Is the default sketch that the Nano ESP32-S3 (SKU: ABX00092) ships with available? The RGB LED gently cycled between each color and I would like to recreate this functionality.
Did you look in the example menu? I suspect it may be there but if not there is stuff that would help you do this.
Here my modified blink for the Nano ESP32 RGB LED.
int vDelay = 500; //Controls blink speed of built in and RGB leds
pinMode(LED_RED, OUTPUT);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
void toggleLED() {
if (digitalRead(LED_BUILTIN) == LOW){
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
toggleLED();
digitalWrite(LED_RED, LOW);
digitalWrite(LED_GREEN, LOW);
digitalWrite(LED_BLUE, LOW);
delay(vDelay);
//2
toggleLED();
digitalWrite(LED_BLUE, HIGH);
delay(vDelay);
//3
toggleLED();
digitalWrite(LED_GREEN, HIGH);
delay(vDelay);
//4
toggleLED();
digitalWrite(LED_RED, HIGH);
delay(vDelay);
//5
toggleLED();
delay(vDelay);
//6
toggleLED();
delay(vDelay);
//7
toggleLED();
delay(vDelay);
//8 Turns RGB LED completely Off
toggleLED();
delay(vDelay);
Thanks for sharing @Datacom1!
Yours is definitely cooler, but in regards to the original request, I'll mention the Nano ESP32 documentation now includes a sketch that provides the out of the box LED behavior:
https://docs.arduino.cc/tutorials/nano-esp32/cheat-sheet/#default-sketch
@Datacom1 The code above does not work… LED_BLUE, LED_RED, LED_GREEN never defined. Please update your example.
Hi @jibun-no-kage. Which board do you have selected from the Tools > Board menu in Arduino IDE.
LED_RED, LED_GREEN, and LED_BLUE are indeed defined when you are compiling for the Arduino Nano ESP32 board:
They won't necessarily be defined if you are compiling for a different board though.
