I have 4 leds in my project. Any one should turn on when given input, also should turn off immediately. I havve used delay in if to turn it off. But its not. Help me if code is going somewhere wrong
Thank you
sketch_may24a.ino (1.23 KB)
Thank you
Attach your code using the </> icon on the left side of the posting menu.
Put your sketch between the code tags ``
Why do you need delay(), use BWD, see the blink without delay example in the IDE.
How are your switches wired?
You may need a PULLUP resistor or use INPUT_PULLUP .
const int upip=7;
const int downip=8;
const int leftip=11;
const int rightip=12;
const int upled=5;
const int downled=6;
const int leftled=9;
const int rightled=10;
int a1=0;
int a2=0;
int a3=0;
int a4=0;
pinMode(7,INPUT);
pinMode(8,INPUT);
pinMode(11,INPUT);
pinMode(12,INPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
a1=digitalRead(upip);
a2=digitalRead(downip);
a3=digitalRead(leftip);
a4=digitalRead(rightip);
if (a1 == HIGH) {
digitalWrite(upled,HIGH);
delay(2000);
digitalWrite(upled,LOW);
else {
digitalWrite(upled,LOW); // turn LED off
if (a2 == HIGH){
digitalWrite(downled,HIGH);
delay(2000);
digitalWrite(downled,LOW);
else {
digitalWrite(downled,LOW); // turn LED off
if (a3 == HIGH) {
digitalWrite(leftled,HIGH);
delay(2000);
digitalWrite(leftled,LOW);
else {
digitalWrite(leftled,LOW); // turn LED off
if (a4 == HIGH) {
digitalWrite(rightled,HIGH);
delay(2000);
digitalWrite(rightled,LOW);
else {
digitalWrite(rightled,LOW); // turn LED off
Thank you!
i am new to Arduino. Actually my project is basically to vibrate pager motors. I am trying my code with LEDs. I am not using switches. Its a project for deaf and dumb. When my mic will receive analog input, the motor who is getting this input should vibrate. But only for a sec or 2.
Let me also tell you that I have not connected the mics yet. Just checking if the motors are vibrating whenever they get input. So I am connecting inputs manually for now. When I give input the motor vibrates continuously.
Hope u get my problem.
Also tell me if my approach is wrong
Thank you!
Go back to LarryD's reply and re-read the second paragraph. Using the BWOD (blink without delay) technique essential in most Arduino programs. Your code has many 'delay(200);' statements. What happens if a sound is detected during one of these delays? (hint: absolutely nothing)
There are threads here that discuss the logic of an Arduino program. Learn how to write a useful Arduino program before starting off on a complex topic such as this one. Otherwise you will find yourself starting over fresh after a while, and possibly more than once.
The demo Several Things at a Time is an extended example of BWoD and illustrates the use of millis() to manage timing.
...R
Here is a start point:
//Not tested
//global variable area before setup()
byte a1Flag = false;
unsigned long a1Millis;
//somewhere in loop()
a1 = digitalRead(upip);
if (a1Flag == false && a1 == HIGH)
digitalWrite(upled,HIGH); //led on
a1Flag = true; //allow timing
a1Millis = millis(); //set to the time right now
//time to turn off the led?
if(a1Flag == true && millis() - a1Millis >= 2000)
digitalWrite(upled,LOW); //led off
a1Flag = false; //get ready for the next HIGH on a1
//*********************************** repeat these lines with a2, a3 and a4 stuff
Thank you all!
Now that i m working with switches.
Connected pull down resistor
I have used rocker on/off switch
when i make it off still the motor is not switching off
only when i make any other switch on the previous motor is turning off ![]()
attaching rough sketch
now that for final sketch i m working on everything you all provided on delay
but for the time being i m not using delay
just trying to at least switch off motor when switch is off
Thank you
Testing your code sir ! Thank u so much @LarryD sir.
