I trying to make the infrared receiver receive signal from infrared transmitter. The receiver circuit that I used is attach below.
So when I open the serial plotter, there is a signal on coming even I did't transmit anything. But It also can detect transmit signal when I turn on the transmitter.
code that I use for transmitter is just blinking
I also attach picture of signal and infrared receiver that I used
Picture at serial plotter is when I didn't transmit anything
Picture at serial-with-transmitter is when I turn on transmitter.
How can I just show the signal from transmitter? or I need to change the circuit or photodiode?
Sorry for English. Its not my main language.
You need to modulate the IR signal. Usually 38 kHz is used.
The sun, our bodies, bulbs... everything has some IR radaiation. But none of them at 38 kHz!
Sorry I new for this.
You mean that I have to change new receiver and transmitter right?
What if I use KY-005 as transmitter and KY-022 as receiver. It will be fine right?
I think it looks good. Note that the transmitter likely sends out a quite wide beam. If You use stuff to limit, focus the beam, the range will increase.
