ESP32 S3 BlinkRGB.ino Advanced Example Sketch
An Arduino IDE sketch written and tested for ESP32 S3 Devkit C1, which has an RGB led on board connected to GPIO38.
Based on the BlinkRGB.ino example sketch for Arduino IDE by Espressif Systems.
Make sure you are well aware of the board and build (no harm in double checking. It is a good habit in this field).
If you have ESP32 S3 WROOM1 N8R8 Devkit C1 board, you can refer to this link to verify your setup with Arduino IDE, where I provide information from my bit of the experience.
ESP32 S3 Devkit C1 Arduino IDE Sanity Check
BlinkRGBAdv.ino
  BlinkRGB Example Sketch Revision 2 - Advanced LED Effects
  Improved ESP32 Blink RGB sketch.
  Demonstrates comprehensive usage of onboard RGB LED on ESP32 dev boards.
  Calling digitalWrite(RGB_BUILTIN, HIGH) will use hidden RGB driver.
  RGBLedWrite demonstrates control of each channel:
  void rgbLedWrite(uint8_t pin, uint8_t red_val, uint8_t green_val, uint8_t blue_val)
  WARNING: Do keep in mind that GPIO38 will be inaccessible/locked if RGB LED is used. (Typical for any extra board components).
  Tested for: ESP32 S3 Rev2 WROOM1 N8R8 Devkit C1
  Designed by: Sir Ronnie from Core1D Automation Labs
  Based on ESP32 BlinkRGB.ino example sketch by Espressif Systems
  MIT License.
  Hardware Configuration:
  - RGB LED connected to GPIO 38 (as marked RGB@IO38 on silkscreen)
  - Auto-cycles through effects every 10.24 seconds (optimized for hardware timing)
#define RGB_BUILTIN     38       // Board-specific: RGB LED on GPIO 38
#define RGB_BRIGHTNESS  32      // Default brightness (max 255)
#define EFFECT_DURATION 10240  // 10.24 seconds per effect (power of 2 for efficiency)
#define FAST_DELAY      50    // Fast transitions
#define MEDIUM_DELAY    100  // Medium transitions
#define SLOW_DELAY      200 // Slow transitions
// Effect counter
      int currentEffect = 0;
const int totalEffects  = 12;
// Global variables for smooth transitions
unsigned long effectStartTime = 0;
          int stepCounter     = 0;
  Serial.println("Advanced BlinkRGB - All LED Effects Demo");
  Serial.println("Tested for ESP32 S3 Rev 2 WROOM 1 N8R8 Devkit C1");
  Serial.println("Enhanced by: Sir Ronnie from Core1D Automation Labs");
  Serial.println("MIT License\n");
  effectStartTime = millis();
  // Check if it's time to switch to next effect
  if (millis() - effectStartTime >= EFFECT_DURATION) {
    currentEffect   = (currentEffect + 1) % totalEffects;
    stepCounter     = 0;
    Serial.print("Switching to Effect ");
    Serial.print(currentEffect + 1);
    Serial.print(": ");
    printEffectName(currentEffect);
  // Execute current effect
  switch (currentEffect) {
    case  0: basicOnOff();       break;
    case  1: primaryColors();    break;
    case  2: rainbowCycle();     break;
    case  3: breathingEffect();  break;
    case  4: strobeEffect();     break;
    case  5: colorFade();        break;
    case  6: randomColors();     break;
    case  7: fireEffect();       break;
    case  8: policeFlasher();    break;
    case  9: heartbeat();        break;
    case 10: matrixEffect();     break;
    case 11: spectrumAnalyzer(); break;
void printEffectName(int effect) {
  const char* names[] = {
    "Basic On/Off",   "Primary Colors", "Rainbow Cycle", "Breathing Effect",
    "Strobe Effect",  "Color Fade",     "Random Colors", "Fire Effect",
    "Police Flasher", "Heartbeat",      "Matrix Effect", "Spectrum Analyzer"
  Serial.print(names[effect]);
// Effect 1: Basic On/Off (Original functionality)
void basicOnOff() {
  digitalWrite(RGB_BUILTIN, HIGH);  // White
  digitalWrite(RGB_BUILTIN, LOW);   // Off
// Effect 2: Primary Colors
void primaryColors() {
  rgbLedWrite(RGB_BUILTIN, RGB_BRIGHTNESS, 0,              0);               // Red
  delay(800);
  rgbLedWrite(RGB_BUILTIN, 0,              RGB_BRIGHTNESS, 0);               // Green
  delay(800);
  rgbLedWrite(RGB_BUILTIN, 0,              0,              RGB_BRIGHTNESS);  // Blue
  delay(800);
  rgbLedWrite(RGB_BUILTIN, RGB_BRIGHTNESS, RGB_BRIGHTNESS, 0);               // Yellow
  delay(800);
  rgbLedWrite(RGB_BUILTIN, RGB_BRIGHTNESS, 0,              RGB_BRIGHTNESS);  // Magenta
  delay(800);
  rgbLedWrite(RGB_BUILTIN, 0,              RGB_BRIGHTNESS, RGB_BRIGHTNESS);  // Cyan
  delay(800);
  rgbLedWrite(RGB_BUILTIN, RGB_BRIGHTNESS, RGB_BRIGHTNESS, RGB_BRIGHTNESS);  // White
  delay(800);
  rgbLedWrite(RGB_BUILTIN, 0,              0,              0);               // Off
  delay(800);
// Effect 3: Rainbow Cycle
void rainbowCycle() {
  static int hue = 0;
  int r, g, b;
  hsvToRgb(hue, 255, RGB_BRIGHTNESS, &r, &g, &b);
  rgbLedWrite(RGB_BUILTIN, r, g, b);
  hue = (hue + 2) % 360;
  delay(FAST_DELAY);
// Effect 4: Breathing Effect
void breathingEffect() {
  static bool increasing = true;
  static int brightness  = 0;
  if (increasing) {
    brightness += 2;
    if (brightness >= RGB_BRIGHTNESS) increasing = false;
    brightness -= 2;
    if (brightness <= 0) increasing = true;
  rgbLedWrite(RGB_BUILTIN, 0, brightness, brightness/2);  // Cyan breathing
  delay(30);
// Effect 5: Strobe Effect
void strobeEffect() {
  for (int flash = 0; flash < 10; flash++) {
    delay(50);
    delay(50);
// Effect 6: Color Fade Transitions
void colorFade() {
  static int phase     = 0;
  static int fadeValue = 0;
  static bool fadeUp   = true;
  int r = 0, g = 0, b = 0;
  switch (phase) {
    case 0: r = fadeValue;                                                  break; // Red fade in
    case 1: r = RGB_BRIGHTNESS;             g = fadeValue;                  break; // Green fade in
    case 2: r = RGB_BRIGHTNESS - fadeValue; g = RGB_BRIGHTNESS;             break; // Red fade out
    case 3: g = RGB_BRIGHTNESS;             b = fadeValue;                  break; // Blue fade in
    case 4: g = RGB_BRIGHTNESS - fadeValue; b = RGB_BRIGHTNESS;             break; // Green fade out
    case 5: r = fadeValue;                  b = RGB_BRIGHTNESS;             break; // Red fade in
    case 6: r = RGB_BRIGHTNESS;             b = RGB_BRIGHTNESS - fadeValue; break; // Blue fade out
  if (fadeUp) {
    fadeValue += 4;
    if (fadeValue >= RGB_BRIGHTNESS) {
      fadeUp = false;
      phase = (phase + 1) % 7;
    fadeValue -= 4;
    if (fadeValue <= 0) fadeUp = true;
  delay(30);
// Effect 7: Random Colors
void randomColors() {
  int r = random(0, RGB_BRIGHTNESS + 1);
  int g = random(0, RGB_BRIGHTNESS + 1);
  int b = random(0, RGB_BRIGHTNESS + 1);
  delay(300);
// Effect 8: Fire Effect
void fireEffect() {
  int red   = RGB_BRIGHTNESS;
  int green = random(0, RGB_BRIGHTNESS/2);
  int blue  = random(0, RGB_BRIGHTNESS/8);
  rgbLedWrite(RGB_BUILTIN, red, green, blue);
  delay(random(50, 150));
// Effect 9: Police Flasher
void policeFlasher() {
  // Red flash
  for (int i = 0; i < 3; i++) {
    delay(100);
    delay(100);
  delay(200);
  // Blue flash
    delay(100);
    delay(100);
  delay(200);
// Effect 10: Heartbeat
void heartbeat() {
  // First beat
  for (int i = 0; i < RGB_BRIGHTNESS; i += 8) {
    rgbLedWrite(RGB_BUILTIN, i, 0, 0);
    delay(10);
  for (int i = RGB_BRIGHTNESS; i >= 0; i -= 8) {
    delay(10);
  delay(100);
  // Second beat
    delay(10);
    delay(10);
  delay(800); // Long pause like heartbeat
// Effect 11: Matrix Effect (Green digital rain simulation)
void matrixEffect() {
  static int intensity  = 0;
  static bool direction = true;
  if (direction) {
    intensity += 3;
    if (intensity >= RGB_BRIGHTNESS) direction = false;
    intensity -= 3;
    if (intensity <= 0) direction = true;
  // Random green flickers
  if (random(0, 10) > 7) {
    rgbLedWrite(RGB_BUILTIN, 0, random(RGB_BRIGHTNESS/2, RGB_BRIGHTNESS), 0);
    rgbLedWrite(RGB_BUILTIN, 0, intensity, 0);
  delay(80);
// Effect 12: Spectrum Analyzer Simulation
void spectrumAnalyzer() {
  static int band = 0;
  int colors[][3] = {
    {RGB_BRIGHTNESS, 0, 0},           // Red (bass)
    {RGB_BRIGHTNESS, RGB_BRIGHTNESS/2, 0}, // Orange
    {RGB_BRIGHTNESS, RGB_BRIGHTNESS, 0},   // Yellow
    {0, RGB_BRIGHTNESS, 0},           // Green (mid)
    {0, RGB_BRIGHTNESS, RGB_BRIGHTNESS},   // Cyan
    {0, 0, RGB_BRIGHTNESS},           // Blue (treble)
    {RGB_BRIGHTNESS/2, 0, RGB_BRIGHTNESS}  // Purple
  int level = random(RGB_BRIGHTNESS/4, RGB_BRIGHTNESS);
              (colors[band][0] * level) / RGB_BRIGHTNESS,
              (colors[band][1] * level) / RGB_BRIGHTNESS,
              (colors[band][2] * level) / RGB_BRIGHTNESS);
  band = (band + 1) % 7;
  delay(150);
// Utility function: Convert HSV to RGB
void hsvToRgb(int h, int s, int v, int* r, int* g, int* b) {
  int c = (v * s) / 255;
  int x = (c * (60 - abs((h / 60) % 2 * 60 - 60))) / 60;
  int m = v - c;
  if (h < 60) {
    *r = c; *g = x; *b = 0;
  } else if (h < 120) {
    *r = x; *g = c; *b = 0;
  } else if (h < 180) {
    *r = 0; *g = c; *b = x;
  } else if (h < 240) {
    *r = 0; *g = x; *b = c;
  } else if (h < 300) {
    *r = x; *g = 0; *b = c;
    *r = c; *g = 0; *b = x;
  *r += m; *g += m; *b += m;
Can you please explain what you mean by this
It drops right into Wokwi's ESP32-S3 simulation and works:
What I meant to say is, this is a Neopixel type RGB LED, which means it has a small controller of its own.
This means that once the LED is used, GPIO 38 is locked, and cannot be used for any other IO pin usage (which is essentially setting the pin HIGH or LOW).
I am trying the sketch, but I get no RGB lit; I do get serial output regarding which effect. The verbose error says I need a digitalMode(38, OUTPUT), but that fails. I bet I need a library; any ideas?
You could say the same thing about any pin used for one purpose not being able to be used for a second purpose. The comment in the sketch makes it sound that using pin 38 to drive the LEDs causes a particular problem when it doesn't
Yes, I do see the point. I have changed the wordings to prevent any kind of confusion.
Although I should mention, the official RGB example sketch header contains the line, I merely copied and pasted the header from there and then formatted the header wherever the changes were necessary.
Do try once with RGB brightness 64 as this was the default value in the BlinkRGB sketch (I doubt it will do anything, but who knows).
Double check the IDE setup from the "Tools" dropdown menu i.e. CPU speed, RAM type, etc. If you are working with C1 Devkit, here is the article of mine which covers this in some detail:
If all these fails while you are getting serial reading, and considering I uploaded it after I tested the sketch in my own board, I would suspect a busted LED.
Do verify the board type and the RGB silk marking, as I am working on the assumption that the boards are same.
I’m running the ESP32 XH-S3E board, and I found that the RGB was on pin 97. I’m not sure how it could be on pin 97, as there is no pin 97 on the board. When I changed it to that, it worked! I ran this sketch, and it printed out Pin 97 for the controlling pin. So I changed it in the Blink sketch, and it worked.
  Serial.print("LED_BUILTIN is on pin: ");
  Serial.println(LED_BUILTIN);
  // Nothing here
This unusual pin numbering is how the Arduino core for the esp32 manages a way to use the timing sequence for a neopixel led
See esp32-hal-rgb-led.h and esp32-hal-rgb-led.c
From pins_arduino.h for the esp32 s3
#define PIN_RGB_LED 48
// BUILTIN_LED can be used in new Arduino API digitalWrite() like in Blink.ino
static const uint8_t LED_BUILTIN = SOC_GPIO_PIN_COUNT + PIN_RGB_LED;
For the ESP32-S3 the SOC_GPIO_PIN_COUNT is 49 .
So LED_BUILTIN is 97.
Are you saying the LED_BUILTIN did not work but 97 did, even though both are equal to 97?
I found that I had the wrong board selected in the IDE for the board I have. Now that I have the correct board loaded the LED_BUILTIN does work as it should!
It is important to select the correct board. Many of the defined pins for I2C, SPI, UART, etc. can be different for different boards, even though the same processor is used.
This was a new board that I have never seen before. My friend doesn’t dig as deeply as I do to find out more about this board. I have never seen a board with a USB and a COM plug on them. Now I know I have the correct board in the IDE, I can proceed to find out what it can do.
Based on BlinkM/MinM.
