Is there a way to change the default size of the IDE window? On my laptop it is too tall. In Version 1.x it was settable in a preferences file. I find nothing similar in Version 2.
I looked in the ctrl-shift-p preferences, but found nothing.
Unfortunately I don't think there is currently any setting for the window size. There is an existing feature request for such a setting here:
opened 09:57AM - 17 Aug 22 UTC
type: enhancement
topic: code
### Describe the request
If I open a sketch and resize the window, stop IDE2,… and start IDE2, then the window size is restored. All works as expected.
However, when I set my preferred window size and open an example, create a new sketch, etc., the default hard-coded window size will be used for the new window. It feels like the user has no control over the window size, and adjusting for every sketch is tedious.
I would like to tune this with an Arduino preference/setting. If this new setting is true, the window dimension of the current would be used for the new window instead of the default dimension.
### Describe the current behavior
See the request above 👆 but in a nutshell, every new window has the default hard-coded size.
### Arduino IDE version
Version: 2.0.0-rc9.2-nightly-20220817 Date: 2022-08-17T03:45:04.166Z CLI Version: git-snapshot [6e007379] Copyright © 2022 Arduino SA
### Operating system
macOS
### Operating system version
12.3.1
### Additional context
#### Additional Reports
- https://github.com/arduino/arduino-ide/issues/1981
- https://forum.arduino.cc/t/new-sketch-window-dimensions/1146020
### Issue checklist
- [X] I searched for previous requests in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the feature was still missing when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My request contains all necessary details
