Delay problem when using two DC motors simultanious
Hello there,
I am using Arduino for the first time so let me know if I'm missing out something!
My goal is to control a robot using 2 DC motors via Arduino MEGA and the adafruit_MCP4725 library.
When sending commands, the motors that should be active simultanious are driving with an offset. For example, when sending the command to drive in the same direction for x seconds, one of the motors starts a few seconds later which results in the problem that driving to specific locations is not possible for me. The motors offset duration or which one of them shows the problem is allways different so I can't figure out an exact pattern.
I allready tried to check the hardware with an exernal voltage source. It showed that the hardware is fine, both motors approach at the same time when the needed voltage is reached. But the moment I attach them to the Arduino MEGA the problem occurs again.
To control the motors direction I am using a Joystick that sends commands "Forward, Backward, Left, Right, Stop" via a Bluetooth connection to the main board.
Unfortunately the used code is way bigger than the following so it's possible that i miss something you need for the understanding. So feel free to let me know about that and I'll try to give you the information. Also i provide you my current curcuit diagram with the two DA-Converters.
Here are some more information that are not shown in the code:
"v" is the value 1650. The motors work with voltages between 0,8 V and 3,6 V. Giving the value 1650 means that they get a Voltage value of 1,65 V
The Code I am using to process the commands is the following:
//Definition of the two DAC
Adafruit_MCP4725 dac_links;
Adafruit_MCP4725 dac_rechts;
const int Dir_right_wheel  =3;
const int Dir_left_wheel  =2;
  pinMode(Dir_right_wheel,OUTPUT);  //Deklariert Motorwerte als Ausgänge
  pinMode(Dir_left_wheel,OUTPUT);
    dac_links.begin(0x62);            // Deklariert die Adressen der Motoren für DA-Wandler
    dac_rechts.begin(0x63);
// Integration Part Motorsteurung
#include <SoftwareSerial.h>
#include <Adafruit_MCP4725.h>
  //Hier wird die Nachricht des Clients gelesen in der Variable "Message" gespeichert
        char message = client.read();
  // Die Nachricht des Client wird im seriellen Monitor ausgegeben
        Serial.write(message);
        client.print(message);
        if (message == 'B')
          digitalWrite(Dir_left_wheel,HIGH);  //High and Low sind zur Steuerung der Richtung
          digitalWrite(Dir_right_wheel,LOW);
          dac_links.setVoltage(v,true); // Der Wert gibt an wie schnell sich die Räder drehen
          dac_rechts.setVoltage(v,true);
          Serial.println("Forward"); // Ausgabe im seriellen Monitor
    // LED leuchtet beim Rückwärtsfahren weiß
          strip.setLEDcolor(0, WHITE);
          strip.setLEDcolor(1, WHITE);
          strip.writeStrip();
         // Serial.println("A wurde geschickt!"); // Alternative 2, Rückgabewert über die Arduino Konsole
         // delay gibt die Fahrdauer an, hier 5 Sekunden
        else if (message == 'F')
          digitalWrite(Dir_left_wheel,LOW);  //High and Low sind zur Steuerung der Richtung
          digitalWrite(Dir_right_wheel,HIGH);
     // Beim Vorwärtsfahren leuchtet die LED grün
          strip.setLEDcolor(0, BLUE);//In der Library sind Blue und Green vertauscht
          strip.setLEDcolor(1, BLUE);
          strip.writeStrip();
     // Delay gibt die Fahrdauer an, hier 5 Sekunden
        else if (message == 'L')
          dac_rechts.setVoltage(v,true); //
          Serial.println("Left"); // Ausgabe im seriellen Monitor
      // Beim nach Linksfahren leuchtet die LED Blau
          strip.setLEDcolor(0,GREEN);
          strip.setLEDcolor(1,BLACK);
          strip.writeStrip();
      // Delay gibt die Fahrdauer an, hier eine Sekunde
        else if (message == 'R')
          dac_links.setVoltage(v,true); //Der Wert gibt an wie schnell sich die Räder drehen
          Serial.println("Right"); // Ausgabe im seriellen Monitor
      // Beim nach Rechtsfahren leuchtet die LED Blau
          strip.setLEDcolor(0,BLACK);
          strip.setLEDcolor(1,GREEN);
          strip.writeStrip();
      // Delay gibt die Fahrdauer an, hier 7 Sekunden
        else if (message == 'S')
          dac_links.setVoltage(0,true); // Der Wert gibt an wie schnell sich die Räder drehen
          dac_rechts.setVoltage(0,true); //
          Serial.println("Stop"); // Ausgabe im seriellen Monitor
       // Die LED blinkt bei einem Stop-Befehl 6 mal rot auf
          strip.setLEDcolor(0,RED);
          strip.setLEDcolor(1,RED);
          strip.writeStrip();
Thank you everyone in advance for your help. As allready mentioned, I'll try to support you with missing information as fast and best i can.
Can you post an annotated Schematic not a frizzy picture. Also post links to "Technical information" on the hardware devices.
I don't see any delay in your code. What is your problem?
Okey so looks like i messed up a few things here, my bad.
So the problem I'm encountering is not like a delay written in the code itself. Its more like a lag from the motors. The moment the motors recieve a command, for example "drive forward" (so both motors should start at the same time and end at the same time) they wont spin simultanious.
It happens quite often that just one motor starts spinning and the other one starts a bit later. I want to fix that so the wheels attached to it drive in one line.
I hope this one helps.
Can you quantify the delay in the motor starts?
Do you get any improvement if you change the true to false, and don't write the setting to the device eeprom?
There are some other modifications you can make to the library (like leaving the bus speed at 400KHz) which might speed things up but fundamentally you are sending two separate, sequential i2c commands and the motors will respond sequentially.
Do you have any documentation on the motors you can provide?
What happens if you interchange the motors ? Does the problem move to a different motor or stay with the same one ?
