtonPin2, INPUT); //set buttonpin2 as input
buttonstate1 = digitalRead(ButtonPin1); //read button1 status
if (buttonstate1 != lastbuttonstate) { //compare the previous value of button with current value
if (buttonstate1 == HIGH){ //condition if button1 is high
buttonpushcounter++; //increment the value of push button counter
if (buttonpushcounter >= 10){ //condition for push button countern that should not exceed the value greater than 10
buttonpushcounter = 10; //if exceeding the value of 10 then set pushbutton counter to 10 only
Serial.println("Maximum Value Reached"); //print to serial monitor
Serial.println("Button1 Was Pressed"); //print to serial monitor if button1 was pressed
Serial.println(buttonpushcounter); //print value of button push counter on serial monitor
lastbuttonstate = buttonstate1; //store to previous for further loop read
buttonstate2 = digitalRead(ButtonPin2); //read button2 status
if (buttonstate2 != lastbuttonstate) { //compare the current value with previous button value
if (buttonstate2 == HIGH) { //condition if button2 is high
buttonpushcounter-=1; //decrement the value of push button counter
if (buttonpushcounter < 0){ //condition if button push counter is less than zero
buttonpushcounter = 0; //set push button counter to zero
Serial.println("Turning all OFF"); //print to serial monitor
Serial.println("Button2 Was Pressed"); //print to serial monitor if button2 was pressed
Serial.println(buttonpushcounter); //print the push counter value to serial monitor
delay(500); //wait or delay the program 500ms
lastbuttonstate = buttonstate2; //store the prevoius value for further loop read
If you indent your code (use the auto format tool in the IDE) you may see what your problem is
One variable to store states of two different buttons?
int lastbuttonstate1 = 0; //previous state of button1 counter
int lastbuttonstate2 = 0; //previous state of button2 counter
if (buttonstate1 != lastbuttonstate1) { //compare the previous value of button with current value
if (buttonstate1 == HIGH) { //condition if button1 is high
if (buttonpushcounter >= 10) { //condition for push button countern that should not exceed the value greater than 10
lastbuttonstate1 = buttonstate1; //store to previous for further loop read
if (buttonstate2 != lastbuttonstate2) { //compare the current value with previous button value
buttonpushcounter -= 1; //decrement the value of push button counter
if (buttonpushcounter < 0) { //condition if button push counter is less than zero
lastbuttonstate2 = buttonstate2; //store the prevoius value for further loop read
[quote author=jremington link=msg=3709978 date=1524938042]
[code] lastbuttonstate = buttonstate1; //store to previous for further loop read
[/quote]
If you look at your code now, you'll see that you only read the second switch if the first has already been pressed.
TolpuddleSartre:
Thanks a lot TolpuddleSartre for helping to make my code working properly. Debugging done and code working fine.
