Greetings,
I am very very new to magnetic fields and study. I have been thinking about building a senor net that would cover a large area, be low voltage (solar / battery), but also be high res enough to be useful.
Like Adafruit Triple-axis Magnetometer, there is one that is "wide" and one that is not so wide. Paired with a GPS (or would it be better to have more than one, like 3 equally dispersed).
My question about these types of sensors - if you had more than one in a grid, can you use the output from each to get better readings overall?
If I wanted to monitor an 80 acre area that is mostly line of sight, what kinds of sensor placement and density should i consider?
I am afraid i dont know enough to know what kind of density i would need to create measurement wise to have accurate meaningful data. My thought with more a dispersed set of arrays that could relay data back to a pi is that the combination from several different sensors would give me a better picture overall. I remember hearing that the gas/oil industry use like 900Mhz transmitters to relay. Can something like that be achieved using ardunio for the sensor management and relay of data back to the PI? but over distances that could approach .5 miles or .75 miles. Can you do mesh?
I am not afraid to read the manual. I was hoping for some ideas about how to calculate my power requirements for the individual sensors and ardunio to store/forward, something i am not good at, at all
An idea of what kinds of transmitter to use in an outdoor hostile (northern maine winters) environment:
What kind of housing should i consider? Either staying away from conductive metals or synthetic?
Should I consider having a low power heater or just shut down if -32f or temps exceed environmental specs? How do you harden for environment? Fiberglass insulation wouldnt impact would it?
What kinds of transmitters i should look at for transmitting over open (or slight obstructions) ground, resistant to humidity / rain / snow / ice (friends have told me that lower range communications can fade during heavy rains). Is there an antenna design that would achieve this?
Lastly, if i wanted to measure watts of power being given off or electric field charge of the atmosphere at those sites what are good sensors for those kinds of measurements.
What am I missing? What should I be reading?
Thank you! Thank you! Thank you in advance!!!
John
