Detecting a voltage to sensor
Hii everyone,
I want to know the voltage of sensor I write the code its working fine on normal state of sensor but
I blocked the ir sensor the voltage is increase .5v , the board should not detect the blocked sensor voltage , So how to detected the voltage please suggest me.`
This is a code , I Used Atmega 2560
int value = 0;
float voltage;
void setup(){
void loop(){
value = analogRead(A0);
voltage = value * 5.0/1023;
Serial.print("Voltage= ");
Serial.println(voltage);
Please post a link to the sensor product page or data sheet, and a wiring diagram (hand drawn is preferred, with pins and connections clearly labeled).
I have no idea about sensor just in sensor just given a voltage of 2.8v on normal state and in blocking state the sensor given 3.2v check with multimeter and the sensor has two- 1 pin is common grounding and other for taking output from sensor
And neither do we! So is this a guessing game or do you really want some help with something Arduino related?
If voltage > 3.0V then is blocked
If voltage < 3.0V then is NOT blocked.
Thanks for reply,
Yes i really want help
I Know some reading of sensor data
This is the reading of blocking the sensor**(the sensor is blocked**)
This reading is sensor on normal state if sensor is not blocked
Since I can't actually read what the pictures show, tell us why you know the difference and if you know the difference, where is your problem?
So the problem is this:
When connected to the Arduino A0 pin it always reads 1.86V but when you read it with a voltmeter, it changes from 2.8V to 3.2V
Am I correct?
yes
that should not showing the difference they were two cases:
1.In first case i worked with normal cases that the normal case we should present the default case 1.86v repeated many times then 0 will coming in normal state
2.In second case they should worked on blocking the sensor in blocking state the sensor has no default values are given send in documentation .
Sorry, that makes no sense to ma at all!
Post a schematic and picture of DUT.
A picture is worth 1000 words.
post a schematic please, and a link to your "sensor" data sheet
